#239 |
Drives: svt focus
I'd love to be able to do a full exhaust setup that adds good power but isn't too loud. I'm not 16 any more, being able to stay somewhat low key is important.
#240 |
Drives: Legacy GT
Wouldn't it have been way easier to just take a perrin header, cut off the end, and put on a new bend and collector?
#241 |
Site Moderator
Drives: Stuff
Uhhhmm why would they do that exactly?
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
#242 | |
post whore extraordinaire
Drives: 2013 Asphalt Grey FR-S 2003 Evo 8
#243 | |
Remember that once you change cams you will have to make sacrifices, it will either be smooth midrange, low end pull, or highend power, not all three. Taiman, would you please update everyone on how the torque dip has changed since the exhaust intall, and what your current driving impressions are regarding said torque dip? Thank you G |
#244 | |
Kuruma Otaku
As for the placebo comment, I understand it is real. I'm just speculating based on gearing and rpm drop, not having driven one yet, that under 'soft' and 'hard' driving it wouldn't be too apparent. Some insight on how it is noticed, and under what conditions, could help with figuring out a solution.
Because titanium. |
#245 | |
Kuruma Otaku
Because titanium. |
#246 |
Drives: '06 AM V8V Coupe
I think it would be more intake header dependent, no? Doesn't matter how good your exhaust scavenging is if the intake acoustics don't match. Would probably need AVCS adjustment along with fuel/ignition to suit the new volumetric efficiency local max, and turn down the intake cam advance in the previous local max torque range since scavenging efficiency has been reduced there.
#247 | |
Kuruma Otaku
An exhaust pulse will create a pressure drop at the exhaust valve when it arrives. Bigger pressure difference will reduce effort to extract gas out of the cylinder. But matching it to overlap and coinciding intske side lengths we can now get a pressure increase on the intake side as well. But there can actually be such a thing as over-scavenging too... So what the acoustic tuning can do is spread around or gather together torque in the rpm range. Which goes back to my old BMEP obsession. It's not just about peak BMEP, but also how far it drops over how many rpm. And acoustics plays a major role in that. In this case remember I was originally not too impressed with the BMEP numbers, before we got dyno graphs. But the fact that the low peak is nearly the same as the main peak shows how much they've spread it around. Now we just have to gather it up at 5500+ and get some slightly longer duration cams, and this will be getting close to that TRD 3SGE...
Because titanium. |
#248 | |
Tall guys fit, too.
Drives: BRZ Premium 6MT (SWP)
Shifting at 4kish or 7kish pretty much negates the issue as you avoid that zone altogether, as long as your high RPM shifts finish before the engine RPM drops too much. Really, you'd notice this the most on a track or area where you can't always control your shift points. In street driving, it is 100% avoidable... but I don't want to have to avoid anything.
#249 |
Boost Junkie
Drives: Evo 9, 98 Neon R/T
OP,
Have you dyno tested any other header designs? Seems like you just dyno tested against the OEM piece... Also LaCenter washington is a small place. You work for ETS previously?
Stages are for Thespians.
#250 | |
Tall guys fit, too.
I really don't want to do much with the cams. I probably won't do more than an I/H/E and a tune, with a possible change in the suspension later on down the road.
#251 |
Drives: DGM BRZ Limited
Since there are no designs yet developed, all tests are against the OEM piece. Development will continue.
#252 |
I'm a sucker for big power. I'll take some big cams
![]() I'd like to nail around 220whp or so for now. Once a tuning solution is available i'd like to play with this. |
| Tags |
| 21 months no dyno, 22 months no vendor dyno, 22months4rattles&leakssmh, amazing warped qualiy, y u no tag |
| Nameless Performance BRZ Axleback Exhaust | ESBjiujitsu | Engine, Exhaust, Transmission | 1377 | 04-21-2020 02:23 AM |
| Nameless Performance Axleback is available for pre-order. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 114 | 07-23-2012 10:38 PM |
| Nameless Performance Downpipe is available for pre-order. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 4 | 07-12-2012 04:57 PM |
| We are Nameless Performance. | John@Nameless | Announcements, Contests, Giveaways | 22 | 06-18-2012 11:32 PM |
| Nameless Performance is here. | Nameless Performance Inc. | Engine, Exhaust, Bolt-Ons | 16 | 06-06-2012 04:32 AM |
