Old 06-26-2012, 03:14 PM   #15
Boosted2.0
Boosted2.0's Avatar
Drives: 13 FR-S, 00 Spyder&Celica, 08 Tundr
Originally Posted by R Corse View Post
Is this good for any Toyota motor? Or just the FRS/BRZ?
This blue coolant is only used in the FR-S.
All other Toyotas use the pink SLLC.
Boosted2.0 is offline   Reply With Quote
Old 06-26-2012, 06:21 PM   #16
R Corse
Drives: Ducati R Corse
What about the "Red Stuff"?
That's been going around too.
R Corse is offline   Reply With Quote
Old 06-26-2012, 06:57 PM   #17
chulooz
Registered you sir
chulooz's Avatar
Drives: 99 impreza coupe
Is this good for any Subaru motor? Or just the FRS/BRZ?
Fixed... but once you go back (to green) you cant go blue.
chulooz is offline   Reply With Quote
The Following User Says Thank You to chulooz For This Useful Post:
Dreyup (01-09-2016)
Old 06-26-2012, 09:15 PM   #18
R Corse
Well that's grand, but I could care less about Subaru motors. I'm more concerned about Toyota motors/engines; that is why I phrased it:
"Is this good for any Toyota motor?"
Thank you for the info though; I did not know that about the green/blue.
Old 06-26-2012, 09:26 PM   #19
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
Toyota Long Life Coolant (Red) was used in vehicles up to 08/2003 production.
Toyota Super Long Life (Pink) is used in vehicles from 08/2003 production on, with exception of FR-S, which uses blue.
From the description in the owner's manuals it sounds like the Pink and Blue stuff are pretty similar.
Scion FR-S Description: "Use either Super Long Life Coolant BLUE or similar high-quality ethylene glycol-based nonsilicate, non-amine, non-nitrite, and non-borate coolant with long-life hybrid organic acid technology"
Other Toyota/Lexus/Scion Models: "Use either Supra Long Life Coolant or similar high-quality ethylene glycol-based nonsilicate, non-amine, non-nitrite, and non-borate coolant with long-life hybrid organic acid technology"
Toyota lists their Super Long Life Coolant as being compatible with their older Long Life Coolant.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
The Following 4 Users Say Thank You to Jeff Lange For This Useful Post:
carbonBLUE (06-27-2012), chulooz (06-26-2012), jcw99 (07-10-2014), JohnJuan (03-09-2015)
Old 06-26-2012, 11:31 PM   #20
R Corse
Jeff
Freaking awesome information; thank you so much. Asked around, and that was the most informative reply I have received!
Old 06-29-2012, 01:41 PM   #21
meltman
meltman's Avatar
Drives: The "L" train
That's total bologna. Subaru's magic blue coolant is just standard ethylene glycol based with a bit of diethylene glycol and some water (50%).
It's the same base composition as standard cheap green coolant but with blue dye instead of green and a higher price tag.
You can drain and go back and forth without issue.
meltman is offline   Reply With Quote
Old 06-30-2012, 10:37 AM   #22
AzFranz
Az to Nm to Az
AzFranz's Avatar
Originally Posted by engee View Post
The blue coolant is the Subaru's supercoolant that they started using starting back in 08/09.
DO NOT MIX WITH ANY OTHER COOLANT!
1st replacement interval is 11 years/137,500 miles (220,000 km).
2nd replacement interval is 6 years/ 75,000 miles (120,000 km) after the 1st.
If you mix the coolant with other coolant though, you will be back in 30 months/30,000 miles (48,000Km) interval.
11 Years! Holy insanity. I couldn't imagine waiting that long to change the coolant in my car especially living in Arizona.
It's a sleeper...I launch, it feels like it's asleep.
AzFranz is offline   Reply With Quote
The Following User Says Thank You to AzFranz For This Useful Post:
gonzo (03-01-2013)
Old 07-05-2012, 02:15 PM   #23
AJ PwR
AJ PwR's Avatar
Drives: R35 R56 CZ4A ZC6
Send a message via ICQ to AJ PwR Send a message via AIM to AJ PwR Send a message via MSN to AJ PwR
When you buy any aftermarket coolant , just make sure they meet the manufacturer's approval and that will be all good.
AJ PwR is offline   Reply With Quote
Old 07-05-2012, 10:39 PM   #24
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
This is probably true.
Too lazy to check myself though
Old 10-12-2012, 08:20 AM   #25
F1point4
Photo Specialist
F1point4's Avatar
Drives: 2013 Toyota 86 DGM 6MT
Dealer wants 35 bucks for the jug
F1point4 is offline   Reply With Quote
Old 10-12-2012, 10:29 AM   #26
gmookher
its not the same.
Unless you have done HPLC and can prove it dont suggest it just for color.
its not. That said, you can use BMW blue as well.
Old 10-12-2012, 11:37 AM   #27
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Nissan has blue now too we switched over around mid year 2010.
The Following User Says Thank You to JoeBoxer For This Useful Post:
gmookher (10-12-2012)
Old 10-12-2012, 01:59 PM   #28
jarviz
jarviz's Avatar
Drives: Raven FRS MT
yup, such . any 3rd party coolants that can be used instead?
jarviz is offline   Reply With Quote
GALAXY BLUE SILICA BRZ Compilation Hachiroku BRZ Photos, Videos, Wallpapers, Gallery Forum 595 12-08-2022 05:55 AM
Galaxy Blue VINs? dorkymork BRZ First-Gen (2012+) — General Topics 49 06-02-2012 09:55 PM
Black, blue, or gray.. i may have a choice here Mykflo BRZ First-Gen (2012+) — General Topics 27 05-26-2012 11:26 AM
I want this edition... (blue modified 86 TRD) xantonin Scion FR-S / Toyota 86 GT86 General Forum 119 02-15-2012 01:02 AM
More pix of blue 86 w/aero+ rims Alfie FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 1 11-29-2011 08:17 PM
