Old 11-20-2016, 08:49 PM   #15
Originally Posted by Calum View Post
The tune is also different. They could have gotten that much from tuning alone.
Yep. (and tune was in my list).
A lot of things changed to get that 5HP gain so not sure why so many seem to think that manifold is some magic bullet they just bolt on and make huge gains.
Calum (11-21-2016), Cole (11-20-2016)
Old 11-20-2016, 08:50 PM   #16
churchx
churchx's Avatar
Drives: 2014 GT86
Yet even for MY2017 they still have constraints to have tune conservative enough to deal with crappy fuel world-wide. No wonder if they played it safe this time too.
Old 11-20-2016, 09:23 PM   #17
Lantana frs
Drives: 13 frs red
Imo there is some significance to the the area of the torque dip. Might be a happy spot for the motor that needed to be suppressed to meet noise/emissions requirements. Other than that, they spent a lot for a meager overall gain. Probably speaks to the stringency of standards that needed to be met. At least the new manifold wont inflate under high boost.
Lantana frs is offline   Reply With Quote
The Following User Says Thank You to Lantana frs For This Useful Post:
slow15frs (12-01-2016)
Old 11-20-2016, 10:12 PM   #18
CSG Mike
CSG Mike's Avatar
The majority is from a revised header design.
Old 11-20-2016, 11:22 PM   #19
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Kind of an odd question, but is this new manifold's part number the same as a boosted applications? If so... im betting it was a cost saving measure long term for subaru to use across all their "f" series motors.
The Following 2 Users Say Thank You to Summerwolf For This Useful Post:
Drakiv (11-21-2016), Tcoat (11-21-2016)
Old 11-21-2016, 12:17 AM   #20
lowlevel
Drives: 2017 Toyota 86
Not sure either.. my gut says the plastic is actually better for NA/stock.. but I do like red.
lowlevel is offline   Reply With Quote
Old 11-21-2016, 06:27 AM   #21
Calum
That Guy
Drives: 2013 asphalt FRS MT
Damn, missed that.
The Following User Says Thank You to Calum For This Useful Post:
Tcoat (11-21-2016)
Old 11-21-2016, 04:38 PM   #22
wparsons
wparsons's Avatar
IIRC, the turbo engines use tumble valves still, so I doubt it's the same part.
flickr
Old 11-21-2016, 05:45 PM   #23
CSG Mike
CSG Mike's Avatar
correct, the DIT has a TGV, similar to the EJ.
wparsons (11-22-2016)
Old 12-13-2016, 10:14 AM   #24
bem75
Round 3 Racing
bem75's Avatar
Drives: Scion FR-S race car
Has anyone tested this with FI? What are thoughts on this in a racing application, FI, with lots of heat under the hood? Heat soak has been a big issue for me.
bem75 is offline   Reply With Quote
Old 12-13-2016, 12:00 PM   #25
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
Does the orig plastic intake manifold have a history of breaking? The Genesis Coupe 2.0T was plastic and had a bad rep for breaking at the gasket even at stock boost (which is still 18 PSI). But I don't recall reading about too many Twins blowing up intake manis.
As for the red... c'mon, we all know that was done so you'd know that YOU have the upgraded engine.
guybo is offline   Reply With Quote
Old 12-13-2016, 01:42 PM   #26
driggity
Drives: Silver Coupe with a Boxer
Are the TGV integrated into the manifold? I know that at least on the old EJs they sat between the manifold and the heads.
Subaru has been using plastic intake manifolds on factory turbo cars since at least 2005 and I think they've been very reliable. I don't remember hearing about any failures when I had my 2005 Legacy GT. That being said I don't know if the intake manifold on the twins is manufactured in the same way and is the same material.
driggity is offline   Reply With Quote
Old 12-13-2016, 02:02 PM   #27
gramicci101
Off Topic
The only issues Subaru has had with plastic on factory turbo cars has been the plastic intercooler end tanks separating from the metal core on Legacy GTs under high (not OEM) boost levels. And even then it's more of an urban legend that started after a few failures.
Old 12-13-2016, 04:18 PM   #28
CSG Mike
CSG Mike's Avatar
It's sandwiched in.
2017 intake manifold oldgunfan Engine, Exhaust, Transmission 27 02-15-2017 04:48 PM
FBM Intake Manifold Fonzi Engine, Exhaust, Bolt-Ons 1 03-11-2016 07:36 PM
Intake manifold dallenj Engine, Exhaust, Transmission 0 11-02-2015 02:56 PM
Intake manifold viking Engine, Exhaust, Transmission 6 09-23-2014 11:08 PM
Aluminium intake manifold? Hempo Engine, Exhaust, Transmission 18 06-27-2013 01:19 PM
