Old 11-15-2016, 11:03 AM   #519
Nah
Drives: 2013 Scion Frs 6mt
Lol thanks I'll try it out soon and get back with results...!
Originally Posted by Kodename47 View Post
No, that's not RPM
In the top right there's RPM#1 and RPM#2. Copy the RPM column from your map into that. That determines the RPM break points in the map for the tool. The main columns are just for the log data once it's loaded in.
Nah is offline   Reply With Quote
Old 11-15-2016, 02:19 PM   #520
Nah
So, after dialing in my cams and timing ive noticed that my my afr went from 12.5 to 13.0... right at 4k to redline. 2-4k follows commanded perfectly. I'm gonna keep playing around with it... but with the increased flow what do you guys suggest to get my AFR's back to where they should be?
Old 11-15-2016, 05:40 PM   #521
Kodename47
Kodename47's Avatar
Drives: UK GT86
Increase MAF scale or add enrichment in the fuel map.
.: Stealth 86 :.
Kodename 47 DJ:
Nah (11-16-2016)
Old 11-17-2016, 02:48 PM   #522
Nah
alright so after further fine tuning, my e85 tune is near complete thanks to wayno's base!
Anyone have any tips for tip-in... I've made the changes steve99 has recommended and have full DI in loads .1 and .2. this helped. but its still off slightly... its like a slight jerk... rpms go up and down every so slightly... then right after the pedal feels perfect.
Thank you
Old 11-18-2016, 11:19 AM   #523
Nah
Some data to look at.. any help is appreciated thanks!
http://datazap.me/u/mtb1205/1-3-gear...g=0&data=1-5-9
Old 11-19-2016, 05:23 AM   #524
steve99
Drives: FT86
looks ok
should rearly log iam and ignition advance rarther than vvt intske\exhaust
how long after flash was that log higher band ltft is 0 so maf scaling either rarly good or its not had much closed loop time in upper band
it look like it might be slightly rich but a few more miles may see negitive fuel trim and that will sort itself out
Nah (11-19-2016)
Old 11-19-2016, 09:44 AM   #525
VeilSide
Drives: GT86
What is the reason, why the Timing Compensation Per Cylinder A and B are modified and C and D not (within the linked v111.2)?
VeilSide is offline   Reply With Quote
Old 11-19-2016, 04:46 PM   #526
steve99
Drives: FT86
some cylinders may run hotter than others due engine design , coolant flow exhaust design, and hence may be more knock prone than others.
the stock maps have this as well but maybe different compensations
Old 11-19-2016, 05:20 PM   #527
VeilSide
Drives: GT86
I did not check the stock rom, but the OTS maps did not have it.
In general you are right, but is this a common rule which can be used for all the different EL or UEL (in my case) headers?
Old 11-19-2016, 05:50 PM   #528
steve99
Drives: FT86
shiv initially zeroed them all out in the base oft tunes, i think he put them back in in the latest ofh specific maps.
you would rearly need to be looking at individual cylinder knock counts to make your own specific tables, i suspect waynos are based of the ofh specific tune
VeilSide (11-19-2016)
Old 11-19-2016, 08:47 PM   #529
phrosty
You've got it reversed. Base tunes had them, OF tunes had them but reduced, and OFH-specific tune had them removed.
phrosty is offline   Reply With Quote
Old 11-19-2016, 09:40 PM   #530
steve99
Drives: FT86
ok thanks , was too lazy to look thru all the tunes, just recall they chaged it round a bit
Old 11-29-2016, 01:00 AM   #531
Nah
Love this group
Old 12-02-2016, 12:28 PM   #532
BXRCHTR
@Wayno I PMd you about the donation for the link. BTW Is there a way to do AT Launch control yet
As I lay rubber down the street, I pray for traction I can keep, but if I spin and begin to slide, please dear god, protect my ride.
BXRCHTR is offline   Reply With Quote
Help uploading 2.06 tunes to OFT Jimmy817 Software Tuning 3 12-28-2014 09:06 PM
Custom Az Tunes Juggles Arizona 13 11-08-2014 10:15 AM
EcuTek Tunes Rio Engine, Exhaust, Transmission 1 04-29-2014 12:10 AM
How long until *other tunes? ScionFrsFan Engine, Exhaust, Transmission 61 12-07-2012 05:34 PM
Speedhunters - TRD TUNES THE 86 quik1987 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 69 05-22-2012 04:26 PM
