#1849 | |
Drives: 2013 Subaru BRZ, Edelbrock SC, E-85
Yeah mine does that same fluctuation sometimes when the A/C is on. Sent from my iPhone using Tapatalk |
#1850 |
Drives: UK GT86
High cold RPM is normal, happens on the stock car to. It's for cat heating.
As for bouncing idle, sounds like the idle control needs sorting.
.: Stealth 86 :.
#1851 |
Drives: GT86 Cosworth
The ecu is probably still learning. After flashing mine a few times I have noticed it either learns really quickly and gives a steady idle regardless of turning on the a/c or loading the alternator, or it take months.
#1852 | |
Drives: 2014 Porsche Cayman S
Sent from my XT1031 using Tapatalk
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
#1853 |
#1854 |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Two months ago I stopped by CSG to flash to the CARB/EO tune, and immediately I noticed an occasional hesitation at around 4k-5k RPM under partial throttle conditions. I thought it'd give the ECU time to learn, but it hasn't gone away. It doesn't happen at WOT or the low end of throttle input; but more at 50%-70% throttle. It'll happen when i'm rolling along at 'cruising' speed (RPM around 2.5k) and push the pedal down to accelerate (not WOT) and it'll buck a bit when it hits around 4k. It doesn't happen every single time though.
It happens straight from cold through normal operating temps so from what I can tell, it doesn't seem to be very temperature dependent. I stopped by Edelbrock for them to get some logs, but it only manifested itself a few times during the drive, and we didn't see anything weird in the logs, so it seems safe to drive as is (which was my main concern). We saw it show up as a blip in RPM but weren't sure why. Anyway, I'm hoping that they'll have a chance to take a more detailed look at it (I'm wondering if other people have experienced the same issue), as it's a little bit annoying for daily driving. They've been very responsive and helpful. I'd rather keep the EO tune rather than flash back to the original one (which did not present this issue) just to keep it 100% compliant.
My DGM BRZ vid: https://www.youtube.com/watch?v=0OL9OhxexAA
My car journal thread: http://www.ft86club.com/forums/showthread.php?t=43402 Last edited by shiumai; 11-18-2016 at 09:03 PM. |
#1855 | |
Drives: 16 Brz.
#1856 | |
Only about 10-15 extra hp!! Definitely a significant difference for me considering the very affordable price point. Sent from my iPhone using Tapatalk |
#1857 |
Drives: FRS, Supra, Colorado D, GLC63
#1858 | |
| The Following User Says Thank You to paiceyfan For This Useful Post: | The Racers Line (11-20-2016) |
#1859 |
Drives: 2016 BRZ
The idle RPM oscilation is because of the Edelbrock intake design, I had the same issue, and my car actually stalled when I had the AC on and it was hot outside this past summer.
In any case, the problem was solved by about 99% with the NEW version of the Delicious Tune update tune. So I strongly advice you contact DT for a tune from them. Bill know what he is doing. There was also a small problem with the blip rpm at 4-5k rpm, and he kinked it out as well. A third problem was when taking off, sometimes it would be a bit of a rough take off with a hesitate as soon as you pressed the gas. He fixed that too. I've been driving with the edelbrock since May, with these issues, then the Delicious tuning update tune came out around June/July, and since then it's been like driving the car with stock reliability, but with power that makes mustang and gti owners cry and wonder why they wasted their money in their cars instead of a brz, haha. :-) |
#1860 |
Drives: 2016 BRZ
Oh, and forgot to mention, the rumor is Edelbrock is supposed to be working on a redesigned V2 air intake, to help with this idle rpm hesitation issues, but I haven't heard if its something that it will really happen or not.
| The Following User Says Thank You to GT86Asia For This Useful Post: | taiguy (11-21-2016) |
#1861 | |
Drives: 2013 Black BRZ Limited
#1862 |
Edelbrock E-force Owner's thread and FAQs (Frequently Asked Questions)
I'm averaging 24.5 on 91 with a heavy foot. Sent from my iPhone using Tapatalk Last edited by Silverfox; 11-21-2016 at 10:58 PM. |
| The Following User Says Thank You to Silverfox For This Useful Post: | CSG Mike (11-22-2016) |
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 10:09 PM |
