10-20-2016, 02:21 PM | #449 |
Drives: 2016 ZC6
@BRZyJ Dude, ELT. Nice.
My build thread: Pointmutation's WRB BRZ build
10-21-2016, 01:47 PM | #451 |
Drives: 2013 Scion FR-S Firestorm MT
I just ordered one of these units on Amazon for $279, I picked up all the adapters as well. I'll share some pictures upon completing the install.
Parts List: Perrin CAI + Borla UEL Header + Perrin Overpipe + Invidia Front Pipe w/ High-Flow Catalytic Converter + FT-86 SpeedFactory V1 Exhaust + 10k HID's + Eibach Sportsline Springs + TRD Spoiler + Rear Diffuser + Rear Spats + OFT Stage 2 Tune +18" Enkei Black Raijin Wheels (18x8 +45 up front 18x9.5 +45 in rear) Tire Specs: 235/40R18 in the front, 265/35R18 in the rear
10-21-2016, 03:06 PM | #452 |
Drives: FRS RS 1.0
Wow disabling of Google App and Play Services helps a ton. And Maps still works fine.
Only issue with the phone now is the mic , I have put it behind the steering wheel but there still a ton of noise on the other side. |
The Following User Says Thank You to shadoken For This Useful Post: | Yoshoobaroo (10-21-2016) |
10-29-2016, 10:44 PM | #453 |
Drives: Blue Monogram FRS
Hey guys, I just wondering, has anyone been able to figure out running netflix? I keep getting error (0013). I purchased the joying JY-TL123 from Amazon. Spent time getting the bluetooth dongle to communicate with torque but finally got it connected. Like most folks have already said this is a great unit, especially after flashing malaysk's rom.
10-29-2016, 11:52 PM | #454 | |
Drives: 2013 BRZ Limited / 2024 G70 3.3T
http://forum.xda-developers.com/andr...dunit-t3405931 |
10-30-2016, 11:17 PM | #455 | |
Drives: 2016 BRZ Series.HyperBlue
11-02-2016, 11:18 PM | #456 |
Drives: Asphalt FR-S
11-03-2016, 03:16 AM | #457 |
Boost Creep
Drives: 2016 HyperBlue BRZ
Does it get rid of the massive freeze every time the unit starts? I'm about tired of this fucking thing right now.
SBD400X Turbocharged 2016 Series.HyperBlue BRZ
11-03-2016, 07:04 PM | #458 |
Drives: FRS RS 1.0
I dont know. I never had the freezing before so dunno if it helps.
On another note , do not update google maps. The latest update makes it so you cant use offline maps without play services.. Fuk you google. Now i gotta find the older APK and install that. |
11-03-2016, 09:39 PM | #459 |
I'm having zero lag issues
11-04-2016, 02:22 PM | #460 | |
Drives: 2016 ZC6
But that png doesn't match our twins' cam angle and wheel track (obviously because it was made for a RAV4. lol). Here's what it looks like on the unit. The red 0.5m line is pretty good distance wise. But the green 2m line is more like 1m on our car. And the yellow track lines are obviously off. I just use it for the red line distance as I reverse mainly using mirrors and head check and only refer to the reverse cam for distance to wall once I'm already straight. I may just go in and remove those track lines and the numbers on the green line.
11-05-2016, 01:02 AM | #461 |
Boost Creep
I dunno what to do with this thing. Fresh install of the ROM and all I have is Spotify and Torque, with USB OBD reader. The thing is basically unusable until I slap the rocket button to clean up bullshit running in the background. Disabled play services. I dunno.
11-05-2016, 07:10 AM | #462 | |
TRACKBREAD
-Josh |
Similar Threads | ||||
Another Android Head Unit | Starscream15 | Electronics | Audio | NAV | Infotainment | 57 | 08-23-2015 12:41 AM |
Dashlinq4 Android Head unit. Stock BRZ fitment. Toyota Universal. | junglizste | Audio/Visual, Electronics, Infotainment, NAV | 3 | 01-08-2015 11:55 AM |
Ca-Fi Dashlinq4 Android head unit universal Toyota | phanguy | Audio/Visual, Electronics, Infotainment, NAV | 4 | 11-19-2014 11:57 AM |
FS: T7019A Android Head Unit | pheoxs | Audio/Visual, Electronics, Infotainment, NAV | 4 | 08-26-2013 05:05 PM |
Android head unit | drei | Electronics | Audio | NAV | Infotainment | 21 | 07-16-2012 02:42 AM |
