Old 11-21-2016, 12:24 PM   #2339
johan
Drives: '14 981CS, '99 NB1
STi front lip and LED DRLs. Car is still on jack stands, hence the 4x4 look.
Was able to buy the front lip through my local dealer, they had it in their warehouse so I got it the next day after ordering. LED DRLs I got through FT86 Speed Factory.
No instructions available for installing either of these. Had to wing it. I took a lot of pictures of the STi lip install and hope to put together a DIY on it.
johan is offline   Reply With Quote
The Following 3 Users Say Thank You to johan For This Useful Post:
Drambeenie (11-21-2016), funwheeldrive (11-21-2016), kuczynskika (11-21-2016)
Old 11-21-2016, 12:38 PM   #2340
Drambeenie
Drambeenie's Avatar
Drives: Black 17 BRZ LT MT PP
This looks great. Did you paint it black? The left one looks silver. Also, did you paint your headlights?
Drambeenie is offline   Reply With Quote
Old 11-21-2016, 01:12 PM   #2341
johan
No painting, just the lighting / potato camera on my iPhone.
Old 11-21-2016, 01:27 PM   #2342
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Very nice!
Old 11-21-2016, 02:16 PM   #2343
kuczynskika
kuczynskika's Avatar
Drives: Harrop TVS86 STi BRZ tS
Are your FT86 DRLs functioning? How did you wire them? How bright are they? Pictures? I am curious how the wiring will work since I am contemplating a 17bumper retrofit on my 14.
kuczynskika is offline   Reply With Quote
Old 11-21-2016, 02:38 PM   #2344
johan
Are your FT86 DRLs functioning? Yes.
How did you wire them? I tapped the existing DRL wires on the driver side headlight. I used a standard T-style wire tap on the red and black wires. The colors likely won't help you though as the wiring to the headlights is slightly different on the '17s. I just used a multi-meter to figure out which wire got power when I wanted power. On the '17s the boomerang is always on, so I tapped into the boomerang wiring.
Pictures? I haven't taken a lot of pix yet, but here's a functional one from last week - before I added the STi lip.
The weather has been shit on the days that I've had the car running. Somehow I'm always working on it on the days where it's nice outside.
Old 11-21-2016, 02:48 PM   #2345
kuczynskika
Excellent, excellent, thank you! I figured there would have to be some sort of cutting and splicing. Those look nice and bright. Great job.
Old 11-21-2016, 03:27 PM   #2346
johan
No problem.
This is the connector I used:
For the tapping, I de-pinned the connector on the wiring harness they give you, and then cut off the pins and put the flat end connector on the ends of the wires. This gives me an easily reversible install if I ever wanted to remove them.
They give you a bunch of zip ties / square adhesive blocks for the zip ties, that made it easy to run the harness along the radiator support. I just pulled off the top of the plastic radiator shroud and front of the intake to make it easy to access. I then zip tied the harness on either side to the fog light wiring to keep it localized to where I wanted it.
The Following User Says Thank You to johan For This Useful Post:
Old 12-28-2016, 01:54 PM   #2347
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
http://www.subaru.jp/tas2017/
krayzie is offline   Reply With Quote
Old 12-28-2016, 02:08 PM   #2348
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Originally Posted by krayzie View Post
I'm gonna post this and tell everybody it's the new Turbocharged BRZ STI and watch people freak the f*ck out over it on social media
The Following 4 Users Say Thank You to TylerLieberman For This Useful Post:
Jfheisenberg (12-30-2016), johan (12-28-2016), krayzie (12-28-2016), vh_supra26 (01-12-2017)
Old 01-12-2017, 08:17 PM   #2349
DSOmegaX
DSOmegaX's Avatar
http://sp.subaru.jp/tas2017/lineup/detail_6.php
Nothing new in terms of parts. Just some of the already available items adapted to the 2017.
@dsomegax.cars
Old 01-12-2017, 08:22 PM   #2350
kuczynskika
meh... same shit... move along folks.
Old 01-13-2017, 08:04 AM   #2351
krayzie
Drive From Home
krayzie's Avatar
I think their new direction now is to make STI Sport into a new Subaru standard trim level for all of their cars just as I suspected all along. Another step closer to worldwide export.
Old 01-13-2017, 09:13 AM   #2352
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Not impressed on the updates.
it sucks to be broke, sti omg!
WTB: Parts for my FR-S hyperpunx Interior Parts (Incl. Lighting) 1 03-05-2013 05:28 PM
[Group Deals] SoCal Subaru BRZ parts or Any Parts Giccin Southern California 25 08-26-2012 10:30 AM
