Pat.Thornton
Old 10-19-2016, 12:43 PM   #533
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
Hi TLDR. Sorry.. so I also have this issue. I have creaking noise only if I release my clutch. What could be the issue? Hope it is not TOB.
hanabie is offline   Reply With Quote
Old 10-22-2016, 09:16 AM   #534
sato
sato's Avatar
Drives: Dodge Patitas
You'd have to take it to the dealer for them to inspect and see. Take it ASAP. I dismissed it as just a spring lubrication issue or something and didn't take it sooner (than 52000 miles). Now my dealer is stating it is "simply lubrication issue" (not even bothering inspecting it before stating that), and giving me a $500 bill just to lubricate it because they have to lower the whole transmission (BS). Their words: it is a wear and tear maintenance issue, your cost.
sato is offline   Reply With Quote
Old 10-22-2016, 09:21 AM   #535
sato
sato's Avatar
Originally Posted by seant2h View Post
To follow up on my noise issue and touch on yours....
I took my car to my mechanic who is an independent mechanic and he was able to lube the pivot with white lithium grease without removing the transmission and now the noise is gone and it feels much better. He said that it appears that nothing in there was lubed when assembled. I am no mechanic and thinking out loud and I'm wondering if the service manual calls for lubing the pivot and if not, could that possibly be a reason that so many TOBs are going bad? Maybe if the pivot point is binding then it's putting an undesirable force on the bearing causing it to fail prematurely.
The best part is that he charged me $46 and change for the service. The dealer would probably charge me more just to unlock the car and smell the tree hanging from my mirror.
I'm glad it can be done without taking the transmission apart. And the manual doesn't say jack sh¡t about lubricating that piece.
Old 10-22-2016, 11:08 AM   #536
SLVRSRFR
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
TOB usually shows symptoms when the clutch is pushed IN, not OUT. So this is probably just a lubrication issue, as noted above.
@bpennerz
SLVRSRFR is offline   Reply With Quote
Old 10-22-2016, 03:00 PM   #537
Absolutely not bs. That is the fix but it is not a "maintenance issue." I would dispute that. Go back and read my previous posts in this thread.
hanabie (10-22-2016), sato (10-22-2016)
Old 10-22-2016, 06:09 PM   #538
aegisdrgn
aegisdrgn's Avatar
Drives: Scion FR-S 10 Series #2263
Did you bother to read the post immediately after the post you quoted? The service manual calls for lubing that pivot.
aegisdrgn is offline   Reply With Quote
The Following User Says Thank You to aegisdrgn For This Useful Post:
sato (10-24-2016)
Old 10-24-2016, 12:02 AM   #539
sato
sato's Avatar
Very pissed, limited functionality. Hahaha
Old 10-26-2016, 10:48 AM   #540
Readytoxplod
Tire Destroyer
Drives: Firestorm+snail
Mine squeaked/crunched about a year ago, and gets worse when warm. Dealer serviced it,found nothing. Took it again a few months later, same problem and they lubed something in the pedal assembly and the problem went away. Now the problem has returned, and the dealer ordered these parts in the clutch pedal assembly to remedy the issue, all free under the 36k warranty.
-Su003-00974-Assist Rod B
-Su003-00979- Spring Assist 3
-Su003-00968- Bushing
-Su003-00973- Assist rod
-Su003-00969- Bushing A
-Su003-02937- Pin
-Su003-00058- Clip
I will post back to see whether it fixed it, although it is cold here now and the problem mysteriously went away again since it seems heat dependent.
322whp/273wtq
Readytoxplod is offline   Reply With Quote
The Following User Says Thank You to Readytoxplod For This Useful Post:
Oxyg3n (10-26-2016)
Old 10-26-2016, 11:24 AM   #541
sato
sato's Avatar
-Su003-02937- Pin
-Su003-00058- Clip
Anybody got a parts diagram for those components?
Old 10-26-2016, 12:19 PM   #542
Oxyg3n
Oxyg3n's Avatar
Drives: 2017 BRZ - WRB
-Su003-02937- Pin
-Su003-00058- Clip
Finally something that sounds like my problem! It does seem to start once the car warms a bit. Did yours start early? Mine started before the car even hit 1000 miles. Plus it's just the pedal not in the transmission like others are saying in this thread.
Sent from my SAMSUNG-SM-G920A using Tapatalk
Oxyg3n is offline   Reply With Quote
Old 10-26-2016, 02:31 PM   #543
That's the assist spring assembly. Won't help.
Old 10-26-2016, 03:24 PM   #544
sato
sato's Avatar
That is what I thought. Just wished somebody with more time and access to post them up.
Old 10-29-2016, 05:29 PM   #545
Readytoxplod
Tire Destroyer
No mine started at around 13,000 miles.
322whp/273wtq
Old 10-29-2016, 05:37 PM   #546
Readytoxplod
Tire Destroyer
Actually it did seem to help and the problem is gone. They replaced the spring and some of the pedal assembly and the squeaky crunch is gone, although it is getting cold here and the pedal squeaks/crunches when it is warmer and after driving a bit. The new spring was also pretty lubed up I noticed. I really was surprised they replaced all of this for free, parts included, since I was at 36k miles with an aftermarket clutch/turbo but I showed them that I had the issue before the aftermarket clutch and turbo was installed and the car was stock, so it was not a cause of a new clutch or throw out bearing.
Run to a dealer and get them to replace or lube the clutch spring and assist rod and bushing under warranty and it should fix it!
322whp/273wtq
Loud 'Squeak' Noise From Clutch? Brndn704 Issues | Warranty | Recalls / TSB 23 07-20-2020 09:58 AM
Upgraded Clutch Squeak Rybot Issues | Warranty | Recalls / TSB 116 10-09-2019 03:10 PM
Clutch pedal adjustment gone wrong? Clutch issues. PulpBrah Engine, Exhaust, Transmission 12 03-06-2017 05:08 PM
Clutch Squeak CatDaddysBBQ Issues | Warranty | Recalls / TSB 4 07-14-2015 07:44 AM
Clutch pedal squeak. merino_frs Engine, Exhaust, Transmission 1 08-25-2014 02:00 AM
