Old 10-26-2016, 01:38 PM   #3025
nisti
nisti's Avatar
Drives: BRZ & XV
Originally Posted by OkieSnuffBox View Post
^Knowing your alignment numbers would be helpful as well.
Good call.
nisti is offline   Reply With Quote
Old 10-26-2016, 02:10 PM   #3026
cjd
cjd's Avatar
Drives: 2017 BRZ
Can you add front camber? I'd do that first.
The Following 4 Users Say Thank You to cjd For This Useful Post:
churchx (10-26-2016), nisti (10-26-2016), Racecomp Engineering (10-26-2016), strat61caster (10-26-2016)
Old 10-26-2016, 03:01 PM   #3027
Originally Posted by nisti View Post
What is the opinion of @Racecomp Engineering on a size of rear sway bar upgrade for my setup:
RCE Yellows on stock struts
17x9 +35 RPF1
245/40-17 Conti ECDW
Trying to reduce understeer, but not sure if a 16 mm solid bar would be enough to help, or need to go bigger.
If anyone has experience here, let me know!
Here is my current alignment specs:
A 16mm bar will be fine, but I wouldn't go any larger without also adding a front bar.
I don't know those tires well...but a little more front camber would help.
- Andrew
nisti (10-26-2016)
Old 10-26-2016, 04:28 PM   #3028
Tokay444
Add, or subtract?
Old 10-26-2016, 04:51 PM   #3029
churchx
churchx's Avatar
Drives: 2014 GT86
Given how most advise more negative camber in front and seeing in chart that it's other way around (thus added more grip in rear), imho dialed in more negative front will dial out excessive understeer AND eliminate need for swaybar purchase . Win-win, or -loose to companies making/selling swaybars
If more negative camber in front not possible, try reducing it in rear. Most often i've seen people setting 0.5 less neg. camber in rear for these cars.
P.S.
While adding neg. camber i'd also set front toe to 0deg. Rear toe-in 0.1 can stay as is.
Lynxis (10-26-2016), nisti (10-26-2016)
Old 10-26-2016, 08:44 PM   #3030
cjd
cjd's Avatar
Drives: 2017 BRZ
Originally Posted by Tokay444 View Post
Add, or subtract?
As noted, more negative camber. Typical race settings are -3 to -3.5 if there aren't rules that prevent it (c street SCCA rules, for example)
Old 10-27-2016, 01:26 PM   #3031
renfield90
The Stig's German cousin
Add, or subtract?
Typically when we talk camber we talk in magnitudes rather than absolutes, under the assumption that camber should always be negative i.e. add = more negative camber, remove = less negative camber.
The Following User Says Thank You to renfield90 For This Useful Post:
cjd (10-27-2016)
Old 11-17-2016, 03:36 PM   #3032
86Tony
Drives: 2015 AOZORA EDITION
i have a set of bilstein MDS shocks. bilstein recommend me to use 14k 16k springs what are your thoughts on that.
86Tony is offline   Reply With Quote
The Following User Says Thank You to 86Tony For This Useful Post:
DeaconRoc (11-17-2016)
Old 11-17-2016, 04:13 PM   #3033
DeaconRoc
Drives: GT86
Interested to see the responses to this.
On my motons we've tried lots of different spring rates and have found they definitely seem to work better with higher spring rates.
On the TMG cars they run the Bilsteins with 14/16 springs.
DeaconRoc is offline   Reply With Quote
Old 11-17-2016, 04:51 PM   #3034
86Tony
yes these are the same shocks as the ones on the TMG cars
Old 11-17-2016, 05:04 PM   #3035
DeaconRoc
Drives: GT86
Definitely be very interested to hear how you get on with them. Will they be solely for track use or road and track?
Old 11-17-2016, 05:30 PM   #3036
86Tony
yes just track only. will let you kno once track season starts again
Old 11-18-2016, 02:06 PM   #3037
Most important question is: What kind of tires do you run?
Also, is your car caged?
- Andrew
Old 11-18-2016, 07:43 PM   #3038
86Tony
- Andrew
no car is not caged yet will do so in the future. tires i have been just running re71r. i want to run slicks but afraid of the fuel starvation
Air Suspension Discussion Thread - Let's Get Nerdy Andrew@ORT Suspension | Chassis | Brakes -- Sponsored by 949 Racing 174 02-13-2016 03:17 PM
RallySport Directs Everything Suspension thread!! RallySport Direct Brakes, Suspension, Chassis 21 07-02-2014 05:31 PM
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension ModBargains.com Suspension | Chassis | Brakes -- Sponsored by 949 Racing 63 05-22-2013 08:15 AM
2012 Team USA vs the 1992 Dream Team ERZperformance Off-Topic Lounge [WARNING: NO POLITICS] 1 09-14-2012 06:19 PM
Team build thread; PROJECT.STH trueno86power Other Vehicles & General Automotive Discussions 0 03-02-2010 10:13 AM
