Old 11-03-2016, 04:12 PM   #29
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
the main thing to mention here is the tune
its crucial to engine longevity and a bad tune vs good tune on the same hardware will kill things pretty quickly
Matt@Cosworth is offline   Reply With Quote
Old 11-03-2016, 04:14 PM   #30
Anderzz
Anderzz's Avatar
Drives: 2013 Subaru BRZ Premium
Originally Posted by bfrank1972 View Post
Why are we all talking about clutches and horsepower instead of torque? It's torque that kills clutches - and the positive displacement superchargers can produce a lot more torque for a given peak whp output level - that's one big consideration. Example: A tuned intercooled innovate, or intercooled edelbrock on CARB tune will both produce probably 240-250whp peak on pump, but both will also produce close to 200 wtq for a good span of the rev range, with torque falling off in the upper ranges. A well tuned centrifugal unit like a vortech may produce around 280whp peak - sounds like a lot more but in reality it's at or under 200wtq for most of the power band.
Around 200wtq is probably the limit before you start having some issues - and also depends a lot on how abusive you are.
Apples to apples, a 280 whp positive displacement supercharger (or turbo) will likely kill the clutch a lot faster than a 280whp centrifugal supercharger. A tuned/optimized 280whp edelbrock unit will probably make the clutch suffer.
Thanks for the highly informative reply. If you don't mind the total noob question, what are the other PD SC options outside of the Edelbrock?
Seems like the huge torque would be alot more appealing to me personally even if it meant dropping another $700-$1k on a better clutch
Anderzz is offline   Reply With Quote
Old 11-03-2016, 04:38 PM   #31
armstrom
Drives: none
The primary PD kits are Edelbrock, Harrop and Cosworth. Sprintex is also a PD SC but uses a twinscrew rather than roots type blower. The other three all use Eaton TVS (1320 for the Edelbrock and Harrop, 900 for the Cosworth) blowers.
-Matt
armstrom is offline   Reply With Quote
The Following User Says Thank You to armstrom For This Useful Post:
Anderzz (11-03-2016)
Old 11-03-2016, 05:29 PM   #32
Kylebrz
Kylebrz's Avatar
Drives: 2013 subaru brz
that's encouraging, how many miles has it been in the car?
I have put 30k kilometers in it and it's been thru it's paces my friends have vortech and jr kits and they have had a few hiccups but not me I am making more tq then them to
Kylebrz is offline   Reply With Quote
The Following User Says Thank You to Kylebrz For This Useful Post:
Old 11-03-2016, 08:01 PM   #33
bfrank1972
Drives: 2013 FR-S Argento
-Matt
Yup, though I wouldn't leave the Sprintex supercharger out of the 'primary' category, it was one of the first systems out for our cars and is a solid performer if set up/tuned right. There's also a TRD developed one, but it's a bit of a unicorn and probably not a complete bolt on kit when you find one.
Regarding the centrifugal systems, I wouldn't discount them just because they lack torque at 2500 rpm. At 3500+ they still produce a good bit more torque than a NA car, and 5000+ they're rockets all they way to redline.
Lastly, as someone else mentioned, TUNE is everything.
The Following 2 Users Say Thank You to bfrank1972 For This Useful Post:
CSG Mike (11-04-2016), Kylebrz (11-03-2016)
Old 11-03-2016, 09:00 PM   #34
Kylebrz
Kylebrz's Avatar
Tune is everything!!
Old 11-03-2016, 11:33 PM   #35
VABeachBRZ
I personally would rather have the centrifugal systems. TQ down low doesn't help my track days or spirited driving. @ 4.5k+ it starts to take off. My buddy has the edelbrock, but says he likes the way mine (JRSC) drives and prefers it.
Both kits are amazing. It's all about how you use them. Can't go wrong with either
VABeachBRZ is offline   Reply With Quote
The Following User Says Thank You to VABeachBRZ For This Useful Post:
Old 11-03-2016, 11:53 PM   #36
Cal3000
Drives: Panda FR-S
Originally Posted by Nah View Post
100k on your motor with the supercharger!?!?!?!
Mis read your post lol... but still how many miles on the setup?
102k miles on the set up and 126k total miles on the motor. lol
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
The Following 3 Users Say Thank You to Cal3000 For This Useful Post:
AJPG (11-05-2016), CSG Mike (11-04-2016), Nah (11-04-2016)
Old 11-03-2016, 11:56 PM   #37
Cal3000
Drives: Panda FR-S
Originally Posted by Wise View Post
How is the transmission going any problems during that timespan? Do you run an aftermarket clutch?
No gearing issues but a lot of throw out bearing issues. It seems to wear out every 40k miles or so.
I started off running the stock clutch for 20k miles. Then switched over to an exedy stage 2 before their revision. That was a nightmare. I went back to the stock clutch and it holds fine.
The Following 2 Users Say Thank You to Cal3000 For This Useful Post:
fguadamuz (11-04-2016), Wise (11-04-2016)
Old 11-04-2016, 01:31 AM   #38
BigFatFlip
sleep, drive, eat, repeat
BigFatFlip's Avatar
Drives: '13 BRZ, '12 Outback
Originally Posted by Phantobe View Post
So I'm just wondering is there any noticeable tq in a centrifugal type supercharger below 4.5k RPM? Does it pretty much feel like a NA engine? I like the fact that centrifugal makes more top end but will it still feel like there's a torque dip in the 3-4.5k RPM range?
I have an Edelbrock and have driven a couple of JRSC equipped cars. I would have to say yes, I noticed that in the lower rev ranges, the JRSC equipped car kinda feels like an NA car, but without the torque dip since there is still more torque than stock and the dip is usually filled in, just not a "wallop" like the Edelbrock.
The Following 2 Users Say Thank You to BigFatFlip For This Useful Post:
CSG Mike (11-04-2016), Phantobe (11-04-2016)
Old 11-04-2016, 09:09 AM   #39
wbradley
Sarcastic SOB
wbradley's Avatar
I'm curious how a car on 215's, stock width but ultra high performance tire manage the Edelbrock torque wallop. As appealing as that sounds I picture activating VSC and throttle cut out pretty quick on aggressive take offs.
With the centrifugal the low end torque is a lot less, typically the torque dip is gone with more overall response lower end, with a screaming upper end. So, the tach needle climbs quick from about 4800 to redline. The power curve increases linear to redline. Maybe like a more powerful S2000 with a turbo sound?
Old 11-04-2016, 11:31 AM   #40
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
Why not just get wheels/tires that will accommodate the added power? Or turn off VSC.
shiumai is offline   Reply With Quote
The Following User Says Thank You to shiumai For This Useful Post:
Old 11-04-2016, 11:53 AM   #41
wbradley
Sarcastic SOB
wbradley's Avatar
Firstly, some people like to run narrower wheels/tires. I will be swapping to 225's on my 8" wheels. There seems to be some school of thought that significantly wider tires changes the dynamics, as would a staggered setup, and I belive that for me at this point in a way I prefer not to go .
Shutting off VSC every time not a suitable option, I daily drive as do most people.
The different types of blowers are like different "flavours". That doesn't mean they aren't all tasty, or that all designs will be everyone's taste.
In the ideal world unless you are drifting you want to get the power to the ground. It's just a matter of how easy or difficult that will be and whether or not you are compromising handling or feel.
Old 11-04-2016, 12:07 PM   #42
CSG Mike
CSG Mike's Avatar
Wider tires don't change the dynamic of the car. Rather, it exaggerates it.
A car that understeers can be made to "oversteer" if the tires are small enough and you have enough power; this is a "power-over". Make the tires wide enough, and eventually you can't power-over anymore, revealing the true understeering nature of that specific car.
shiumai (11-04-2016)
New to me daily driver.. 95 M3. Dave-ROR Other Vehicles & General Automotive Discussions 58 07-17-2014 02:05 AM
Is your FR-S your daily driver? Drive Scion FR-S / Toyota 86 GT86 General Forum 136 02-10-2014 09:10 AM
FRS as a Daily Driver? Pake1 Scion FR-S / Toyota 86 GT86 General Forum 104 08-15-2012 11:48 PM
Will the BRZ be your daily driver WRXGuy1 BRZ First-Gen (2012+) — General Topics 47 05-23-2012 12:15 PM
BRZ as daily driver? Pakjk89 BRZ First-Gen (2012+) — General Topics 80 03-22-2012 09:50 AM
