#1066 |
Drives: FR-S Whiteout
Ahh.. I didnt see the vid.
Intent > Content
cowardice is the mother of cruelty. |
#1067 |
Drives: 2013 satin white brz limited
So I'm Considering either the 350 or the 400 series header. Is the extra $300ish worth the gains on the 350 or not in your opinions? Its just a summer fun driver that will be driven on e85. That said not totally ruling out going FI in the future but hoping that by doing this header with the rest of the exhaust and the tune that it will provide enough power to satisfy me.
#1068 | |
#1069 |
I guess let me rephrase. What kind of apx power numbers am I leaving on the table on the upper end by going with the 400 over the 350.
#1070 |
Drives: 2016 Halo FRS
Made 184 full bolt ons with the 350 type a at moto-east
Hope that helps |
#1071 | |
Drives: Subaru BRZ / Toyota 86 Experts
#1072 | |
I've worked quite a bit with delicious in the past and will continue to in the future for my tune once I add either the 400 or 350 series ACE headers. Guess I will just have to see where the finances are come spring and go from there! |
#1073 | |
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
I been speaking to Dave on FB. I'm the guy with the JUN manifold setup, etc. +70hp over stock N/A |
#1075 |
I'm actually not familiar with your setup; if you've been talking to David, I would go with his recommendation!
#1076 | |
Just waiting on dyno results of the anaconda from you guys Atm setup, running Shell VPower --- [Induction] --- HKS Cold Air Intake HKS Panel Filter Perrin Si Intake Tube Torque Solution TB Spacer Crawford Billet power blocks TODA Throttle Body JUN Intake Manifold --- [Exhaust] --- HKS 4-2-1 EL Headers MOTIV overpipe HKS Catted Front Pipe HKS Racing Single Exit Whole exhaust heatwrapped in DEI Titanium --- [Misc Engine, lightening stuff] --- Fluidampr Pulley GReddy lightweight pulleys 10.5lbs Prolite flywheel DriveShaft Shop carbon fibre driveshaft 4.556 Final Drive btw, anyone know if its beneficial/detrimental to run the Crawford billet power blocks with the Ace headers? Any idea what it would do with the torque curve? The JUN gives me more power up top instead of plateau-ing btw |
#1077 | |
Drives: GTS 86
Have a dyno run with and without and decide which one you like more. |
| The Following User Says Thank You to Hawk77FT For This Useful Post: | stevo_12v (12-12-2016) |
#1078 | |
| The Following User Says Thank You to CounterSpace Garage For This Useful Post: | 2015firestormFRS (11-10-2017) |
| Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? | alanhung85 | CANADA | 6 | 10-21-2014 10:41 PM |
| RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP | NickFRS | Engine, Exhaust, Transmission | 44 | 04-19-2014 05:42 PM |
| Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 82 | 04-14-2014 08:16 PM |
| Gutted cat stock header vs aftermarket catless header NA application | stevo585 | Engine, Exhaust, Transmission | 8 | 04-04-2014 04:12 PM |
| Wanted: UEL header with Perrin header back and tune. | skye67 | Engine, Exhaust, Transmission | 7 | 12-21-2013 10:34 PM |
