Old 11-30-2016, 12:35 AM   #1
H-TownBrz
H-TownBrz's Avatar
Drives: 2013 WRB Brz Premium
OFT Launch Control/Anti-Lag - spit flames?
I'm very new to the tuning scene, and I was just wondering if there was a way to implement a spark cut at the launch control rpm limiter so it can shoot flames... Sort of like the megasquirt miatas and their spark cut to induce flames on their launch control. Any input will help!
H-TownBrz is offline   Reply With Quote
Old 11-30-2016, 01:34 AM   #2
Leonardo
Country Boy 4 Life
Leonardo's Avatar
I remember a thread... yep.
http://www.ft86club.com/forums/showthread.php?t=38795
Old 11-30-2016, 01:43 AM   #3
aagun
Drives: 86
u can do that using timing tables in romraider
if u set LC At 5k
go to the timing in gear blow the speed . then edit the rpm up to 6k . including 5k rpm
then if ur in gear blow the speed (2)mile stock rom . the retreat to -20
u can increase fuel target at 4k-6k in CL and OL at low load
aagun is offline   Reply With Quote
Old 12-01-2016, 11:17 PM   #4
wparsons
wparsons's Avatar
Unless you're catless, you're going to have a bad time with trying to shoot flames.
flickr
Old 12-02-2016, 01:35 AM   #5
BRZyJ
BRZyJ's Avatar
Drives: 2013 BRZ Limited / 2024 G70 3.3T
BRZyJ is offline   Reply With Quote
Old 05-12-2018, 02:13 AM   #6
Bisofication
Bisofication's Avatar
if u set LC At 5k
@aagun Can you please explain more? I'm kinda a newbie and would love to do it (I got the oft with pop tune but would like to also have it when I LC)
Thanks
Bisofication is offline   Reply With Quote
Old 05-15-2018, 03:06 PM   #7
aagun
Drives: 86
Thanks
I HAD LONG TIME NOT MISS WITH THAT THING
YOU NEED TO REMOVE IDLE CHECK FROM THE ROM
Old 05-23-2018, 03:09 AM   #8
FRSBRZGT86FAN
FRSBRZGT86FAN's Avatar
Also it'll totally destroy any muffler packing and make your car louder in the long run.
The Following 2 Users Say Thank You to FRSBRZGT86FAN For This Useful Post:
Teseo (05-26-2018), wparsons (05-23-2018)
Old 05-23-2018, 11:01 AM   #9
Tor
Tor's Avatar
Drives: Toyota GT86
Originally Posted by H-TownBrz View Post
....I was just wondering if there was a way to implement a spark cut...
No, it's not possible with the stock ECU. To answer your actual question...
Tor is offline   Reply With Quote
Old 05-26-2018, 01:14 AM   #10
FRSBRZGT86FAN
Seriously? I could've sworn its possible somewhere in rom raiders tables, there's a fuel cut easily enough...
OFT launch control inop. shifter907 Software Tuning 34 06-17-2017 12:08 AM
OFT + Launch Control = How tf?! Strife26 Software Tuning 16 05-31-2016 02:42 PM
Help on Launch control disable speed to control wheel spin during launching j.boy Software Tuning 8 02-01-2016 04:58 AM
Best RPM to set OFT Launch Control to? Aztec Software Tuning 12 03-23-2015 08:56 PM
How bad is launch control Bg8780 Engine, Exhaust, Transmission 23 07-09-2014 01:47 PM
