Old 10-25-2016, 07:28 AM   #1
Gyzm0
Gyzm0's Avatar
Drives: 2013 Toyota GT86
OEM armrest elbow question
Hello guys,
I'm about to pull the trigger on the Toyota lhd oem armrest for the GT86.
Since it's raised a few cms I was wondering if it interferes in any way with your elbow while you're changing gears.
I never thought about this until I drove a substitute Toyota Auris during my last service and my elbow kept banging against the armrest, granted it is much higher placed than our armrest, but we sit lower and our console is higher so I wanted to know from the few people who have installed it too.
I don't want to be more confortable driving with one hand and right arm resting in the armrest, I like both hands in the wheel and just briefly go to the gear lever, I do feel aesthetically the car has a hole in the middle and would like to put the armrest there but won't do it if interferes with usability.
Thanks in advance for your kind replies.
Best regards.
Gyzm0 is offline   Reply With Quote
Old 10-25-2016, 07:29 AM   #2
Gyzm0
Gyzm0's Avatar
The part in question
Old 10-25-2016, 07:59 AM   #3
swarb
Originally Posted by Gyzm0 View Post
Hello guys,
Best regards.
Use a book to simulate the arm rest and try it out. Not everyone drives the same or is shaped the same.
I don't have a arm rest, but I did some measuring and I would only use the front portion of the arm rest directly next to the parking brake boot. I used the door panel arm rest with my left hand on the steering wheel as reference for where my elbow would be on the right side. Shifting, the shifter is slightly further than the steering wheel(pulled closest to driver) so I would have plenty of clearance.
The Following User Says Thank You to swarb For This Useful Post:
Gyzm0 (10-25-2016)
Old 10-25-2016, 08:32 AM   #4
tobin
tobin's Avatar
Drives: '13 BRZ
It doesn't interfere with your elbow at all. It's the same height as the armrest on the door, if that helps.
tobin is online now   Reply With Quote
The Following 2 Users Say Thank You to tobin For This Useful Post:
funwheeldrive (10-25-2016), Gyzm0 (10-25-2016)
Old 10-25-2016, 09:17 AM   #5
Gyzm0
Gyzm0's Avatar
I was going to test it using some kind of plastic clip anyway, thanks for the idea.
First hand experience is always welcome
Old 10-25-2016, 09:31 AM   #6
PandaSPUR
PandaPandaPandaPandaPanda
PandaSPUR's Avatar
Drives: 2015 BRZ Limited CWP
I have that arm rest and it doesnt interfere with my shifting.
The Following User Says Thank You to PandaSPUR For This Useful Post:
Gyzm0 (10-25-2016)
Old 10-26-2016, 04:36 AM   #7
Pointmutation
Pointmutation's Avatar
Drives: 2016 ZC6
Everybody is shaped differently. A lot of factors come into play here like how tall are you, how low do you sit, how long are your arms, do you shift overhand or gun grip, position of elbow when shifting, lazy driving or shifting like a race car, etc, etc. I agree with the suggestion of using a book to simulate the armrest height and how the the armrest would work for you.
I have a much taller armrest that only got in the way when shifting fast and enthusiastically during spirited mountain runs so I'd have to swing it out of the way. But I adapted and don't even lift the armrest out of the way anymore now.
I agree that gaping hole in the middle aesthetically needed to be filled with something.
Pointmutation is offline   Reply With Quote
The Following User Says Thank You to Pointmutation For This Useful Post:
Gyzm0 (11-10-2016)
Old 10-26-2016, 07:00 AM   #8
ZZT86
ZZT86's Avatar
Drives: BR86
Agree with others here - the OEM armrest/lid is perfect, should be stock fitment damn it.
ZZT86 is offline   Reply With Quote
The Following User Says Thank You to ZZT86 For This Useful Post:
Gyzm0 (11-10-2016)
Old 10-26-2016, 07:36 AM   #9
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
I have been eyeing the armrest up too. Is it creaky at all?
-Josh
Old 10-26-2016, 08:17 AM   #10
Bluesman62
Bluesman62's Avatar
Drives: 2013 Subaru BRZ Premium
-Josh
Nope. At least mine is not creaky!
Bluesman62 is offline   Reply With Quote
The Following 2 Users Say Thank You to Bluesman62 For This Useful Post:
Gyzm0 (11-10-2016), Yoshoobaroo (10-26-2016)
Old 10-26-2016, 08:26 AM   #11
Bluesman62
Bluesman62's Avatar
One note to the OP, be CAREFUL when in installing. The rubber well/expansion nuts included with the kit (used to secure the armrest to the center console) are not very robust and can break easily. Do not over tighten or they will break. Just tighten enough so that the arm rest is not loose. One of the nuts broke during my installation and I've read about other people having the same problem. Other then that, real easy to install. Just take your time when drilling the holes.
Old 10-26-2016, 08:50 AM   #12
shiumai
shiumai's Avatar
Drives: 2013 DGM BRZ, 2020 C8 Corvette
-Josh
Mine creaks while opening and closing it, but not at any other time. Other than that small nitpick, I love the OEM armrest.
shiumai is offline   Reply With Quote
Old 10-26-2016, 09:27 AM   #13
PandaSPUR
PandaSPUR's Avatar
+1
Tried putting some grease on the joint and that helped a bit but the hinge still creaks when I open and close.
Old 10-26-2016, 11:36 AM   #14
churchx
churchx's Avatar
Drives: 2014 GT86
Mine also creaks only during open/closing. It's of perfect hight to .. well, resting arm , it's finish is OE and fits very well with rest of interrior. If i were to nitpick at something, imho it's main drawback that it opens to side, not to back, thus making console box unfomfortable to use for passenger. Otherwise - imho must have addition.
P.S.
I haven't tried alternative arm rests, but i guess if i find height of this just right, then those that are much thicker/higher, may have comfort position issues.
Gyzm0 (11-10-2016)
WTB: Perrin CAI+elbow inlet Howardwei Want-To-Buy Requests 1 07-17-2016 08:53 PM
Carbon Fiber Intake elbow and filter zumin Engine, Exhaust, Bolt-Ons 5 06-09-2015 06:32 AM
WTB: intake to PCV elbow dar3d3vil Want-To-Buy Requests 3 04-08-2015 01:58 PM
WTB: OEM armrest or Sutty's custom armrest J.C. Want-To-Buy Requests 0 10-20-2014 06:07 PM
HPS silicone intake elbow and JDM exhaust tips Mr.Scion Engine, Exhaust, Bolt-Ons 8 10-02-2014 06:18 PM
