Old 05-26-2016, 10:08 AM   #85
dustmann
Drives: '14 WRB BRZ Limited
I talked to a guy in a z06 at the track this weekend who said a lot of the vette guys run continental extreme contact dw for their wet track tires. I have no experience with them, but reviews say they're similar to the PSS which I like.
dustmann is offline   Reply With Quote
The Following User Says Thank You to dustmann For This Useful Post:
dp1 (05-26-2016)
Old 05-26-2016, 10:11 AM   #86
e1_griego
e1_griego's Avatar
Drives: Many
I use DW as my daily tires and puddly autox tire. Big fan, but the PSS is better in the dry by quite a bit. The wear great if you're not beating on them, though.
I had 215 PSS on stock wheels when I bought my car. They were fine, but I was coming from ZII and RS3V2 so I think I wasn't as impressed as people going from primacies to PSS.
e1_griego is offline   Reply With Quote
The Following User Says Thank You to e1_griego For This Useful Post:
dp1 (05-26-2016)
Old 05-26-2016, 10:56 AM   #87
xwd
Yeah the DWs are great rain tires. I also use them as my daily driver tires but the dry grip and braking performance aren't in the same ballpark as a PSS, let alone the top tier tires. I swap tires for events so it doesn't matter, but If you want a single set of tires the PSS is going to be better.
The Following User Says Thank You to xwd For This Useful Post:
dp1 (05-26-2016)
Old 05-26-2016, 01:45 PM   #88
e1_griego
e1_griego's Avatar
Drives: Many
Yeah, I swap to re71s for events. In my last daily driver 240 I ran DW and beat on them for a weekend of fun-runs and they were *pissed*. Learned that lesson the hard way.
dp1 (05-26-2016)
Old 06-26-2016, 04:00 AM   #89
dp1
driving smoother faster
Drives: Sold
My 235/40-17 Toyo RR racer takeoff slicks almost corded yesterday so I replaced them with 255/40-17 Toyo RA1, on 17x9 RPF1s. Almost forgot how good these tires are for DE - plenty sticky, wear like iron, take on heat cycles and progressive at the limit. I don't think that I will run anything but Toyo Proxes RA1 or Nitto NT01 for DE until I can drive at the limit in every corner. After I'm done with these RA1s, I will probably buy a set of 235/40 NT01 for dry and 235/40 RA1s for rain (and dry spares), both on 17x9 from 949racing.com.
dp1 is offline   Reply With Quote
The Following User Says Thank You to dp1 For This Useful Post:
Bramick (12-06-2016)
Old 10-09-2016, 09:41 PM   #90
dp1
Drives: Sold
Updated with 255/40-17 tires
Bramick (10-09-2016)
Old 11-24-2016, 10:28 PM   #91
dp1
Drives: Sold
I'd made a decision mid 2016 track season to stay away from slicks until I learn how to drive over 1G/at the limit in every corner with UTQG 100 tires. I've been thoroughly impressed once again with Toyo Proxes RA1 tires - not cheap but plenty sticky for HPDE, great as rain tires when relatively new and progressive at the limit. I'm getting sustained 1.2-1.3G (depending on banking) on AIM Solo DL with 255/40-17, in dry, with track camber and dialed in suspension. They will heat cycle out before I wear them out. Have a new set in 235/40-17 ready to put on when the forecast is dry+rain. I'll keep one newer set for mixed/wet track days and another more worn set for dry track days, then get a new set when worn retire. Most of the time shouldn't need to carry two sets of wheels.
Old 11-27-2016, 05:55 PM   #92
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Because you've admitted to this:
There's a good chance you will not experience this.
If they do cycle out, you may not notice in your lap time or they may not cycle out at all depending on how fast you wear through them and how hard you push them. I've set fastest times with RA1s (and RRs) showing their cords all the way around the tire. Several racers have.
It's also worth mentioning that a lot of folks will often mistake "cycling out" for a tire that's been at rest for awhile and needs a cycle or two to "wake up". The other thing too is thinking they've "cycled out" while on track because the grip has decreased during the session. A Hoosier R6/R7 will really fall off in performance if the driver is over-driving them, exceeding their slip angle a lot or over heating them but they may have cycled out yet as you can experience this loss of grip on sticker hoosiers if over driven.
I'm saying all this so people don't dispose of tires prematurely! Save those $$$.
PRO86 | WTCC | STL
The Following 2 Users Say Thank You to rice_classic For This Useful Post:
dp1 (11-27-2016), FirstWinter (11-27-2016)
Old 11-27-2016, 06:49 PM   #93
dp1
Drives: Sold
Good feedback thanks!
The RA1 are definitely faster as they wear and apparently fastest just before they cord. I'd heat cycled them out before (I was a little slower then) and I see that I'm wearing them faster now but not fast. They wear like iron, impressive. Nitto NT01 wore quicker.
No personal experience with "waking up" tires except that my old RA1 dropped quite a bit after 30+ heat cycles out so I discarded them with some meat still on.
I tend not to overdrive tires so others who do will have better info on limits and longevity. I'm sticking with RA1 for now.
Im not looking to break records and I am very interested in exploring limits of less sticky tires to learn how to become a better driver - haven't tried Hankook RS3 before so likely will in 2017.
Old 12-03-2016, 02:03 PM   #94
subielife
Subaru Ambassador
subielife's Avatar
Drives: 13 BRZ 18 Silverado
Im not looking to break records and I am very interested in exploring limits of less sticky tires to learn how to become a better driver - haven't tried Hankook RS3 before so likely will in 2017.[/QUOTE].
Excellent point. At our last event of the season I had no track tires left so I ran my PSS (OEM size) for the weekend. I was amazed by how much fun I had on those tires. I had forgotten how much fun less grip was.
subielife is offline   Reply With Quote
The Following 2 Users Say Thank You to subielife For This Useful Post:
CSG Mike (12-03-2016), dp1 (12-03-2016)
Old 12-03-2016, 03:41 PM   #95
dp1
Drives: Sold
dp1 tires (reference/research/reviews)
Not to mention that you were silly fast on those too
subielife (12-05-2016)
Old 12-10-2016, 02:11 PM   #96
icybrzzz
Drives: 2015 Scion frz
Anyone hear about the new RS4 from hankook?
icybrzzz is offline   Reply With Quote
Old 12-10-2016, 02:50 PM   #97
e1_griego
e1_griego's Avatar
Drives: Many
There are no details of US market availability yet. Gonna be a while.
Old 12-10-2016, 04:36 PM   #98
icybrzzz
The person that showed me this photo I believe said this was an announcment made by hankook Canada...
NT-01 or R888 ?? Summer Track Tire Deep Six Tracking / Autocross / HPDE / Drifting 22 03-04-2015 02:35 AM
Autocross to Track Day Transition "Dive bombing a tire wall" Rickapl Tracking / Autocross / HPDE / Drifting 13 07-27-2014 10:40 PM
Autocross to Track Day Transition "Dive bombing a tire wall" Rickapl Off-Topic Lounge [WARNING: NO POLITICS] 11 07-15-2014 10:05 PM
New Tire Choices Lunatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 06-30-2014 03:31 PM
Best $100 Summer Tire in 225/45/17 Black Tire Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 14 03-07-2013 06:22 PM
