Old 06-26-2012, 01:23 AM   #15
serialk11r
Drives: '06 AM V8V Coupe
Originally Posted by GirlyScions View Post
Thanks.
To clarify I did understand this was not a under drive pulley. I was just comparing under dive kits to lighter weight pulleys if the hp gains were greater in 1st gears than say 4th for a under drive kit( crank/alternator or whatever).
Ah, well accessory power should just be engine speed dependent (well, I guess it depends on how much electrical power you're using too), so underdrive pulleys should be getting gains in all gears.
Old 06-26-2012, 02:31 AM   #16
Bonburner
6/22/12-2/6/24
Bonburner's Avatar
I won't jump the gun but please keep up the work!
I'm more paranoid about keeping the full warranty in case of anything goes odd with the entirely new platform ~
I'd expect this to be good for both First AND Second gears ~
Old 06-26-2012, 11:42 AM   #17
PERRIN_Jeff
PERRIN_Jeff's Avatar
Drives: Matte Black STI
Thanks! Currently looking at the all the options of mods. I don't wanna jump the gun... yet lol
I just remembered my friend's GM8 (coupe Impreza w swapped JDM wrx engine) & when he installed both lightweight pulley & flywheel, it gave him misfire, so that's why I asked.
I bet he used an early ECU (02-04) where the misfire detection parameters are way too sensitive. If this does become a problem, ECU tuning will take care of the sensitivity and gone will be those concerns.
Warranty on a new car is important. Always keep in mind that the dealer HAS to prove the aftermarket part caused the problem. Also keep in mind that a crank pulley can't void your whole cars warranty. Same goes for exhaust systems, and all those kinds of parts. Worst case scenario they can only void the warranty of the parts they effect. This is why catbacks and most exhaust components do not effect warranty at all.
PERRIN_Jeff is offline   Reply With Quote
Old 06-26-2012, 11:54 AM   #18
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
Damn! You're dead on! I'm not sure what he do to solve the problem, but he doesn't have any problem anymore.
Anyways on-topic Please keep us updated on awesome parts you guys are making!
Old 06-26-2012, 12:24 PM   #19
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Who sells perrin parts in the province of quebec? Ups charges an arm and a leg in duties when shipping over the border unless the shipper tags it as a gift
Silverdub is offline   Reply With Quote
Old 06-26-2012, 12:36 PM   #20
PERRIN_Jeff
We have been quiet over the last couple weeks for a reason
Tuner Works is one of the dealers. Then you can also use our dealer finder as well.
CLICK HERE for the dealer finder
Old 06-26-2012, 02:35 PM   #21
milenko11
Drives: no
We have done this a couple times recently with mixed results. We have NOT done this on the BRZ yet. We have only been doing long term testing making sure there are no negative effects. Which there isn't. The next time we are on the dyno, this part will be installed and tested back to back. It may not show anything, but for sure you can feel this on the road.
This is partially why it this part is so popular on the WRX/STI engines. Its noticeable, inexpensive, and a piece of cake to install (on a manual).
I had it on my WRX and it was noticeable. That's why I want it on my BRZ. However, I need to know if I should get another belt or if the original one can be removed in tact.
milenko11 is offline   Reply With Quote
Old 06-26-2012, 03:11 PM   #22
PERRIN_Jeff
Original belt is used. Remember how easy it was on your WRX? Cut that in half, that is how much easier it is on this car. The new belt tensioner is sooooo easy to deal with!
Old 06-26-2012, 03:16 PM   #23
milenko11
Drives: no
my '11 did not have the tensioner. I didn't notice the BRZ did! Good news. I'll be ordering a pulley shortly!
Old 06-26-2012, 03:31 PM   #24
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
I just called perry auto and ordered the part!
Old 06-26-2012, 04:33 PM   #25
xcelir8brz
Drives: 2013 BRZ Limited
Perrin - I ordered one as well and it's on it's way. I have a 6AT. Mind posting the instructions here?
xcelir8brz is offline   Reply With Quote
Old 06-26-2012, 10:14 PM   #26
Philly
Philly's Avatar
Drives: Eighty Six Turbo
Hi Perrin,
I live in Toronto and saw "Nextmod" as the local dealer. Do you know how reputable this place is and if they can do a good job installing the pulley?
Would this work on my automatic?
Any other dealers I could order from?
Thanks in advance,
Phil
Philly is offline   Reply With Quote
Old 06-26-2012, 10:15 PM   #27
Enigmus
Enigmus's Avatar
Drives: 1996 Integra LS 4DR, 2013 Scion FRS
WTB DIY Article Please!
Enigmus is offline   Reply With Quote
Old 06-26-2012, 10:52 PM   #28
Silverdub
Boostin'
Silverdub's Avatar
Drives: FRS-T
Cmom guys this job is easier to do then installing a cai!
Perrin Crank Pullies now available @ Kronos! KronosPerformance Engine, Exhaust, Bolt-Ons 39 08-30-2012 12:53 PM
