Old 11-20-2016, 09:27 PM   #7645
PitViper
PitViper's Avatar
Drives: 2013 Scion FRS Limited Edition
Originally Posted by riboyster View Post
Does anyone know if there's a billet aluminum 69mm pulley? I can definitely feel the mass difference between steel 69 and raceseng 72.5.
Custom made from a shop that already makes pulleys, would be your best option. Non stop tuning would be a good place to start.
Sent from my LG-H910 using Tapatalk
PitViper is offline   Reply With Quote
The Following User Says Thank You to PitViper For This Useful Post:
riboyster (11-21-2016)
Old 11-21-2016, 11:29 AM   #7646
riboyster
riboyster's Avatar
Got distracted and bought myself a new crank pulley. Lol
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
The Following User Says Thank You to riboyster For This Useful Post:
PitViper (11-21-2016)
Old 11-21-2016, 08:42 PM   #7647
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
Originally Posted by Kodename47 View Post
The lower of the 3 is the grounding connection, it bolts directly to a bar on the engine block.
I definitely owe you a beer -- Just took a look in engine bay, and turns out that I didn't have the bolt in the bottom mounting hole at all. It was sitting on a table -- I must have missed the installation of it.
I installed the bolt and tightened the other two. Went on a drive for about 30 miles and I definitely think that did the trick! the RPM rev range is very smooth from 2k up through 4k now. The engine produces a slightly different note at times that I can notice as well and I even seem to get slightly better fuel economy (although I won't know on this for sure until I run a whole tank through). I didn't have a single instance of hesitation once the engine was warm.
I'm glad you pointed this out -- I would have never thought to check for that extra bolt! I'm going to consider this solved!
ajcarson11 is offline   Reply With Quote
The Following 3 Users Say Thank You to ajcarson11 For This Useful Post:
COO86L (11-28-2016), Kodename47 (11-22-2016), riboyster (11-22-2016)
Old 11-21-2016, 08:45 PM   #7648
PitViper
PitViper's Avatar
Same weight loss, different place. good choice.
Old 11-22-2016, 10:47 AM   #7649
nmastereal
Is that true? I lost that bottom bolt and ive been running fine for 2 years.
nmastereal is offline   Reply With Quote
Old 11-22-2016, 10:52 AM   #7650
ajcarson11
I would say it must be. I can tell a definite difference in hesitations with my car. Your ecu may be fastened to the bar on the engine block more securely that mine was.
I should also note that my car appeared to run fine with the exception of hesitations. So it's not as though that bolt makes a world of difference. Just improves issues in specific circumstances it would seem.
Old 11-22-2016, 05:53 PM   #7651
Kodename47
Kodename47's Avatar
Drives: UK GT86
I ran without mine for years too and then knocked the injector cover one day and the car started to randomly stall. Created a map to prove each injector set and when set to DI only the car wouldn't fire up or would die if it was running. Not sure if the car runs any better but it's a purer grounding source so in theory could do. I actually found that on putting it back on was easier than I remember, you just have to find the angle your arm goes in best and just use a ratchet spanner once it's in by hand, rather than a socket set.
I would guess that if done tight the top 2 would either ground via the injector covers or hold it tight enough against the bar on the block, if the latter then you could be running worse due to poorer grounding.
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-22-2016, 09:21 PM   #7652
stockysnail
Just the tip
stockysnail's Avatar
Now I'm curious to know if I have the bolt. Does anyone have a picture of which spot the bolt is that we are talking about?
Old 11-23-2016, 06:59 AM   #7653
Kodename47
Kodename47's Avatar
Drives: UK GT86
The plugs would be at the rear, so the lower bolt is the one on the left. Here it is in the bay. You can get much easier access by removing all the loom from it and then have room to get your hand in.
I guess most people don't disconnect it and just move it to one side which is why it seems a pain to put back in.
.: Stealth 86 :.
Kodename 47 DJ:
stockysnail (11-23-2016)
Old 11-23-2016, 08:49 AM   #7654
steve99
Drives: FT86
if you could not get to bolt maybe running a dedicated ground wire to that point of the DI computer would work
Old 11-23-2016, 12:40 PM   #7655
nmastereal
I literally was like, I hated taking this bolt out and putting it in. I am just not going to do it. Wonder if adding a ground would help any stutters.
Old 11-23-2016, 12:41 PM   #7656
nmastereal
Thats a pretty dumb design if the mounting was the ground instead of the billion wires going to the ecu having a ground.
Old 11-23-2016, 01:03 PM   #7657
Kodename47
Kodename47's Avatar
Drives: UK GT86
It's fairly common practice, just about everything is grounded to the engine or chassis and therefore it will be designed as such. If there was an additional wire it would just be connected to one of those so cut out the unnecessary and bolt it direct. Saves on costs of additional wiring.
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-23-2016, 02:20 PM   #7658
ajcarson11
Fellas it honestly took me 40 seconds to find the bolt, reach down and screw the bolt in. It took me longer to find my 10mm socket. Instant relief.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
