Old 11-18-2016, 04:45 PM   #29
GrimmSpeed
GrimmSpeed's Avatar
Drives: '13 BRZ, '12 WRX
Send a message via AIM to GrimmSpeed Send a message via MSN to GrimmSpeed
I would have thought that the net length of the runners is about the same. Short JUN runner plus blocks equals same length. I am not disputing the graph, I just don't understand how the result has been achieved.
Knowing the diameter of the runners would be important to make this comparison, but just visually we can assume they are similar.
But the length of the runners on the JUN manifold appear to be around 4 inches shorter than the OEM manifold. And the "powerblocks" are only about an inch tall, so the net change isn't a wash, it is still a substantially shortened runner which may explain some of the top end gains.
Chase
Engineering
GrimmSpeed is offline   Reply With Quote
The Following User Says Thank You to GrimmSpeed For This Useful Post:
Captain Snooze (11-18-2016)
Old 11-18-2016, 05:43 PM   #30
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Thank you. I can sleep tonight.
Old 11-18-2016, 06:33 PM   #31
Tokay444
The intake with spacers makes more power in the same rev range.
Old 11-18-2016, 11:03 PM   #32
stevo_12v
Drives: Mazda MX-6 Turbo, Toyota GTS86 37J
Some pics I forgot
JUN Instruction Manual
Closeup of the goodies
HKS Racing Single exit
Picked up the car this morning. Car definitely loves being in the higher RPM range. Power doesn't taper off as it used to in the higher revs.
stevo_12v is offline   Reply With Quote
The Following User Says Thank You to stevo_12v For This Useful Post:
Hyper4mance2k (12-13-2016)
Old 11-19-2016, 06:11 AM   #33
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
This intake manifold is designed for a high revving NA engine. You'll need to build now the engine with their forged aluminum piston kit and their rods. The pistons are build in Capricorn Germany and they increase the compression ratio to 13.0:1. I am sure that after the engine build, you'll have the strongest NA build running on pump gas. Forget all these guys trying to build such a car the last 3-4 years. They're just promising all these years and still have nothing.
Btw., I don't agree to install a turbo. Your changes are focused more for a NA setup .
The Following User Says Thank You to nikitopo For This Useful Post:
stevo_12v (11-19-2016)
Old 11-19-2016, 12:12 PM   #34
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
No, I am totally lost.
Photo shows a positive gain in the power curve. Win.
BUT as @x808drifter and @churchx says, and the part that messes with my head, I would have thought that the net length of the runners is about the same. Short JUN runner plus blocks equals same length. I am not disputing the graph, I just don't understand how the result has been achieved.
Let me clarify.
The powerband didn't change at all, the shape is identical. It just moved up in the rev range. That is all.
Peak torque didn't appreciably change, I don't have to see the graph to know that. Again, it shifted it higher in the rev range, and the power gains are proportional, because power = torque x speed / constant.
JUN runners are very short. Add blocks, they are still shorter, just not super short.
I'd bet money, if you pulled the blocks, peak torque would move up another 300-400 RPM, and peak power would follow it on up.. Shorten the runners, the powerband will move up again, unless the plenum volume or throttle diameter becomes insufficient. That will eventually kill torque. You can't push it up forever.
They didn't show the torque curve, but here's the relevant point:
OLD peak power: 190 @ 6400 RPM
OLD peak torque, calculated: 155.9 ft/lbs
NEW peak power: 201.9 @ 6700 RPM
NEW peak torque, calculated: Drumroll please.... The very same 155.9 ft/lbs
The car will be faster, reflected in the peak power increasing, but torque didn't change.
I'm thrilled with the outcome of this experiment. Thanks OP, enjoy your money well spent. Yes, the HP/$ ratio isn't stellar, but there's something special about NA power, especially since nobody else has been successful in making much of it.
Originally Posted by Spartarus View Post
If max VE, and therefore max torque, stays the same, but moves higher in the Rev range, the percent increase in horsepower will be proportional to the percent increase in RPM for peak torque, because of how horsepower is calculated.
It's not magic, it's physics. There are rules. They are absolute. Doesn't mean they are well-understood.
If I looked only at the dyno chart, and never saw photos, I'd assert that the diameter is (near-as-makes-no-difference) identical to OEM. (Average diameter, compared by runner circumference / pi, because of shape differences... But I'd bet the number is within 5mm either way.)
I will disclaim that this is ballpark math from looking at the graph, and there may be small variations if it's done more precisely, nothing is perfect in the real world, but It's close enough to make the point.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
The Following 3 Users Say Thank You to Spartarus For This Useful Post:
Captain Snooze (11-19-2016), stevo_12v (11-19-2016), Tokay444 (11-20-2016)
Old 11-19-2016, 02:56 PM   #35
stevo_12v
Let me clarify.
I forgot to add this photo, thought I put it up, but must have been on my FB page. Has the torque marked on this
The Following 3 Users Say Thank You to stevo_12v For This Useful Post:
johan (11-19-2016), Spartarus (11-19-2016), Teseo (11-19-2016)
Old 11-19-2016, 03:28 PM   #36
Spartarus
...Just add nauseum
Spartarus's Avatar
For somebody who likes to run right up to the rev limiter, that is some fat area under the curve at the top.
Peak is off less that 2 n/m from the looks of it... less than 1 foot pound difference, so the math holds up.
The jungle below 5000 rpms is always interesting in these cars... This is a funny little engine.
If you get it to 8k eventually, hanging on to a lower gear for an extra several hundred RPM is transformative, especially if the powerband holds up.
-Spartarus
Old 11-19-2016, 05:07 PM   #37
Captain Snooze
Drives: Red Herring
Thank you for the detailed explanation.
Old 11-19-2016, 05:11 PM   #38
Teseo
Drives: frs
Man... any chance you can do video on the dyno?
Also want to see the tachometer near on 9k rpms, will be porn of NA's crew
Old 11-19-2016, 05:51 PM   #39
stevo_12v
Possibly. Thinking of changing back to my Spec-L as its alot quieter and I prefer the exhaust note. Plus I think I might be losing HP staying with the single exit.
Teseo (11-19-2016)
Old 11-19-2016, 09:15 PM   #40
GsxrMe
GsxrMe's Avatar
Drives: Late 2014 Subaru BRZ
JE has 13.5:1 pistons you might want to think about for your built NA car. Ive used them in my turbo busa and nothing but fantastic results.
http://www.jepistons.com/Catalogs/Sp...baru/fa20.aspx
I hope to see you qt 230bhp or ill be sad
2014 Subaru BRZ
FBM Turbokit: GTX3076R - ECUTEK HRI FlexFuel tune - FBM 3" Turboback Exhaust - 550cc Injectors - Walbro 485 Fuel Pump - 4bar Map Sensor - FBM Oil Pan - ACT SB7-XTSS - AMSOIL all fluids - Forester XT Oil Cooler - Cusco engine, trans mounts - Whiteline rear differential bushings - Perrin shifter bushing - Firehawk 235/45/17 - AEM Failsafe
GsxrMe is offline   Reply With Quote
Old 11-19-2016, 09:57 PM   #41
Cybmx
Drives: 2016 Hyperblue Brz
Hi Stevo, what kind of reverse light is that? Could you post a link to that light? I like it quite a lot. TIA
Cybmx is offline   Reply With Quote
Old 11-20-2016, 01:23 AM   #42
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
Are these build to handle boost or high revs? There is a difference between these two things.
Moto East / Deatschwerks Drop-in Surge Tank - tech & discussion Xero-Limit Engine, Exhaust, Transmission 42 04-27-2017 09:16 PM
Automatic Transmission Surge N1rve Issues | Warranty | Recalls / TSB 25 03-16-2016 10:58 PM
Fuel surge issue??? owenxguo Tracking / Autocross / HPDE / Drifting 1 12-22-2014 09:58 PM
SBD turbo surge?? shif7i7down Forced Induction 72 11-20-2014 09:49 AM
Automatic FRS Surge in Manual Mode N1rve Issues | Warranty | Recalls / TSB 5 02-08-2014 12:28 PM
