Old 10-18-2016, 08:43 AM   #29
Diode Dynamics
Diode Dynamics's Avatar
Factory is definitely not an H1 on the FR-S or the BRZ. Most aftermarket housings use H1 & H7 if that's what you meant.
D2S is an OEM HID bulb size, and will produce much more output than an H1
Nick C.
John C.
Diode Dynamics
Old 11-07-2016, 07:20 PM   #30
tazz786
Drives: 2015 scion FR-S
can somebody please help me on what to do with wiring?
I used a T tap connector to tap the white boomerang wire to the daytime running light red wire on the bottom of the bumper. It worked for about 10 seconds and then went dead.
Now the daytime running lights and the boomerang will not turn on. My FRS is a 2015 and it comes stock with the LED strip daytime running lights.
I connected white boomerang wire to red positive in DRL wire. The black is grounded to the chasis.
tazz786 is offline   Reply With Quote
Old 11-08-2016, 08:00 PM   #31
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
Have you removed the t taps? I've only had bad experiences with them.
Old 11-08-2016, 09:16 PM   #32
tazz786
yeah removed the t taps. ended up blowing a fuse.
The Following User Says Thank You to tazz786 For This Useful Post:
continuecrushing (11-09-2016)
Old 12-30-2016, 03:18 PM   #33
Nicthony
Nicthony's Avatar
I got the Spec D & D4S H11 kit from Ft86speedfactory but after doing my research on here everyone says they don't work so I didn't even try to install them. Long story short what is the proper size for these lights?
Nicthony is offline   Reply With Quote
Old 12-30-2016, 09:35 PM   #34
KnightRyderx2
Drives: 2014 FR-S
So you got this Spec D headlight w/HID option? This headlight uses an H1 bulb. Now if you bought the HID kit as an option to the headlight it should work fine.
Here is the Spec D page. Check the third picture, the rear of the housing. The round plastic thing on the left covers the headlight connector. Turn to remove this and the bulb is behind there.
Unbox your HID kit and find the HID bulb, follow the wire and it should run into a round rubber piece. At the rubber piece there should be another wire with a connector on it. The HID bulb and connector will be on the same side of the round rubber piece. This connector will plug into the same socket as the bulb that came with the Spec D headlight. You need to drill a hole in the plastic cover thing to run the bulb and connector through. Then plug the hole with the rubber thing. The ballast and igniter will stay outside the housing just mount them some place.
KnightRyderx2 is offline   Reply With Quote
Old 01-08-2017, 01:24 AM   #35
Captain.K
Captain.K's Avatar
Drives: 2015 FRS Firestorm Red
anyone else figure out how to connect an hid kit ever since they changed the connectors to this?
Captain.K is offline   Reply With Quote
Old 01-09-2017, 09:59 PM   #36
mcsmokey
mcsmokey's Avatar
Drives: 2016 Scion FRS
I've been wondering the same thing.
mcsmokey is offline   Reply With Quote
Old 01-10-2017, 01:16 AM   #37
Captain.K
Captain.K's Avatar
figured it out already haha the main thing thats a pain is the bracket that holds the bulb
Old 01-19-2017, 05:34 PM   #38
CxG
Drives: Pearl White '13 ZN6
so guys quick question... what do we do if one of the boomerangs go out? like am I SOL here?
CxG is offline   Reply With Quote
Old 01-19-2017, 09:17 PM   #39
Captain.K
Captain.K's Avatar
im semi in the same boat, my high beams are stuck to the "ON" position unless i hit the actual headlight for them to go back to normal......
Old 01-19-2017, 09:56 PM   #40
zman
zman's Avatar
Drives: scion frs
zman is offline   Reply With Quote
The Following User Says Thank You to zman For This Useful Post:
Teseo (01-19-2017)
Old 01-19-2017, 11:32 PM   #41
Teseo
Drives: frs
OP pictures doesnt show
Edit: i want those headlights but the wiring stuff overwhelming to me. Its possible to let the boomerang in all time? Did i need to buy HID kit also, or is optional?
Teseo is online now   Reply With Quote
Old 01-19-2017, 11:41 PM   #42
zman
zman's Avatar
Drives: scion frs
No need for HiDs. You could have them on all the time, just need to find a wire with 12v. I used T taps on mine which come on with the DRL lights
Teseo (01-20-2017)
Springs! Post your Pics!! stevohl Suspension | Chassis | Brakes -- Sponsored by 949 Racing 113 11-10-2016 02:30 PM
Cat/Car pics, post yours :) ZionsWrath Other Vehicles & General Automotive Discussions 18 08-10-2014 11:26 AM
Post your winter pics kidgogeta Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 12-16-2013 01:52 PM
Raven Only! Post Pics! imlevinit FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 1 07-06-2012 07:41 PM
