Old 11-30-2016, 07:51 PM   #197
justatroll
justatroll's Avatar
Drives: Full race 4cyl boxer
My experience would say otherwise...
You could always test it if you are on really good terms with the dyno operator.
Jack up one side a little for a pull until one wheel starts to slip.
You might be able to hear the ABS system actuating and see the response in the dyno data. (small step function in torque when it applies brake)
Arguing with an engineer is like wrestling with a Pig in the mud. You are never going to win and after a couple of hours you realize that he likes it.
justatroll is offline   Reply With Quote
Old 11-30-2016, 09:50 PM   #198
Bad idea. The pedal dance (Inspection Mode) exists specifically for chassis dyno safety.
HINT:
  • If Inspection Mode is not used, the vehicle may unexpectedly move off the dynamometer because of TR(A)C and VSC operation.
  • The VSC OFF switch must not be used to disable TR(A)C and VSC operation when the vehicle is to be operated on a dynamometer. Pressing the VSC OFF switch does not disable TR(A)C and VSC operation completely.
justatroll (11-30-2016)
Old 11-30-2016, 11:14 PM   #199
justatroll
justatroll's Avatar
Of course I know that.
It would be for "engineering evaluation purposes only".
Do Not try this at home
This test is being performed on a closed dyno by professionals
We cannot be held accountable for any property blah blah blah.
It would still be an interesting test.
One of those F1 car test rigs would be fun to test our cars to explore the behavior of the various VSC, TC, ABS, EBD, & EDIFF modes.
The Following User Says Thank You to justatroll For This Useful Post:
Ultramaroon (11-30-2016)
Old 11-30-2016, 11:19 PM   #200
Haha... Well, if you put it that way...
Old 12-01-2016, 12:53 PM   #201
johan
Drives: '14 981CS, '99 NB1
Didn't do the pedal dance to tune my 15 or my 17 - shrug.
johan is offline   Reply With Quote
Old 12-01-2016, 01:27 PM   #202
Without eyes on the source or at least a solid functional diagram that text is no more than a liability disclaimer. Intentionally lifting a wheel to see the effect is a different story. I'd hate to read about a mishap because someone actually tried it.
Old 12-01-2016, 03:10 PM   #203
ayau
Drives: Some rust bucket
@CSG Mike, can you comment on the acceleration/torque between an e85 with Ace header tuned BRZ vs a stock 2015 WRX? What about a 91 tune and a WRX?
Old 12-01-2016, 05:04 PM   #204
CSG Mike
CSG Mike's Avatar
Turbos make torque.
That's not a comparison I've ever had the opportunity to make, beyond a dyno.
Old 12-01-2016, 07:58 PM   #205
CSG Mike
CSG Mike's Avatar
Because Laguna Seca.
And CSG's Laguna special is not ready yet so I can't buy one.
Zero rattles with stock front pipe. Awesome.
SuperDave (12-01-2016), whataboutbob (12-01-2016)
Old 12-01-2016, 09:38 PM   #206
ayau
Turbos make torque.
Thought you have both vehicles. Can a tuned BRZ keep up with a stock WRX on the straights?
Old 12-01-2016, 09:51 PM   #207
CSG Mike
CSG Mike's Avatar
I don't know; I haven't tried.
Old 12-01-2016, 11:00 PM   #208
SuperDave
SuperDave's Avatar
Drives: DAT Rally Blue BRZ
nice! thanks for the info, can I get a ride at laguna seca?
SuperDave is offline   Reply With Quote
Old 12-01-2016, 11:04 PM   #209
Who8myrice
Drives: Ap2
Header stage2 e85 frs was neck to neck with stock WRX from 20roll all the way to triple digit, then wrx started to pull slower then my mom riding bicycle.
This was at Mexico of course
Who8myrice is offline   Reply With Quote
Old 12-02-2016, 03:22 AM   #210
CSG Mike
CSG Mike's Avatar
Sure, although I can't promise anything spectacular!
Mad Mike's Firestorm Build Mad_Mike Member's Car Journals 90 01-21-2026 09:08 PM
My thoughts on my build (Down South in Africa)! 86 South Africa Member's Car Journals 2 02-02-2016 07:55 AM
Mike&Ikes WRB Build Mike&Ike Member's Car Journals 8 09-18-2015 03:12 AM
Mike Mac's Raven FR-S NYC Build ScionFR-S Member's Car Journals 5 06-07-2014 01:49 PM
Mike's CS FR-S build mikef Member's Car Journals 6 04-25-2013 09:11 AM
