Old 12-05-2016, 11:59 AM   #29
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Did you measure the car in the same spot each time?
Old 12-05-2016, 03:13 PM   #30
Zeuseidon
Zeuseidon's Avatar
Drives: 2014 Sterling Silver BRZ
I measured in my garage which does have a 5" difference throughout the 21' depth. However, I measured with the car pulled in and reversed and car read identically, at least with a ruler and the naked eye.
Zeuseidon is offline   Reply With Quote
Old 12-05-2016, 03:49 PM   #31
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
It looks like the SPL damper mounting holes are varying heights where the center should be equal to OEM:
It looks like you already got the answer from SPL, but moving the shock mount to the center one should give you the end result that you're seeking.
Before you get to working on the car again, would consult the install instructions for the Bilsteins to verify if a bump stop is required for the rears and install if they are...
asdf is offline   Reply With Quote
The Following User Says Thank You to asdf For This Useful Post:
Zeuseidon (12-05-2016)
Old 12-05-2016, 04:20 PM   #32
Zeuseidon
Zeuseidon's Avatar
Yup, I called Bilsteins this morning to confirm dimensions of shock and its effect (if any) on ride height. It is stock, with the exception of extended length they said is shorter so as to not unseat a lowering spring at full droop.
And they did say the rear reuses OEM bumpstop.
The Following User Says Thank You to Zeuseidon For This Useful Post:
asdf (12-05-2016)
Old 12-06-2016, 03:40 PM   #33
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
So now it's possibly the shocks? lol
For reference, I've lowered my personal car more in the rear than the front relative to stock using adjustable coilovers after experimenting various different heights and rake settings. Approx. -15mm front -18mm rear is where I settled at. I actually prefer having a bit less rake than stock to shift the weight over the rear slightly more. Long story short, you might actually like the way you car behaves with the rear lower than the advertised drop for your springs. so just enjoy it!
Although being somewhat OCD myself, I'd probably remount the factory arms just to check anyway. Jot it down in my notes. lol
Intent > Content
Old 12-06-2016, 04:07 PM   #34
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Dude, he currently has no bump stops in the rear...
ineedyourdiddly
Old 12-06-2016, 04:34 PM   #35
solidONE
solidONE's Avatar
Okay then throw them on and see what happens. I don't see how that will change the ride height even if it's riding on them at static height. Unless they're pinched between the body and perch, which I dont think is the case having ran Swift springs on my car previously.
Intent > Content
Old 12-06-2016, 04:34 PM   #36
eh they are overrated anyway.
strat61caster (12-06-2016), Zeuseidon (12-06-2016)
Old 12-06-2016, 04:50 PM   #37
Zeuseidon
Zeuseidon's Avatar
Haha, no it's not the Bilstein's. I was just following up on a suggestion to check if they're "stock specs" and to verify the need for bump-stops.
In other news, I changed the mounting hold for the SPL's which did raise it nominally. At this point I'm gunna reinstall my stock bumpstops (which were trimmed from a previous set of springs) just because they're supposed to be there, and chalk it up to allowable variances in specifications between the three added parts.
Like I said previously, I really just wanted to make sure nothing was severely wrong.
Which the general consensus is, it might not be good to mod if you're OCD
The Following 3 Users Say Thank You to Zeuseidon For This Useful Post:
asdf (12-06-2016), solidONE (12-06-2016), strat61caster (12-06-2016)
Old 12-06-2016, 06:03 PM   #38
strat61caster
Bump stops act as an additional spring, it will absolutely affect ride height if they are engaged, their entire purpose is to be pinched between the damper and spring perch. On my B14's the OE stops were engaged even at a modest 1/2" lower than stock iirc. Given that the swifts lower a whole inch and the B8's are similar dimensions to the B14 I bet they're very much needed.
In any case, sounds like the LCA's may have been the primary cause.
ineedyourdiddly
Old 12-06-2016, 06:20 PM   #39
solidONE
solidONE's Avatar
While I dont know the exact numbers, my reasoning is that the bumpstops dont offer too much additional spring rate while the shock body is just resting on top of it. Seeing that you can easily squeeze and compress them between your fingers. Not enough to add to the ride height. Obviously it would increase as it's being compressed such as while taking a corner or hitting a bump. Then again, that's me assuming it is not compressed much at static ride height with the springs. And I did trim my bumstops while I was using the swift springs. so... yeah.
Intent > Content
Rear ended while sitting in traffic Sanchez Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 23 01-12-2017 03:49 PM
FS: Stock suspension and rear lower control arms nickg Brakes, Suspension, Chassis 1 08-20-2016 08:41 PM
FS: OEM Front & Rear Suspension MicheleAbbate Brakes, Suspension, Chassis 46 02-21-2016 12:48 AM
oem front and rear suspension sickmint79 Brakes, Suspension, Chassis 0 08-08-2015 03:12 PM
