Old 10-28-2016, 08:35 PM   #1
Mcdj18
Drives: Toyota FR-S
Removing Passenger Side Pillar
Need help removing the passenger side pillar. Installed a dash cam and need to run the power cable behind. I'm afraid tho since the airbag is right behind it
x-webdoc://60CC6523-FA39-4C4C-A71F-A904AA8258C5/
Does anyone have instructions or advice on how to safely remove this pilar. Any help would be appreciated
Mcdj18 is offline   Reply With Quote
Old 10-28-2016, 08:43 PM   #2
HachiRo
Drives: 2013 White-Out FRS
Anything with airbags, you would wanna disconnect your battery first. Some say wait 10 minutes, some say press on the brake 5 times to get the remaining power out before you can safely work on airbag areas. I believe there are just clips there so you can pry it out quite easily? Might need a flat-head.
I live my life one quarter-pounder at a time.
HachiRo is offline   Reply With Quote
Old 10-28-2016, 08:58 PM   #3
new2subaru
Weight Weenie
Drives: 15 FR-S
There's a photo in this thread a little ways down.
http://www.ft86club.com/forums/showt...923#post239923
Here's a video
[ame="https://www.youtube.com/watch?v=9i2bEoTbjpA"]Brz radar detector install - YouTube[/ame]
Old 10-28-2016, 09:34 PM   #4
Guru Woodman
Guru Woodman's Avatar
Drives: 2015 BRZ Sport Tech CWP
I have a dash cam but did not remove the side pillar cladding to hide the wire. I just tucked it behind the plastic (on the right side, where the rubber meets the plastic. I would probably not fool around with that piece, hoping that you have successfully disabled the airbag.
Guru Woodman is offline   Reply With Quote
The Following User Says Thank You to Guru Woodman For This Useful Post:
Hostile_Kittens (10-29-2016)
Old 10-29-2016, 04:43 AM   #5
QHawk
QHawk's Avatar
Drives: 2020 86GT
I also just nudged a dash cam USB cable behind the trim. In these cars the edges of the plastic trim in lots of places seems thin and flexible enough to lift easily and stuff wires behind it.
QHawk is offline   Reply With Quote
Old 10-29-2016, 02:51 PM   #6
amcluesent
Drives: GT-86
Yep, just pull from the top and it'll come away.
Two things -
1) Don't try and remove the safety straps, just let the panel hang from these
2) If the plastic trim retainer 2/3rds of the way down gets left in the metal of the B-pillar, you must pry this out and slot back into the plastic trim otherwise you'll never re-seat the trim properly.
amcluesent is offline   Reply With Quote
Old 10-29-2016, 04:39 PM   #7
Mcdj18
Drives: Toyota FR-S
Thanks for everyone's input!
Drivers side pillar rattle! (With links) Weeber Issues | Warranty | Recalls / TSB 9 01-02-2020 03:15 PM
WTB: Passenger Side Clear Side Marker Sheepdog Want-To-Buy Requests 0 08-03-2015 09:56 PM
WTB: Drivers side and passenger side fenders condition don't matter Hollwood_lives Canada Classifieds 5 07-30-2015 05:53 PM
WTB: orange OEM side marker (passenger side or both) Kayzer Soze Exterior Parts (Aero, Lighting, Etc.) 4 09-05-2013 05:46 AM
Placing side mirrors inside a car, on the A-pillar hotaka Scion FR-S / Toyota 86 GT86 General Forum 11 08-08-2012 01:19 PM
