Old 12-01-2016, 08:55 PM   #533
wbradley
Sarcastic SOB
wbradley's Avatar
A lot of people seem to think that there is no need to switch to a colder plug with these cars in the typical <300 WHP setup.
I bet the plugs you swapped were still good despite the markings. If the tips looked good that's a positive sign.
Lostpanda, didnt realize you were on the V3. So, your V3 with 110mm pulley produces almost the same power as my V1 that also has a deleted restrictor plus a larger intercooler. For stock fuelling I am so maxed out that the tuner felt it best to set fuel cutoff to 7100 RPMs.
I decided to leave my tune at that point even though I already have the injectors, only need a fuel pump. Reason, I dont feel the need to spend thousands more for clutch, drivetrain upgrades etc and I am CERTAINLY not willing to blow an engine. Frankly, I dont think these cars are my idea of a drag racer.
Old 12-02-2016, 03:58 AM   #534
makinen
makinen's Avatar
Drives: Toyota 86
Originally Posted by lostpanda View Post
Finally I change the pulley to 110mm back, the max whp almost 261.
90MM with the big injecters is the good way.
But the pressure will be 1.1 bar on this V3 7400RPM so I must change so many staff for my engine if not, I think it will very dangerous.
With the stock fuel system, around 1 bar (14.5 psi) could be supported like below. With 100mm pulley + 7800 RPM, 100-200 km/h cleared in 10 seconds.
Originally Posted by makinen View Post
I've tested acceleration of 86 with v3 installed.
V3 + 100mm pulley (boost peak recorded is ~14.5 psi.)
RON98
225/50R16 Kumho 4X-II
makinen is offline   Reply With Quote
Old 12-02-2016, 08:13 AM   #535
wbradley
Sarcastic SOB
wbradley's Avatar
If you have moved fuel cutoff to 7800 on stock fuelling without leaning out I am shocked...that you havent blown a hole through your engine!
Old 12-02-2016, 08:43 AM   #536
makinen
makinen's Avatar
Drives: Toyota 86
AFR is well maintained between 12:1 - 11:1 until top end.
Injectors still have margins but not much.
Old 12-02-2016, 09:18 AM   #537
wbradley
Sarcastic SOB
wbradley's Avatar
Stock injectors and stock fuel pump?
Old 12-02-2016, 09:40 AM   #538
scmil95eg
Drives: '95 delSol, '13 EvoX, '14 Leaf
A completely stock unmodified engine will do that to a stock plug. There isn't anything there you need to be concerned about.
What do the straps look like?
What does the porcelain around the electrode look like?
What does the fuel ring look like?
scmil95eg is offline   Reply With Quote
The Following User Says Thank You to scmil95eg For This Useful Post:
wbradley (12-02-2016)
Old 12-02-2016, 11:00 AM   #539
makinen
makinen's Avatar
Drives: Toyota 86
Sure.
Old 12-04-2016, 09:52 PM   #540
Koj
Koj's Avatar
Drives: Toyota GT86
Originally Posted by Torry@HKSUSA View Post
Thanks, that could be a good idea. I'm waiting on HKS Japan to get back with me on a couple of the part numbers so I can complete a table like this. When I get all the info, I'll put up a table on the HKSUSA website for reference.
Torry ?
Any news about the table ?
Koj
S/C HKSv2, HKS R Spec Manifold, Fujitsubo Authorize R Type S Catback, and more...
My Journal/Garage
Koj is offline   Reply With Quote
Old 12-05-2016, 08:31 AM   #541
Torry@HKSUSA
Torry@HKSUSA's Avatar
Drives: HKS
Originally Posted by Koj View Post
Torry ?
Sorry, been busy and forgot I said I'd put this together. I'll be out of town this week attending PRI, but I'll try to work on this next week. Feel free to remind me again if you don't see it in a couple weeks.
Torry@HKSUSA is offline   Reply With Quote
Old 12-05-2016, 10:55 PM   #542
lostpanda
Drives: FT86
Can our FA20 bear the 1 BAR from the supercharger ?
I just concern about my engine.
My tuner told 0.8 is safty.
I do not know about 1BAR
lostpanda is offline   Reply With Quote
Old 12-06-2016, 12:08 AM   #543
makinen
makinen's Avatar
Drives: Toyota 86
Have you read this article?
http://www.ft86club.com/forums/showthread.php?t=97827
Old 12-06-2016, 12:33 AM   #544
Yobiwan
Yobiwan's Avatar
Drives: Toyota 86 Turbo, Lexus NX300H
yes. stock engine can handle 1 Bar boost easily.
I run 14psi over 4months with HKS v2 S/C.
but without Methanol or lowering CR, it does not make more power than .7bar of boost.
2012 Toyota 86 6MT / 11:1 CR block by Outfront / SBD500x Turbo 17PSI@93gas /Avo 2.5 overpipe+Avo 2.5 catted frontpipe /MAP 3" CBE/ Tein Mono sport / STI brembo Front /OS技研 LSD/SSR GTX01 18x9.5
Yobiwan is offline   Reply With Quote
Old 12-06-2016, 11:07 AM   #545
Torry@HKSUSA
Drives: HKS
Torry ?
Ok, made this:
http://www.hksusa.com/supercharger-kits-5/
Anything else you guys think should be on there that I'm missing? I forget what all parts everyone was asking about.
The Following 2 Users Say Thank You to Torry@HKSUSA For This Useful Post:
Koj (12-09-2016), Yobiwan (12-07-2016)
Old 12-06-2016, 06:00 PM   #546
empower-auto
Kouki-Monster
empower-auto's Avatar
Ok, made this:
Where is the traction fluid filter found on an installed system? (V2)
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
Five Axis Edition FR-S Owners Thread digital_assassin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 563 07-08-2015 09:22 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
Supra Owners Build Thread BoostJunkie Other Vehicles & General Automotive Discussions 164 03-12-2012 09:37 AM
