Old 11-16-2016, 02:14 PM   #267
Thehark1
Drives: '13 BRZ
Originally Posted by Gopherboy6956 View Post
Yep. Did it in my garage over a weekend. But, then again I also:
Replaced stock clutch
Replaced Radiator with bigger one
Replaced all radiator hoses
Installed an oil cooler
Installed catch cans
All at the same time, so it definitely took me longer that just the SC. I HIGHLY recommend an oil cooler if you do this.
But, overall It's really not much more than nuts and bolts. The hardest thing is routing all the plumbing for the Intercooler, just getting everything to sit in the correct place.
Ya I'd have no idea how to install oil cooler or catch cans lol. Which ones would you recommend getting?
Thehark1 is offline   Reply With Quote
Old 11-16-2016, 02:24 PM   #268
Gopherboy6956
Gopherboy6956's Avatar
Drives: 13 BRZ Limited WRB
Well, most of the oil coolers are pretty much the same - I went with Perrin because I have had such great success with all of their other products. Had it on the car for two years now and not a single leak.
Radium Catch cans have been great as well, they are VERY easy to install - it's just a bunch of tubing.
You don't really have to have any special skills to do this - just read the instructions and turn some bolts.
I plan to live forever. So far, so good.
My Build - http://www.ft86club.com/forums/showthread.php?t=31925
Gopherboy6956 is offline   Reply With Quote
Old 11-16-2016, 02:28 PM   #269
Thehark1
Drives: '13 BRZ
I guess the biggest deterrence for me at this point is living in an apartment without a garage.
Does this come with a tune? And everything I'd need to plug into the ODB port and flash it?
Old 11-16-2016, 02:36 PM   #270
Gopherboy6956
That would be a challenge. I had a full garage and all needed tools.
It does come with a base tune from Perrin along with an EcuTek license and the cable to flash it. you'll just need a laptop to perform that tune.
Old 11-16-2016, 10:08 PM   #271
Thehark1
Drives: '13 BRZ
I only have a Mac so I hope that'll work. Could you give me a rough ball park estimate of what installation of one of these would cost by a pro?
Old 11-16-2016, 10:35 PM   #272
Gopherboy6956
That, i can't help you with, I have no idea. I've always done my own work.
I do know a custom tune, which you should strongly look into after making sure everything is working correctly, could set you back $500 - $1000 depending on the tuner.
Old 11-16-2016, 10:45 PM   #273
Thehark1
Drives: '13 BRZ
No problem! Could you recommend a tuner? Or at least how to go about finding one? There are no tuners in my vicinity so it'd have to be done over the internet if possible
Old 11-16-2016, 10:50 PM   #274
Gopherboy6956
You'll want to look at this: http://www.ecutek.com/Dealers
I'm all the way in North Dakota, so I don't know any tuners (at least, in person) that I could recommend there.
sorry!
Old 11-16-2016, 11:28 PM   #275
Thehark1
Drives: '13 BRZ
sorry!
Ok thanks! Last two questions if that's ok haha.
One, have you seen this? [ame="https://www.youtube.com/watch?v=se5LVsiTfvo"]Review | Supercharged Vortech Scion FR-S BRZ Install | Part 1 of 3 - YouTube[/ame]
It's a build log of the vortech install. They run into a lot of problems with the instructions. Has this been mostly smoothed over?
Also, 69kmiles. Do you think that is too high to safely boost the car? Is there a mileage threshold that you would say it no longer makes sense to supercharge the car?
Thanks for all your help!
Old 11-17-2016, 12:15 AM   #276
Thehark1
Drives: '13 BRZ
And one more I thought of! I plan on getting EL headers (probably going EL vs UEL but not 100% sure yet). Can I run any aftermarket headers with the vortech kit?
Old 11-17-2016, 11:25 AM   #277
Gopherboy6956
Yea, i've watched all of his videos. Some is good, some is not so good. I had very limited issues in my install, in fact, I really can't recall anything other than the windshield washer fluid bottle install, it's a little tricky. My kit was a v3, and I believe he had a v2, and there were lots of improvements between the two.
I dont think there's any reason not to boost at that mileage, you might just get more blow-by, which would make the catch cans more useful.
I have had both aftermarket EL and UEL headers on my setup. I settled on the UEL Header from OpenFlash. No issues whatsoever, but it just makes one more case for getting a custom tune, as you can probably pick up more HP and Torque.
Old 02-10-2018, 09:51 AM   #278
new2subaru
Weight Weenie
Drives: 15 FR-S
Sooooooo, no owner reports in 15 months.
You either all blew your engines or things are smooth sailing!
Anyone?
Old 02-10-2018, 09:53 AM   #279
bee_are_zee
bee_are_zee's Avatar
Drives: GBS BRZ
Anyone?
It’s a pretty stout kit. I have 20k on mine currently. No issues.
bee_are_zee is offline   Reply With Quote
The Following User Says Thank You to bee_are_zee For This Useful Post:
new2subaru (02-10-2018)
Old 02-10-2018, 09:55 AM   #280
new2subaru
Weight Weenie
Drives: 15 FR-S
Can't quote you for some reason but thanks for the feedback!
STX Rules and Setup Questions Scooby South Tracking / Autocross / HPDE / Drifting 3914 07-18-2023 05:16 AM
Questions and Discussion on Vortech Supercharging Systems Brian@Vortech Forced Induction 1462 01-27-2017 03:05 PM
Vortech Offical Owner Thread cjsporl1996 Forced Induction 2 03-27-2014 01:50 AM
Who to tune Vortech setup? pheoxs Forced Induction 18 02-20-2014 03:58 AM
Sprintex or Vortech, which setup has more potential? Turbowned Forced Induction 328 09-14-2013 12:09 PM
