#1877 | |
Drives: is300
| The Following User Says Thank You to bshown For This Useful Post: | shiumai (11-25-2016) |
#1878 | |
Drives: 86
Haven't gotten to test it with the AC running, but after installing the Delicious D box and flashing their Edelbrock specific tune I haven't had a single part throttle hesitation. Further more the throttle pedal feels more natural, and the power delivery is smooth and robust. Highly recommend their tune. Only problem now is I have the itch for e85. The stock rods are safe at 330whp right?
| The Following 2 Users Say Thank You to Colin86 For This Useful Post: | shiumai (11-25-2016) |
#1879 | ||
Drives: 2013 DGM BRZ, 2020 C8 Corvette
My DGM BRZ vid: https://www.youtube.com/watch?v=0OL9OhxexAA
My car journal thread: http://www.ft86club.com/forums/showthread.php?t=43402 |
#1880 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: |
#1881 | |
Drives: 2016 BRZ
So it may be all related to the edelbrock instake system. I believe Edelbrock need a V2 design of the intake system, so these issues can be aliminated without having to mess around with the tunes. We just need more users to post here, with these same issues. The people are edelbrock are very good, and constantly monitor these forums. But enough of us have to stand up and point out the issues.
#1882 | |
Drives: is300
| The Following User Says Thank You to bshown For This Useful Post: | paiceyfan (11-28-2016) |
#1883 | |
Drives: 2016 BRZ
#1884 | |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
Seems to not like it when I give it gentle throttle to maintain cruising speed as road incline changes. I've watched my IAM's drop as low as .25 during this time and you can really feel it pulling timing. If I change my driving style from steady throttle, civilized mode to accelerate/decelerate mode (you know the type, can't keep the throttle in one place, piss you off when you ride with them mode), I do not have the problem. |
#1885 | |
Edited to add: If anyone else is experiencing the same hesitation issue with the CARB tune, please do some logging and send the data to Edelbrock so they can take a look at it. Right now, they do not have enough data to identify the issue.
My car journal thread: http://www.ft86club.com/forums/showthread.php?t=43402 Last edited by shiumai; 11-28-2016 at 02:05 PM. |
#1886 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | BirdTRD (11-28-2016) |
#1887 |
Drives: FRS
What guages do you guys recommend for this kit?
#1888 |
I'm using a p3cars vent gauge mostly for temps.
#1889 |
sleep, drive, eat, repeat
Drives: '13 BRZ, '12 Outback
What exactly are you trying to monitor? Temps? Boost? I mostly look at oil temps so I just monitor using torque app since gauges are a bit "rice" for my taste.
I did look into monitoring oil pressure and boost at one point and was leaning towards the defi gauges and cravenspeed flexpod for a nice clean look. Yes, the p3cars vent gauges are also a good option if you don't want to use an app. If you opt for the pre-installed vent option, it is literally plug and play. |
| The Following User Says Thank You to BigFatFlip For This Useful Post: | kidgogeta (11-28-2016) |
#1890 |
Drives: 2016 BRZ
I suggest you get an OBDII reader with bluetooth, that way you can use your phone, and you can place it on one of those belkin style mounts on the left air vent. I get my engine oil temp, IAM temp, coolant temp, and air volume intake.
It's much better than having any additional gauges on dashboard or A pillar. First, if you put gagues on A pilar, you will die if you crash as there is an airbag that will shoot the gauges onto your face. And if you get pulled over, cops can see your gauges wherever you put them in your dash, and plus you have to mod your dash, by either removing air vents, making holes on the dash, and needless mods like that. There's absolutely no need for actual physical gauges. I mentioned cops, because at least in California if they see u got those gauges it is enough for them to claim reasonable suspicion and force u to open the hood, and then ur done for modifying your car, if ur stuff is not CARB certified. |
| The Following User Says Thank You to GT86Asia For This Useful Post: | kidgogeta (11-28-2016) |
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 10:09 PM |
