Old 10-22-2016, 06:50 AM   #813
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Drives: 2016 HyperBlue BRZ
Has anyone done their Subaru logo in cherry blossom? I'm tossing up the idea but not sure yet.
Just changed my exhaust to a Greddy Revolution RS. 100% more fucking loud. 100% more awesome.
SBD400X Turbocharged 2016 Series.HyperBlue BRZ
Luftwaffel is offline   Reply With Quote
Old 10-22-2016, 07:18 AM   #814
Luftwaffel
Boost Creep
Luftwaffel's Avatar
So, I've had enough time in the seat of both to be able to form my opinions of both supercharged and turbocharged.
Admittedly, I've never liked the idea of supercharging. I think it's stupid and roundabout to take power to make power. My throttle response was never quite right. I suspect this to be partially because of the parasitic draw of the blower, and it's possible I had a tiny vacuum leak. My IATs were insanely high because it heat soaks like fucking crazy. I'm talking 130+ in heavy traffic. It felt sluggish and too linear too, and therein lies the problem for me. Being able to hit full boost at low RPM gives that punchy thrill that a supercharger just doesn't, and it holds that boost all the way to redline. The power is just that much more immediate.
It's also simpler. The Edelbrock kit (as most proper PD blowers do) just has too much shit going on, and things have to be relocated all over the place. You have an entirely new coolant loop with water pump you have to worry about, since the intercooler has to be water-to-air because the small space between the blower and the intake manifold is the only place an intercooler can go. You have to change fuel lines, clutch lines, coolant lines, and add/extend a rat's nest of electrical just to make it work. You can't run a strut brace with it because it's absolutely massive. Don't get me wrong, if I had to go with a PD blower I'd do it again since I believe the Edelbrock is the best kit out there, but it is a fairly complex system.
By comparison, a turbo is a turbo. You have exhaust piping coming into and out of the turbine side of the turbo, and you have intake piping going into and out of the compressor side of the turbo. Weld a bung on the oil pan or just buy a pre-welded pan. Tee off of the oil pressure sensor for the oil feed line to the turbo. That's it. It's a turbo. There's nothing to it. Except the shitty close tolerances on some of the nuts. My hands have a few cuts.
The Following User Says Thank You to Luftwaffel For This Useful Post:
hypebrz (10-22-2016)
Old 10-26-2016, 08:31 AM   #815
hypebrz
IG: @HypeBRZ
hypebrz's Avatar
Drives: Series.Hyperblue BRZ
One of the shots from my last mini photoshoot! Having trouble getting the rest to upload lol
EDIT: Here's all the ones I have finished, still have a few more to edit!
And yes, I am aware of my side marker
hypebrz is offline   Reply With Quote
The Following 4 Users Say Thank You to hypebrz For This Useful Post:
funwheeldrive (11-21-2016), ShawnP19 (10-26-2016), ToySub1946 (11-25-2016), trumpet_bro (11-01-2016)
Old 10-26-2016, 10:40 AM   #816
ShawnP19
ShawnP19's Avatar
Drives: 2016 Series.HyperBlue BRZ
Cool pics man, well done
Sent from my SM-G900V using Tapatalk
ShawnP19 is offline   Reply With Quote
The Following User Says Thank You to ShawnP19 For This Useful Post:
hypebrz (10-26-2016)
Old 11-08-2016, 08:44 AM   #817
p1l0t
p1l0t's Avatar
There's nothing like the original blue pill. (So I'm told...)
hypebrz (11-08-2016)
Old 11-08-2016, 09:52 AM   #818
JoeS
Drives: 2016 BRZ Hyper.Blue
Yeah... And if you drive for more than four hours, they suggest you go see a doctor!
Sent from my XT1650 using Tapatalk
JoeS is offline   Reply With Quote
Old 11-08-2016, 09:56 AM   #819
p1l0t
p1l0t's Avatar
Old 11-09-2016, 06:47 PM   #820
Skullman93
Drives: Hyper.Blue BRZ 2016
Kyle
Milford CT
667
Everyday driver
And the day I brought her home
Sent from my Pixel using Tapatalk
Skullman93 is offline   Reply With Quote
The Following 3 Users Say Thank You to Skullman93 For This Useful Post:
JoeS (11-09-2016), Luftwaffel (11-09-2016), p1l0t (11-09-2016)
Old 11-09-2016, 08:03 PM   #821
iamfiona86
FT86Club's BRZ Series.HyperBlue Owners Registry
Fiona
iamfiona86 is offline   Reply With Quote
The Following 4 Users Say Thank You to iamfiona86 For This Useful Post:
hypebrz (11-15-2016), JoeS (11-09-2016), Luftwaffel (11-09-2016), p1l0t (11-10-2016)
Old 11-14-2016, 11:43 AM   #822
Luftwaffel
Boost Creep
Luftwaffel's Avatar
Welcome!
Especially like Fiona's pic, at least one of us flings the car around a bit. I want to start Solo sometime soon. Was going to start last year but the SC tune was never right.
Did this last night.
Still need to fix that damn clock lighting.
The Following 3 Users Say Thank You to Luftwaffel For This Useful Post:
hypebrz (11-15-2016), p1l0t (11-14-2016), SK86 (11-18-2016)
Old 11-20-2016, 01:48 AM   #823
SK86
SK86's Avatar
Drives: '16 HyperBlue BRZ
Originally Posted by Luftwaffel View Post
Welcome!
Looks good man! The clock was a bitch at first. When you get in there, there's a little white plastic piece that the LED's sit behind and the screen sits on top of. Don't de-solder the screen, just bend it out of the way so you can unscrew the white piece. I sat for about 20 mins trying to figure the best way to go about it and almost created a lot more work for myself. Did you do the gauges/door/traction/light controls too?
Edelbrock Supercharger - Borla UEL Header - Nameless Header Back - Forester Oil Cooler
STi Lip Kit - TRD Louvers - Blue/White LED Gauge/Button Conversion - STi tS Black Interior Trim - Seibon FA Style Hood - Tom's USDM Clear Tailights
SK86 is offline   Reply With Quote
Old 11-20-2016, 09:19 PM   #824
Luftwaffel
Boost Creep
Luftwaffel's Avatar
My LEDs have been done for almost a year and I've done other cars here. I'm actually removing the screen entirely.
Old 11-21-2016, 03:30 PM   #825
SK86
SK86's Avatar
Yeah I did mine about 10k miles ago. How funny that we did them almost the same. I did the window controls and headlight/dimmer switches too.
Old 12-03-2016, 07:03 PM   #826
hypebrz
IG: @HypeBRZ
hypebrz's Avatar
It's December guys and gals! What tires are yall running for the cold and rainy weather? My nittos are not cutting it.
:popcorn:, good stuff
FR-S 10 Series Registry torqdork Scion FR-S / Toyota 86 GT86 General Forum 2518 12-11-2025 02:12 PM
FR-S Release Series 1.0 Registry brianFKNmyers Scion FR-S / Toyota 86 GT86 General Forum 800 10-26-2020 09:18 PM
'Unofficial' US BRZ Series.Blue Registry Jimmy45brz BRZ First-Gen (2012+) — General Topics 110 08-15-2017 07:37 PM
2016 BRZ Series.HyperBlue Announced Veloist BRZ First-Gen (2012+) — General Topics 523 11-05-2015 06:22 PM
Anybody want to buy a 2016 BRZ Series.HyperBlue? Veloist Northern California 0 08-27-2015 01:05 PM
