#1037 |
Drives: 13' FR-S
Anyone got a Trd quick shifter?
#1038 |
Drives: 13' FR-S
Have a Airaid intake I'm trying to get rid of. $150
And looking for a perrin intake |
#1039 |
Drives: 2013 Scion FR-S Asphalt
For sale: Nameless Trackpipe (Muffler Delete) $50
![]() Sent from my SAMSUNG-SM-G900A using Tapatalk |
#1040 |
Drives: White Scion FR-S
PHANTOM ELECTRONIC SUPER CHARGER $1850
FOR SALE:
1.5 DUMP PACK PHANTOM ELECTRONIC SUPERCHARGER WITH BATTERIES. ![]() What do I need to run this? OFT Tablet How much power? OFT TUNE W/ HEADER, E85, EXHAUST: ~225 WHP / 207 FT/LB TQ If you have an OFT the box tunes are free on the OFT website for e85 and 91 with and with out a header and EL or UEL header. How many miles does this system have: I put 10k miles on this system. No issues what so ever. I recently upgraded to a turbo kit is my reason for selling. How long to install? This is a very easy system to install. If you are mechanically inclined it takes about an hour. If not, maybe about 2 to 3 hours. The instructions can be found on youtube and the Phantom ESC thread. How much boost? 5psi Do I need to upgrade anything else? No supporting mods are required, this system runs fairly cool vs traditional Forced Induction as it does not use exhaust gas or pullies to run, only batteries. How does it work? With this kit, there is a trigger that is placed behind the gas pedal (similar to NOS) once you depress the pedal past a certain percentage (60-100 percent, depending on how loose or tight the trigger is) When can I engage the system? Anytime in 1st gear, and 3.5k RPM in any other gear is suggested. How much "juice" or how long will the turbine spin before running out of battery? The turbine will spin for a full minute and a half under load, however as soon as you let off the pedal it takes about 15 seconds to fully charge. I personally have never run the battery out, and you never will daily driving it. I have only read a few times under vigorous tracking. There is an Auxiliary charger upgrade available that makes it impossible to drain out the system if you were looking to track this system. Also, there is a "Proceed" upgrade that eliminates the switch behind the pedal, and engages the system directly off of the ECUs throttle input (neither of these upgrades are included) ![]()
Phantom ESC 1.5 Dump Conversion, Borla Headers, TRD Exhaust, OFT E85 Tune
#1041 |
Drives: 2013 BRZ Limited. 2016 Forester XT
Located in Tucson.
Selling my wheels and tires. They're Miro Type 380 (Discontinued) BBS LM reps. 5x100 18x8 +35 front 18x9 +38 rear 57.1 center bore (Centering Rings will be included) They're currently plastidipped black but they're silver with a polished lip. One wheel has a small curb rash and another a small nick. (hidden by the dip) Front wheels are wrapped in brand new Michelin PSS 245/40/18 Rear wheels are wrapped in almost new (few hundred miles) Michelin PSS 255/35/18. I paid 750 for the wheels alone. Tires a little over 900. I'm open to reasonable offers but I think $1,000 for everything is a pretty good deal. This will include wheels/tires, centering rings, lugs and OEM TPMS sensors. Prior to the dip Also have a set of OEM struts with Eibach Sportline springs, used about 13k, no leaks and rode like new, took them off last week for coils. $100 takes them. PM me for questions or more details, Im located in Oro Valley. |
#1042 |
Tucson Auction of Toyota Dealership
Not sure if anyone has interest, but a Toyota dealership in Tucson has a liquidation auction:
http://online.auctionnation.com/auct...-framed-276395 There are only 2 car related posters, that's about it. But I figured I would share if anyone is interested. |
#1043 |
Drives: 88 Supra 1JZ, 16 FRS, 25 GR Corolla
Anybody want a free OEM Exhaust Manifold? From a 2016 FRS. located in Phoenix
Trying to sell on Craigslist but no one wants it and I'm moving. Like 13K miles on it.
NARFALICIOUS
Noob Poster 1988 | 2016 |
#1044 |
The Stig's German cousin
#1045 |
Drives: 2013 FRS
I have a set of stock FRS wheels, mostly decent condition with worn RE71Rs on them. $150 or best offer. Also have stock exhaust manifold and front pipe. Free. I am located in North Phoenix.
#1046 |
JDM GT86 Shift Knob. Barely used for about 2 weeks.-$45
#1047 |
Drives: Scion FR-S 10 #853
I'm looking for a passenger side visor for a '13 FRS (probably all the same?). My mount cracked and half broke off, so the visor just falls straight out and down. And you can't just order the mount, you have to order the entire visor for around $60. Let me know if anyone has any cheaper leads.
#1048 |
800 obo.
#1049 |
Aliexpress 24 hour sale
FYI, some cool gadgets for our cars on sale for the next 24 hours on Aliexpress..
https://www.aliexpress.com/item/2x-c...a-9cdef489f07b Thought I would share. |
#1050 |
Drives: 13 FRS
Have the following for sale:
CSF Aluminum Radiator Brand New $190 picked up ![]() JDL Ultra Quiet Front pipe brand new $350 picked up ![]() JDL UEL Header- Old Design Used $250 picked up ![]()
| Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 10:54 PM |
| Phoenix run Tue 8/26 pics | RiptorVT | Southwest | 1 | 08-30-2014 02:45 PM |
| Anyone in the Phoenix area | evo4g63 | Southwest | 0 | 02-06-2013 11:19 AM |
| Looking to move to Phoenix from WI | FR-Shadow | Southwest | 37 | 01-23-2013 11:38 PM |
