Old 11-25-2016, 02:45 PM   #1
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Drives: Heavily Modified FRS
Hoodpins are they nessesary??
Hello all. Are hood pins necessary with a aftermarket carbon hood? I don't like the look of them (even the flush ones) but I rather not have my hood fly off while I am driving. Safety first
Old 11-25-2016, 02:48 PM   #2
jvincent
jvincent's Avatar
Does the carbon hood as flush against the seal as the OEM hood when latched?
If yes, then I'd say you're good to go.
If the seal isn't tight and if you are tracking it at high speed then YMMV.
The Following User Says Thank You to jvincent For This Useful Post:
go_a_way1 (11-25-2016)
Old 11-25-2016, 03:05 PM   #3
LOLS2K
/scion
LOLS2K's Avatar
Drives: '13 86 M/T
yes.
"Practice makes better. Only Senna is perfect." - CSG Mike
LOLS2K is offline   Reply With Quote
The Following User Says Thank You to LOLS2K For This Useful Post:
Old 11-25-2016, 03:06 PM   #4
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
It sits lower into the seal then then OEM one did. It also has vents so the pressure difference should be minimal but today at high speed (it was very windy) I could see it shaking and those stoppers are maxed for height. It laches nicely but I am not sure I trust it
Old 11-25-2016, 03:08 PM   #5
ls1ac
ls1ac's Avatar
hood pins are meant for racecars that have no other holding mechanism.
they became popular in the sixties to make the car look racy.
if your hood has the stock two part latch then the answer is no.
the only caveat would be if the hood is meant for racing and has poor structural support and flexes so much that the latch can become disengaged or the sides rise up at speed, them yes.
The Following 3 Users Say Thank You to ls1ac For This Useful Post:
go_a_way1 (11-25-2016), Tcoat (11-25-2016), Ultramaroon (11-25-2016)
Old 11-25-2016, 03:23 PM   #6
This. ^ All of it.
Your bigger concern should be the total lack of any form of buckle/breakaway zones in that hood. You get in a frontal crash you better duck fast or go a way will become gone a way in a hurry!
See how the stock one bends?
Yours won't!
go_a_way1 (11-25-2016), Milotic (12-11-2018), Ultramaroon (11-25-2016)
Old 11-25-2016, 03:30 PM   #7
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
This. ^ All of it.
Yours won't!
Mhe car is already so unsafe atleast this will be a quick way to go
Tcoat (11-25-2016)
Old 11-25-2016, 03:31 PM   #8
But so so messy!
go_a_way1 (11-25-2016), Ultramaroon (11-25-2016)
Old 11-25-2016, 03:36 PM   #9
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
But so so messy!
Yeah I should really be more considerate of the people who are going to have to remove my decapitated body from the wreckage before they can take a photo of another totaled team lava twin
Old 11-25-2016, 03:43 PM   #10
new2subaru
Weight Weenie
Drives: 15 FR-S
[ame="https://www.youtube.com/watch?v=xJJxVcPIc7I"]Why You Need Hood Pins - Presented by Andy's Auto Sport - YouTube[/ame]
I would probably use them.
The Following User Says Thank You to new2subaru For This Useful Post:
Old 11-25-2016, 04:04 PM   #11
jvincent
jvincent's Avatar
The OEM hood has a lot of shake at track speeds too.
Unless it flexes to the point of unlatching, you are probably fine. OTOH if it comes off it will be spectacular.
Old 11-25-2016, 04:21 PM   #12
funwheeldrive
I have always been told to use hoodpins on lightweight hoods, even if they have an OEM latch mechanism.
I would never run without pins.
The Following User Says Thank You to funwheeldrive For This Useful Post:
Old 11-25-2016, 04:31 PM   #13
go_a_way1
Not Bаnned Anymore
go_a_way1's Avatar
Okay good to know. it doesn't flex much at all just shakes and lifts a tiny little bit.
hood weighs more then OEM as its wet carbon
Old 11-25-2016, 04:37 PM   #14
new2subaru
Weight Weenie
Drives: 15 FR-S
[ame="https://www.youtube.com/watch?v=VUM4GO8biR8"]Flying hood of car - Car crash compilation - YouTube[/ame]
I've had this happen to me with a steel hood on the highway.
It blocked the entire windshield. What a ride!
