#7659 | |
#7660 |
Grip>Slip
Anyone tried the Grams 72mm throttle body with the 210 yet?
| The Following User Says Thank You to xjohnx For This Useful Post: | 8686 (11-29-2016) |
#7661 |
Mountain Runner
Drives: 2013 Subaru BRZ Limited 6MT
I'm looking into maybe getting an Innovate Stage 2 (intercooled) system, and likely having it dyno tuned somewhere reputable/experienced from the start... But I'd like to know what you (experienced owners) would say the top three supporting mods are, and what fluid is best for the air/water cooler (i.e. water and what additives). Any input is appreciated, it's a matter of me saving up and deciding between an Innovative Stage 2 or a Jackson Racing system. The car will be autocrossed fairly regularly (mostly second gear stuff) and I *may* start track duty next season.
2013 BRZ 6MT Limited: "Quick as Hell, on a Budget" Build • Ceramic Coated Gruppe-S UEL/OP • Konig Hypergrams • RS4 200tw • Koni Yellows, Eibach Springs • Ferodo DS2500's
#7662 | |
Drives: GT 86
I have had the intercooled 210 for 40,000 odd KM now and have not been nice to it in any way shape or form (have a spare motor) and so far the only issue I've had is one belt and I have to top the oil in the SC up every now and then. Have run the 69mm pulley from day one and the redline cut out is set to 7800 rpm . Best addition so far is a set of TOG EL bigger bore headers and 2.5" full Perrin exhaust which bought it to life and an oil cooler to keep temps in check . |
| The Following 2 Users Say Thank You to sam69 For This Useful Post: | brybot (12-04-2016), Keenercarguy (11-28-2016) |
#7663 | |
Just the tip
1. An oil cooler if you plan on doing any type of racing, but no need it you'll just be doing street driving. If only street driving then a higher flow air filter or new intake system like the Moto-East or Perrin. 2. Temperature sensor in the MAP plate to get an accurate temp reading so it can be tuned to it's potential. 3. Full 2.5 exhaust. 4. (Adding a fourth) Get a 70mm or 69mm pulley to maximize the supercharger with either the next size down in the standard belt or the Gates blue racing belt the same size as standard. *For fluids just use 50/50 antifreeze that your car uses. I'd recommend taking it to Moto-East as that's were my tune it from and it's been working well. If I were to buy a kit new (I got mine used for $1300 cheaper), I'd buy an Edlebrock instead of the ones you listed, mainly because of the expand-ability and cooling potential. The Sprintex runs hot even with the intercooler when racing.
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
| The Following 3 Users Say Thank You to stockysnail For This Useful Post: |
#7664 |
Mountain Runner
What about heat soak? Has anyone done lots of back to back testing? I know an oil cooler would help (and I intend to run a 72.5mm pulley, maybeeee a 70mm) but I'm trying to cover my bases
#7665 | |
Drives: 2013 Subaru BRZ Limited (Black)
For the track and for those who rev higher on the street the Jackson Racing is a better package -- but for autocross and street driving I think the 210 is great. |
| The Following User Says Thank You to ajcarson11 For This Useful Post: | brybot (12-04-2016) |
#7666 |
Personally, I can't say i've really experienced any obvious heat soak. But I also live in Indiana where we don't see temps above 80deg for more than about 2 months out of the year. I'm running a 72.5mm pulley, on moto-east tune, non-intercooled.
| The Following 3 Users Say Thank You to ajcarson11 For This Useful Post: |
#7667 |
Drives: 86
I was thinking about it but my tuner says it will not do anything as the stock 65 mm TB is more than enough Sent from my iPhone using Tapatalk
VOLK LE37 17X7.5, SWIFT Springs, Bilstein B8, HKS intake duct, Cosworth Air Filter, HKS headers, PLM Over Pipe, EVS Down Pipe & Exhaust, FD 4.55, GFB pulleys, Axle-Exchange Drive Shaft, Mishimoto oil cooler, Cusco F&R strut bar, TRD door stabilizer, Innovate SC, Delicious Tuned
| The Following User Says Thank You to 8686 For This Useful Post: | brybot (12-04-2016) |
#7668 |
Drives: 2013 Scion FRS
That's the irony behind people getting bigger intakes. They're still restricted by the 2.5in throttle body anyway.
ScreamingElectron - SnakeShit |
#7669 | |
Drives: 2013 SWP BRZ Limited
| The Following 2 Users Say Thank You to jwvand02 For This Useful Post: | brybot (12-04-2016), Keenercarguy (12-03-2016) |
#7670 |
yeah, I lost that bolt when I was installing my kit too. It threw lots of fuel CEL codes and stalled randomly until I fixed it.
#7671 |
Does a tighter belt make a big difference? Is there a lot of slippage with the 69mm?
#7672 |
Hearing a strange fluttering sound at mid/high boost from 3rd gear and up. I'm not sure if I've just picked up on it, or if it just started last week. Anyone else hear strange things like this?
Only started noticing it a few days after I smoked a centrifugally charged frs with the 69mm. Also worth noting that I can only hear it with the windows down - nothing out of the ordinary in the cab noise. Maybe my oil is aging and some valve noise is happening? Any ideas? @PitViper
ScreamingElectron - SnakeShit Last edited by riboyster; 12-08-2016 at 01:19 AM. |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
