#421 |
They make fun reading though!
| The Following User Says Thank You to Tcoat For This Useful Post: | Ultramaroon (11-06-2016) |
#422 |
Drives: '15 BRZ RA
Final Drive is actually a torque multiplier and changes the amount of torque that is transferred on the wheels. However, things get complex with speed and the gear that you have to use in each case (shorter or longer FD). This is a reason why crankshaft power is a better measure of actual engine power.
#423 |
Drives: Silver 2013 BRZ Ltd Auto 45,000 mi
Remapping the throttle is NOT a tune
For those who didn't know, a remapped throttle is only one map out of the hundreds that make up a tune. It is not a tune in and of itself. It does not change the maximum horsepower or torque of the engine. It simply changes how much goes where, at which pedal percentage and at which rpm. The actual air to fuel ratios, exhaust gas re-circulation, and emission controls are unchanged. These still work in the same relation, regardless of which throttle map is loaded.
Since there are a lot of car reviewers and car buyers who aren't looking for, and in some cases, can't even drive a stick, I want to concentrate on solutions for the Automatic versions of the FT86. As a sports car owner, I am offended by the fact that a stock Auto FT86 can't keep up with a much of anything, econocars, SUV's, or minivans, in stop and go traffic. The reason is, the cars just don't have enough low-end torque to accelerate in the same gear they are in. The gas pedal must be pressed at least 20% to trigger a downshift, and then, in a lower gear, at higher revs, it has so much power that it catches up to traffic dangerously quickly. The solution is to remap the throttle and change the Final Drive. The throttle needs to actually have less power up to 20%, then more power from 20% to 100%, in the lower rpm ranges below 3000 rpm's. I drive an Auto. I have used a 4.10, a 4.30, and currently a 4.88 Final Drive in my car. I've been backing up my words with actions, by actually changing the throttle map, driving, changing, driving, and learning as I go. There are a lot of negative people who Can't Do Sh*t, that feel they need to tear down those who can. I use Open Source RomRaider tuning software so I can share what I learn with others, and learn from others who are willing to share.
If I say yes, will that make you think I understand?
![]() Last edited by KoolBRZ; 11-06-2016 at 04:21 PM. |
#424 | |
pessimistic skeptic
| The Following 2 Users Say Thank You to mrg666 For This Useful Post: | darthpnoy1984 (11-07-2016), Hoahao (11-07-2016) |
#425 | |
#426 | |
| The Following User Says Thank You to Ernest72 For This Useful Post: | darthpnoy1984 (11-07-2016) |
#427 | |
Drives: 15 ZN6 Asphalt
I have a similar commute as you are underpowered please the kids unfortunately are too spoiled these days. Sent from my iPhone using Tapatalk
2015 ZN6 DD AT
#428 |
Potato Farmer
Drives: #SLOBRZ
Without reading the 31 pages before me..
The review is pretty much spot on. The car handles like shit out of the box, i have spent thousands to get mine to handle how it should. It's a cheap car, and it's good for its price, but its nothing special. it is easy to be biased cause you own one, I was... But after 30k (AUD) of work, it's starting to look good, and handle well. And I have only done basic performance mods.. Another 10k and I could have a Harrop supercharger, and at 80k that it is now cost me, I could have just bought a M240i and been done with it.
Something something butter..
www.vic86brzclub.com |
#429 | |
Drives: AP1 Honda S2000, Focus RS
| The Following 5 Users Say Thank You to deejaylew For This Useful Post: | DAEMANO (11-08-2016), darthpnoy1984 (11-07-2016), Hoahao (11-07-2016), Mr.Impreza (11-07-2016), mrg666 (11-07-2016) |
#430 | |
Mr.Fujitsubo
Drives: 2018 STI
![]() ~ An no....buying a BMW won't allow you to be "done with it". BMW just gives you VIP access to the dealerships garage since you'll be seeing it monthly. ![]() Trust me...I've owned BMW's
2015 Toyota 86 ~ The Sold Car ~ Build Journal OFT Stage 1 Tune Review ![]() |
#431 | ||
Drives: '14 Monogram, '95 Miata, '90 300ZX
^^^ BMW is pure garbage.
From a third party perspective, it is pretty clear what is going on here. I have no doubt that the ability exists to set up and tune this car to behave like much more of what is expected from a sports car. That said, it is not possible for other reasons. The stock throttle map, shift points, changing the rear end ratio, and so on, are all set up to meet the EPA and CARB emission and fuel economy standards and conform to the drive cycle tests. Should this apply to a low volume sports car, many of which aren't even daily driven? Probably not, but the EPA has been over-reaching quite a bit lately, and the CARB regulations are basically a way for one state to circumvent the democratic process and force one state's excessive regulations on the entire country by way of leveraging economies of scale. Basically what I'm saying is this is a regulatory problem, not a Toyota/Subaru problem. That, along with the fact that they want to advertise a higher fuel economy, are responsible for a lot of less than desirable automotive "innovations" that we've seen lately. Valve problems from cylinder deactivation systems, turbocharged motors on economy cars that will be expensive to fix in the long run, reduced engine longevity due to particulate filter systems, and my personal favorite, the disaster that is the CVT, are just a few that come to mind. Unfortunately, this kind of thinking has made its way into the 86 as well, and this is what we are stuck with now. On the plus side, we are also getting positive improvements such as weight reduction, because of this. Also, it can be fixed with a tune, although it kind of sucks to lose your warranty over something so silly. |
| The Following 2 Users Say Thank You to Yardjass For This Useful Post: | darthpnoy1984 (11-07-2016), why? (11-07-2016) |
#432 | |
I am glad that somebody get's it! This is all that I have maintained all along! Unfortunately those regulatory requirements are indeed Toyota/Subaru's problem. Not so much as a "want" to advertise but a MUST meet situation. They do what they can to give the public what they want and still meet the requirements they are required to if they wish to export the vehicles. The guys that tune or mod do not have their hands tied by the regulations and do pretty much as they please. End of story and a non debatable FACT.
| The Following 4 Users Say Thank You to Tcoat For This Useful Post: |
#433 | |
Drives: 2015 BRZ Sport Tech CWP
| The Following 2 Users Say Thank You to Guru Woodman For This Useful Post: | Tcoat (11-07-2016), Ultramaroon (11-07-2016) |
#434 |
In fairness there were still two Germanys when you got that!
| The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
| Stupid? Or Cool? I'm too old to know | FNCrazy | Cosmetic Modification (Interior/Exterior/Lighting) | 27 | 08-03-2016 11:59 AM |
| Does This Look Stupid? | FNCrazy | Cosmetic Modification (Interior/Exterior/Lighting) | 29 | 07-24-2016 11:54 PM |
| Help stupid iphone | Atticus808 | Off-Topic Lounge [WARNING: NO POLITICS] | 5 | 01-19-2015 11:53 PM |
| stupid question about brz | andrewmay9 | BRZ First-Gen (2012+) — General Topics | 55 | 05-17-2014 04:10 AM |
| stupid deer | balla_08 | Cosmetic Modification (Interior/Exterior/Lighting) | 11 | 12-14-2013 06:23 PM |
