#15 | |
Only happy when it rains.
Drives: series.blue
#16 |
Drives: 2014 GT86
Yes, in deep snow low ground clearance often makes it known especially due bulldoser shaped front bumper that seems made for digging in, instead on sliding above. But no traction or control issues with good winter tires, business as usual.
#17 | |
Only users lose drugs.
Drives: All the time
Yeah, 'terrible' is a bit harsh, although you do still have to keep in mind that it's a lightweight, rear wheel drive car with very little weight on the rear. The Torsen definitely helps though, and 4 snows are mandatory. That said, I go pretty much anywhere our Jeep goes, ground clearance not included. I was considering upgrading to the Wilwood WRX kit (12", 4 piston) in the front, but the way salt is so aggressively used here in central New England, durability of the caliper and rotor hat is a concern. The caliper uses dust boots, but they pretty much pave the roads here with salt from December to April... EDIT: I apologize for the partial derail...this doesn't have much to do with calipers without dust boots...still curious about durability of other anodized components though... Last edited by venturaII; 10-26-2016 at 11:22 AM. |
| The Following User Says Thank You to venturaII For This Useful Post: | Pat (10-26-2016) |
#18 |
Drives: 2013 WRB BRZ 6MT
I don't have the Sprint kit but I've got the RR Racing Sport Performance kit which I'll be running this winter. It uses a single piece rotor so I don't expect issues there but the caliper is anodised and doesn't have dust boots so that is what I'm concerned about although it does use stainless steel pistons which should be better than nothing. Our roads are heavily salted and rust is a big problem here so it will be interesting. I'm doing my winter car prep this weekend and I'm planning to swap pads and do a final partial bleed as part of that process so I'll be taking lots of pictures and notes on the current state of all of the brake hardware and then I'll compare it again in the spring.
| The Following User Says Thank You to Lynxis For This Useful Post: | n0thing (01-02-2017) |
#19 |
Drives: 2014 GT86
Problems with corrosion in salty environment usually are not that much affected what finish or what metal is used in brakes parts, rather that there are different metals placed next to each other. As in two piece disks, as in aluminium calipers (and yes, including stainless steel pistons). Throw in electrolyte, which is from salt+thawn snow/ice, and you get corrosion. Frequent washing may lessen it, but not prevent.
#20 |
Drives: 13 Subaru BRZ, 02 Audi TTQ
StopTech used to have a document on their website where they said this.
#21 |
Why aren't these higher end caliper companies using ceramic pistons?
A Chrysler mini van comes with ceramic pistons... |
#22 |
#23 |
#24 | |
Drives: 2016 Asphalt FR-S
Pat, did you ever end up getting the sprint kit? And run them through the winter? How did they hold up? I'm in a similar situation
#25 |
Drives: 2023 BRZ
Your timing is good, thpark93. I have run the Sprint kit through two winters now, and plan to clean inspect the calipers sometime this week. At the end of the first winter I cleaned them with Flitz Metal Pre-Clean and a small brush. I'm told that is an excellent remover of mag-chloride. I'll post pictures in this thread when I clean and inspect them soon.
#26 | |
Your posts have been very helpful lately! Mark Sent from my Pixel 2 XL using Tapatalk |
#27 |
I ran the RR Racing kit for 2 winters and it's still in good condition although they are filthy and the dirt is more difficult to clean off than I have time/patience for right now.
#28 |
Drives: 2023 BRZ
Due to this website not allowing large photos to be posted, and the benefit that high-resolution photos provide in this situation, I'm not going to add them to my album on this website. Instead, you can see the full-res photos here. Hope that helps.
| Scion Durability Survey | aegisdrgn | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-06-2015 12:04 AM |
| Basic Road Salt removal tips. | DetailersDomain | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 8 | 02-15-2013 08:27 AM |
| Durability of cast wheels | AsianStyle | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 13 | 12-06-2012 05:10 PM |
| FR-S A/T strength/durability? | 07stealth350z | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 06-18-2012 12:58 PM |
