Old 11-15-2016, 12:09 PM   #7617
riboyster
riboyster's Avatar
Drives: 2013 Scion FRS
Originally Posted by ajcarson11 View Post
Hmm... Yeah mine is stuttering enough that's it's driving me a little crazy in traffic. The power band unless I'm wot feels like it has at least 3 consistent dips around 2400, 2800, and 3200. I can feel it in the rear Everytime it dips. Hmm...
Could be bad timing in areas. What's your IAM?
ScreamingElectron - SnakeShit
riboyster is offline   Reply With Quote
Old 11-15-2016, 12:58 PM   #7618
ajcarson11
Drives: 2013 Subaru BRZ Limited (Black)
It very well could be bad timing -- But I think Mike would have spotted if it was really rough. Here's the latest log that i've taken. Mike made a few changes since looking at this log --
http://datazap.me/u/ajcarson11/725mm...e?log=0&data=6
I'm sure a dyno-tune in person (rather than e-tune) could probably solve this. I'm just wondering if there isn't some leak i'm missing somewhere. I've got tight hose clamps on every single connection. I've sprayed electrical cleaner around all the fittings checking for rise/fall in RPM, and i've retorqued all of the bolts.
It's so close to being perfect for me -- just the dips make it a strange experience some times.
ajcarson11 is offline   Reply With Quote
Old 11-15-2016, 11:45 PM   #7619
riboyster
riboyster's Avatar
Looking at your log, you appear to be running a tad rich or lean when it happens. If I were to make a guess, I'd say its a problem with fuel injection. Your target/actual AFR is consistantly inconsistant at the RPMs you mentioned.
It's at points too lean, and at other points too rich. The fact that it riches means that you don't have a vacuum leak, and fact that it leans leads me to believe that your airflow isn't being restricted. You'll also notice that your ignition timing gets pulled pretty drastically at around 2700.
I'm thinking there's something going on with your fuel injectors. Ask Mike if they have any way of diagnostically testing them. Strange behavior indeed though. Do post the solution if you guys get a handle on it.
The Following 2 Users Say Thank You to riboyster For This Useful Post:
ajcarson11 (11-16-2016), sato (11-16-2016)
Old 11-16-2016, 04:54 AM   #7620
Kodename47
Kodename47's Avatar
Drives: UK GT86
All of this makes it unlikely to be injectors, especially if it's not happening at WOT.
Stuttering tends to be caused by either mixtures too rich or too lean to make power, especially when on part throttle as this is quite easily overlooked. This could also cause timing to be pulled, which would exacerbate the situation.
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-16-2016, 05:36 AM   #7621
riboyster
riboyster's Avatar
My money is on a fueling problem.
Too lean or rich would be broad spectrum, unless there's some sort of valve malfunction in the charger.
Old 11-16-2016, 07:51 PM   #7622
ajcarson11
The charger is indeed used -- Not sure how i'd identify a problem with it really without sending it back to Sprintex, or having it checked professionally (which is tough in my area). Mike did pull "low-load low-rpm" timing to see if it would help. I think it did help but its still quite noticeable at low and medium throttle.
Not really sure what my options are -- You'd think that if it were a valve malfunction in the charger that it would get worse with load or RPM. Injectors seem unlikely (based upon the fact that i had no issues previously). But Hm..
Old 11-16-2016, 10:17 PM   #7623
riboyster
riboyster's Avatar
Definitely strange. Did the previous user have the problems?
Old 11-16-2016, 11:02 PM   #7624
ajcarson11
Not sure honestly -- claimed to not have any issues but you can never be too sure. When I drained the fluid for the first time there wasn't a lot in the unit. It doesn't make any strange sounds or strange vibrations that I can tell.
Old 11-16-2016, 11:13 PM   #7625
riboyster
riboyster's Avatar
Man I wish I was there to feel it and figure it out with you
The Following User Says Thank You to riboyster For This Useful Post:
Old 11-16-2016, 11:42 PM   #7626
ajcarson11
It's all good -- Overall I'm definitely happy with the performance at the price point.
I'm more concerned about whether it could cause trouble for the engine over time. It feels unnatural and I can feel the car jerking at times on medium-high throttle if I go from a low-load state to a high load state quickly in 2nd or 3rd gear. If i give it strong throttle (not even WOT, but strong) from 3k on up to redline it does just fine.
The Following User Says Thank You to ajcarson11 For This Useful Post:
riboyster (11-16-2016)
Old 11-16-2016, 11:44 PM   #7627
riboyster
riboyster's Avatar
Maybe a little rough on your transmission. But if it works fine on wot then I'm thinking the low torque surges won't be too bad
Old 11-16-2016, 11:45 PM   #7628
CK_Bladesmith
CK_Bladesmith's Avatar
Drives: Raven FR-S
A good rule of thumb that I use for mine is this: Never WOT under 3k rpms. Remember these cars have garbage connecting rods that can't handle torque down low.
Raven FR-S mods: Unichip, Ground Control street coilovers with camber plates and strut tower brace, SPC Lca's, Drag DR-38 wheels with Dunlop Direzza DZ101s, Perrin CAI and silicone inlet tube, Perrin 3" resonated catback, Perrin high flow catted front pipe, Rev Works UEL header.
CK_Bladesmith is offline   Reply With Quote
The Following User Says Thank You to CK_Bladesmith For This Useful Post:
D_Thissen (11-17-2016)
Old 11-16-2016, 11:46 PM   #7629
riboyster
riboyster's Avatar
Exactly. Im glad you're aware of that.
Old 11-17-2016, 12:17 AM   #7630
ajcarson11
Certainly. I never give it more than 60-70% throttle under 3000rpm. I've read the horror stories, and I've got an early model 2013. I was nervous from the start
I'm grasping for straws here, but was looking at the log and i'm noticing that around my trouble spots (2500rpm, 2800, 3000/3100) the ignition mode changes from 2 to 3, or sometimes from 2 to 2.25 and then back down. That would be right around where the port injection comes in combination with the direct. I haven't touched the DI injectors -- Maybe I caused trouble when I reinstalled the port injectors? They were off the car for several days sitting on a table as I took my time installing the SC. Is it possible that I could have installed the seals wrong for the port injectors?
I figure i'll give the exhaust system a once-over for leaks around the header as well. I've never had trouble there, but I haven't checked for leaks in that area for a while. I do know that I have a small exhaust leak at the end of the midpipe near the muffler (had an extra resonator installed). I wouldn't imagine this would cause any trouble though.
Innovative ideas to increase interior storage capacity? swift996 Cosmetic Modification (Interior/Exterior/Lighting) 0 01-30-2013 10:45 PM
AVO vs Innovative diss7 Forced Induction 32 01-21-2013 06:15 PM
Technical topic sub-forums OrbitalEllipses Site Announcements / Questions / Issues 1 07-17-2012 11:38 PM
