Old 11-04-2016, 09:31 PM   #1
xcuz31
Drives: white frs
OFT worth it?
i am about to pick up a OFT tommorrow before i do i just wanna make sure its worth it
i have a header right now uel
i am not expecting any big hp gain
but decent gain will be good and is it reliable to run a OTS tune for daily / track?
i really need your opinion
xcuz31 is offline   Reply With Quote
Old 11-04-2016, 10:00 PM   #2
Guru Woodman
Guru Woodman's Avatar
Drives: 2015 BRZ Sport Tech CWP
Yes, it is totally worth it. It is the best bang for you buck, especially when you have a UEL header.
I have an OFT without any other mods (yet) and I am amazed how much different the car feels and drives. Even the exhaust note is different
Guru Woodman is offline   Reply With Quote
The Following User Says Thank You to Guru Woodman For This Useful Post:
xcuz31 (11-04-2016)
Old 11-04-2016, 10:42 PM   #3
xcuz31
Drives: white frs
how much power it will make with stage 2? i seen some dyno and it seems like its only gonna add lil HP
Old 11-04-2016, 10:50 PM   #4
Teseo
Drives: frs
If you have e85 available in your area you can have more power
The Following User Says Thank You to Teseo For This Useful Post:
xcuz31 (11-04-2016)
Old 11-04-2016, 11:33 PM   #5
xcuz31
Drives: white frs
thats sucks i dont have a lot of e85 here im thinking of staying pump gas 91 octane so i wont get stranded just in case
Old 11-04-2016, 11:37 PM   #6
Wyattkb
Drives: 2014 Whiteout FRS
Bro, its worth it. Hands down the best bang for your buck you can do to this car.
It makes the car much "peppier" all around and a noticeable gain in the butt dyno.
I have ran the OFT on Stage 2 91 and Stage 2 E85 at the track over 5 times. I had 0 issues. I have put over 40k DD miles on my car with the OFT and it has had 0 issues.
If you don't have a header yet, get that after the OFT when you can afford it. It will add a lot more power to the top end. If OFT + Header isn't enough for you switch to the E85 tune and you'll feel even more power.
I have been running my OFT Stage 2 tune for over 1 year with no issues. I took it off for a month while I was doing some maintenance and couldn't believe how dull the car felt stock.
Note I don't work for OFT nor am I sponsored. I have just had a good experience with the OFT all around. All other plug and play tune options available for our car are garbage when compared to the OFT. Trust me I have spent the money on them and was very disappointed.
Wyattkb is offline   Reply With Quote
The Following 3 Users Say Thank You to Wyattkb For This Useful Post:
FRSBRZGT86FAN (06-16-2018), trvth (11-08-2016), xcuz31 (11-04-2016)
Old 11-04-2016, 11:41 PM   #7
xcuz31
Drives: white frs
thanks i have a uel header right now . and cel is not on yet becausei have a defouler . but im picking up a oft tommorrow . thanks for the advice hopefully i will feel better when i get the ots tune installed.
Old 11-05-2016, 03:30 AM   #8
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I was considering to buy an OFT too. Everyone says good words, but keep in mind that you'll run much leaner (less fuel during high engine loads). This means higher engine temperatures. It should be fine if you don't push the car a lot, but in other cases you should have consequences ...
Old 11-05-2016, 07:17 AM   #9
steve99
Drives: FT86
Oft is device to flash tune log, and just happens to come with free tunes..
Oft tune generally run a bit rich
stock tune is super rich
oft tunes like all other aftermarket tunes run leaner than stock higher rpm. but oft tunes run richer than most others.
i dont understand where your getting the idea oft tunes runs lean and will cause problems from , it just misleading people
on petrol high rpm load
stock is about 11, pre MY2017
oft 11.8 , but many will run a little richer
lot of other tuners run 12 to 12.5 on petrol
new my2017 cars targeting arround 12.5
Old 11-05-2016, 07:55 AM   #10
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
I didn't say that OFT runs lean. I said that it runs leaner than the stock tune.
As you said on high RPM and load, OFT targets 11.8 and stock tune targets 11.0-10.1.
OFT stg1 target AFRs:
Stock target AFRs:
Why is this misleading people? Is it wrong saying that a leaner air/fuel ratio will give higher engine temperatures?
Old 11-05-2016, 02:00 PM   #11
Kodename47
Kodename47's Avatar
Drives: UK GT86
Exhaust gas temps will be hotter if its more lean, which could reduce cat life/efficiency. The engine won't run hotter as the cooling system is decent enough. I guess you could also worry about cooking the valves, but we've yet to hear issues like that.
Don't forget that running more ignition advance will help reduce EGTs
.: Stealth 86 :.
Kodename 47 DJ:
Old 11-05-2016, 04:52 PM   #12
steve99
Drives: FT86
Every NA tune ive seen/logged runs leaner than stock OFT ecutek guys , local BRzedit tuners. As @Kodename47 said this does not always mean higher exhaust gass temps. As many other things are adjusted in tune ie ignition timing valve timing etc.
The most likely reason they run so rich is to protect primary cat in exhaust from deterioration over time, most people have swapped out to catless header.
most people that get a tune from any tuner, are generally the people that push car hard and track car. We not seeing a huge number of tune related engine failures on NA cars that are tracked and its been three or more years.
The early engine problems were primarily due to DI injector fails due knock (on stock tune) with the incorrectly set Transient ignition retard parameter ,which was fixed in most aftermarket tunes, and leter rom revisions.
In fact the highest EGT (exhaust temps) I see are when im cruising on highway at light load where your targeting close to 14.7. When im tracking and full throttle on straights (12.5 AFR) my egt is 60C or more lower than when im cruising on highway..
Old 11-05-2016, 05:03 PM   #13
churchx
churchx's Avatar
Drives: 2014 GT86
steve99: are you shure about 1st cat protection being most likely reason? Not for example "safe as possible" tune for whichever shitty fuel that these cars can see worldwide?
Old 11-05-2016, 05:15 PM   #14
steve99
Drives: FT86
Nope not sure, and as you say its also likely its for safety with crappy fuel, or to help if someone accidently puts low quality fuel in the car, might provide some extra knock resistance.
very likely when you look at cars running 95ron fuel like this
http://datazap.me/u/steve99/south-af...-20-28&solo=28
Does it worth to buy and fix this BRZ ? kilohercas BRZ First-Gen (2012+) — General Topics 12 01-07-2015 12:26 PM
gt 86 worth 40k!!!??? 12345qwerty Scion FR-S / Toyota 86 GT86 General Forum 29 04-13-2013 10:56 PM
Is the FR-S worth getting? DIM Scion FR-S / Toyota 86 GT86 General Forum 60 10-28-2012 11:43 PM
Is it worth it? Greaser Scion FR-S / Toyota 86 GT86 General Forum 45 08-10-2012 10:15 AM
BRZ vs FRS - was it worth it? Heero CANADA 34 06-25-2012 10:57 AM
