Old 11-07-2016, 08:34 PM   #4243
Apex_BRZ
Drives: 2013 Subaru BRZ Limited (WRB)
Originally Posted by dp1 View Post
What size rims/tires do you want to run
I have Enkei RPF1 wheels, OEM diameter/width. I'd like to stick with the tire size I've been using, which is 225/45/17.
Apex_BRZ is offline   Reply With Quote
Old 11-07-2016, 09:25 PM   #4244
dp1
driving smoother faster
Drives: Sold
That size tire fits best on 17x8 rim though it works with stock also. Rim in RimWidth size recommended by tire manufacturer (usually the middle of three numbers for min-measured-max) or a little wider than measured usually works best for optimal tire feel.
Check out some common options at http://www.ft86club.com/forums/showthread.php?t=84188
Look into Nitto NT01 and Maxxis RC-1 for dry and Dunlop Direzza Z2 for dry and wet, aside from what you tried. Common wet choices are Michelin PSS and Conti DW, neither as good in the dry as RE-11 or RE-71R.
dp1 is offline   Reply With Quote
Old 11-07-2016, 09:32 PM   #4245
Apex_BRZ
I work in the tire industry, so I'm very particular about choosing the right tire size and wheel combo. But that was 3 years ago and I have no idea what they even are at this point. The tires fit and wear perfectly.
I'm aware of the options, but looking for solid feedback from firsthand experience. I didn't think the NT01's were any better than the RE-71R or RE-11, they've been around quite a while. Have you actually used all of those tires on the track? What are your thoughts about how they compare to each other?
Also, really looking for feedback on R-Compounds like the Toyo R888 as well.
edit: Reading through the link, thanks...
edit 2: Looking a lot harder at the NT01's. I think the Maxxis RC-1's are out, as they might be a little too extreme and the car will see rain. I guess it comes down to how many track days I could get out of them. The RE-71R's wore down VERY fast.
Old 11-07-2016, 10:41 PM   #4246
dp1
Drives: Sold
Got a track related question? I'll try to answer.
Cool, so you should be in the know...
My experiences:
- Toyo Proxes R888 like specific pressures and wear unevenly if they are outside the camber/pressure "happy place" - only tried them on Lotus Elise. Very good compound but never again since Toyo RA1 and Nitto NT01 and Maxxis RC-1 are available in our sizes. Some swear by them so take my comments with a grain of salt.
- Nitto NT01 were awesome - they provide very good stick and allow for some serious hooning without loosing it. They will wear if pushed hard. This tire may save you where you should not be saved
- Toyo Proxes RA-1 work very well for me. Wear like iron and behave predictably at the limit. Great for rain when new and get faster in dry as they wear. Likely will heat cycle out before they wear out.
Heard that Maxxis RC-1 like clean lines and require some skill to keep in check at the limit if driver is not smooth. I see that as a great learning tire for advanced driving with plenty of tread and without crazy stick that hides many mistakes. Similar performance in hot temps as NT01 but faster in colder temps. I will get them for next season in 235/40-17 on 17x9 rims.
Old 11-07-2016, 10:46 PM   #4247
dp1
Drives: Sold
Don't expect too much from NT01 in the rain, even when new
Old 11-07-2016, 10:46 PM   #4248
zdr93523
zdr93523's Avatar
Drives: 2013 BRZ Limited
The Maxxis are great dry tires, equivalent to the NT01 and they wear extremely well. Beyond that, you're looking at a BFG R1 or something way more aggressive. In the wet, I highly recommend the Pilot Sport AS3. They're newer tire tech than the super sport and much better in the wet. You can daily those and use them as your wet track tires.
Instagram: @zdr_93523
Youtube: https://www.youtube.com/user/zdr93523
Pink Ribbon Racing 2013 BRZ Limited NASA ST2 and TT2 race car
www.makesmodels.com
www.camautomag.com
zdr93523 is offline   Reply With Quote
Old 11-07-2016, 11:04 PM   #4249
CSG Mike
CSG Mike's Avatar
If you write off the RC1 for rain use, you sh ould also write off the NT01. Those grooves won't do anything to evacuate water.
RA1 is your answer.
Old 11-07-2016, 11:06 PM   #4250
Apex_BRZ
Awesome, thanks guys! The car will see rain, but I think they'll be good enough. I have a lot of experience with my other car in heavy downpours and very wide R888's. Seemed to do "good enough". Still something to consider though. Any word on the newer R888R's yet?
The Maxxis RC-1 really sound great, but I can't see going with those. They really look like slicks with a couple grooves cut in them. I mean, there is no design at all for water evacuation where the other tires at least have a chance. While I hold a line really well and am a very smooth driver, I'm still learning and can make mistakes. They might be more than I'm looking for right now.
Maxxis RC-1
Old 11-08-2016, 05:28 PM   #4251
Prmspen
Student Driver
Prmspen's Avatar
Drives: 2016 Subaru BRZ Limited
Somewhat off topic, but do you have a recommendation for a good home racing simulator setup? Looking to spend in the hundreds (low hundreds if possible), not the thousands.
Prmspen is offline   Reply With Quote
Old 11-08-2016, 05:43 PM   #4252
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Logitech will get you the most for the money, particularly if you're on a budget and not getting really serious into it yet. G920 for PC/Xbox One or G29 for PS3/PS4/PC will both run you right around $300.
Thrustmaster would be a step up in quality, but also price. Wheel/pedals are sold together, but the shifter is a separate purchase.
Then of course there's Fanatec, but you're wayyyy over budget there.
I use the G920 for FM6, DiRT, and iRacing (the occasional times I decide to temporarily renew my subscription for a month) Built a pretty sweet setup for it too.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 11-08-2016, 05:49 PM   #4253
OkieSnuffBox
Drives: '23 BRZ Limited
What do you want out of the simulator? Fanatec seems to have dropped their more entry-level, you might look around and see if you can find a retailer with old stock.
Even their Porsche GT2 wheel and pedals, I thought, felt noticeably better than G27 setup.
And for about $75 more.
But I also ran iRacing on 3 27" monitors. But I believe iRacing now has some support for the Occulus Rift.
Asseto Corsa, etc, all suck as racing sims but are more "fun." iRacing has much more realistic physics, but aren't as pretty.
Old 11-08-2016, 06:20 PM   #4254
ysu
Drives: Toyota 86 GTS Auto
Highly debatable. Lots of people say (me included) that AC is actually a better representation of realism than "iceRacing". I've played both, extensively (years and years) along many others. Got up to 'A' licence in iR, nearly pro (my last race was a disaster when I went for it) Both are approximations of reality; nobody has worked out a full, 100% simulation for tyre physics as of yet.
But in iR I had to learn to predict; you cannot really react. By the time you'd react it's too late. AC is more forgiving; you can react & correct. iR is inherently more oversteery - every car wants to spin - whereas AC seems more neutral, even understeery ( but most tin-tops should be that way out of the box ).
iR is also a _lot_ more expensive (read: about 10 times or more), and what you get for your money is not much IMO, unless you want to seriously compete online with random people. Organised leagues exist for AC as well.
Toyota 86 GTS A/T, ACE 250/B header + OP, Apexi air filter, Whiteline camber bolts
ysu is offline   Reply With Quote
Old 11-08-2016, 07:08 PM   #4255
Prmspen
Student Driver
Prmspen's Avatar
Skill improvement and winter seat time, mostly. Looking to be sharp (and improved) for the start of next year's autocross season / track days. A bit of fun wouldn't hurt...
Old 11-08-2016, 07:15 PM   #4256
Apex_BRZ
Don't forget about Project Cars. I feel the order of things as far as realism would be more like Asetto Corsa, then Project Cars being better yet. IRacing is highly debated as being the best.
Simple question, hard to find answer... Mango22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 5 05-16-2013 06:23 PM
Silly question about protecting track rims sw20kosh Tracking / Autocross / HPDE / Drifting 16 04-25-2013 12:34 PM
Asking the question that I already know the answer to. Are the engines the same? Bigmaxy Engine, Exhaust, Transmission 10 01-19-2013 07:47 PM
Random dog-related question for those who have their BRZ GMU-BRZ BRZ First-Gen (2012+) — General Topics 11 05-31-2012 07:48 AM
Got my answer - BRZ comes with HID headlights as STD Z_Rocks BRZ First-Gen (2012+) — General Topics 20 01-10-2012 09:54 AM
