Old 11-14-2016, 06:20 PM   #15
solort
Drives: Series 10 FRS
Ran an event in Huntsville yesterday after I removed my TRD springs and put car in DS trim. Was able to get within .1 sec of Nats DS champion on a 60+ sec course. Felt the car handled no differently than with TRD springs. Just an early subjective observation. And I did not drive the car to its potential.
solort is offline   Reply With Quote
Old 11-14-2016, 09:08 PM   #16
G_Ride
G_Ride's Avatar
Drives: Some kind of Subaru
Did you also have the TRD swaybars? Those probably make more of a difference than the TRD springs.
G_Ride is offline   Reply With Quote
Old 11-15-2016, 06:01 AM   #17
solort
I run a 20mm Whiteline in front on stiff and OTS Koni yellow inserts and car is just about tuned in. Never bought the rear TRD cause I did not think the car needed it. Never pushed unless I over drove car. Trophied a couple of Tours last year and Co driver won Bristol Match tour in the car. But he is an alien....
So I look forward to the diverse DS class next year...
The Following User Says Thank You to solort For This Useful Post:
CokeSlap (04-01-2017)
Old 01-29-2017, 08:46 AM   #18
Open Loop
2013 FR-S Whiteout / SSC
Question re Koni Sport Yellows
Hi everybody - I am building up my 2013 FR-S for D Street and I have a question regarding the use of Koni front replacement struts. The question relates to whether I should use Koni's complete replacement struts or the inserts. I have a good understanding of what needs to be done to use the inserts and I don't have a problem with going that route if it is best, but for the sake of convenience I am considering using the complete replacement strut if it can be done legally under D Street class specifications.
The issue is (of course) that I understand that the locating holes are bigger on the Koni complete units allowing a greater camber adjustment, particularly if using the 14mm crash bolts.
Is it legal to use the Koni complete units and the 14mm crash bolts if the camber is set within the limits that would otherwise be legal?
If I really want to use the Koni units (i.e., not inserts) what is the best course of action to stay legal within the Street classes?
Thank you.
Open Loop is offline   Reply With Quote
Old 01-29-2017, 09:14 AM   #19
Twinz
Twinz's Avatar
Drives: 2016 FR-S MT, 2015 Scion FR-S AT,
Koni offers lock-out washers that make the shocks legal for street class and will send them to you at no charge. They are not legal without them.
Twinz is offline   Reply With Quote
Old 01-30-2017, 01:05 PM   #20
TrqlessWonder
Drives: 2014 FR-S
It should also be noted that the inserts were prone to leak out through the adjusters.
-Mike
#24 CS/CSR
TrqlessWonder is offline   Reply With Quote
Old 01-30-2017, 02:59 PM   #21
MarkR171
MarkR171's Avatar
Drives: '05 Elise
Just buy the full replacements and call/email Koni to send you the mount inserts (required to be DS/CS legal) when you order the struts. They responded to my email within 10 minutes and sent the inserts very quickly.
'05 Lotus Elise
'19 BMW M2C
'22 Subaru WRX
ex '15 Scion FR-S
MarkR171 is offline   Reply With Quote
Old 02-01-2017, 01:21 PM   #22
nico_rsx
Drives: BRZ 2017 Pure Red, MT
The 2017 SCCA rules and classification are out, but the 2017 BRZ/86 are nowhere to be found in street class. But they are there in STX!
Also the other 2017 cars are in Street.
I don't understand. I'm buying a 2017 in a couple months, will I be in C or D, or is the 2017 not elegible in street, only in STX?
This make no sense.
https://www.scca.com/pages/solo-cars-and-rules
https://www.scca.com/downloads/19210...asses/download
Edit: I sent an email to the SEB asking them to class the 2017 twins in street. I'm not a member, so not sure if they'll consider my letter, but it's worth a shot.
nico_rsx is offline   Reply With Quote
Old 02-01-2017, 05:33 PM   #23
renfield90
The Stig's German cousin
This make no sense.
Probably an innocent oversight, but a pretty disappointing one, especially for those parts of the country that have already held events under the new rules.
My guess is that the 2017s will continue in DS unless they have TRD parts. The update is incremental and not all that game changing; your gearing will make you accelerate a bit better at the cost of shifting more. Just beware, since the model has changed, they could change the classing at any time via the 12-month rule.
I had knee surgery today, so sometime tomorrow I will be editing the first post with my pass at the DS parts bin. I will probably leave some parts out if I don't know about 'em so once that's up, feel free to contribute and I'll keep updating that post!
The Following User Says Thank You to renfield90 For This Useful Post:
nico_rsx (02-01-2017)
Old 02-01-2017, 08:03 PM   #24
G_Ride
G_Ride's Avatar
I could see the 2017s in CS. They do have a larger rear sway bar. There is also the 17x7.5 wheels some of the models can get.
The Following 2 Users Say Thank You to G_Ride For This Useful Post:
DaWorstPlaya (02-19-2017), strat61caster (02-01-2017)
Old 02-01-2017, 11:28 PM   #25
Shneegle
Shneegle's Avatar
Drives: 2013 FRS, 2024 Trueno
I would agree that the 2017's at least with the Subaru performance package or TRD package would be in CS.
I could see the normal 2017 cars without those to just be in DS with all the others.
Shneegle is offline   Reply With Quote
Old 02-02-2017, 02:42 AM   #26
G_Ride
G_Ride's Avatar
I could see that split too.
Old 02-02-2017, 06:13 PM   #27
renfield90
I've been too loopy to do much of anything useful today. Maybe tomorrow.
Old 02-03-2017, 12:01 AM   #28
solort
I hope you are recovering well from your knee surgery. I hear rehab is the key and not a lot of fun.
I am recovering from back surgery last Thursday. Hope to be released before the Dixie Tour. But I think DS will be interesting and course dependent with the WRX and Mustang Turbo thrown in. CS is looking very NDish...
renfield90 (02-03-2017)
SCCA Solo Street Modified (SM) Discussion whataboutbob Tracking / Autocross / HPDE / Drifting 61 07-27-2020 10:03 AM
SCCA Solo C Street Discussion Kido1986 Tracking / Autocross / HPDE / Drifting 4831 07-08-2020 03:52 PM
Gen3MR2's C Street (SCCA SOLO) Progress Gen3MR2 Tracking / Autocross / HPDE / Drifting 0 02-12-2016 01:02 PM
2014 SCCA Solo Nationals/Pro Solo Finale thread edj Tracking / Autocross / HPDE / Drifting 206 09-19-2014 11:34 AM
Henry's C Street (SCCA Solo) progression Kido1986 Tracking / Autocross / HPDE / Drifting 74 05-04-2014 08:20 PM
