Old 10-19-2016, 08:22 AM   #477
Torry@HKSUSA
Torry@HKSUSA's Avatar
Drives: HKS
Originally Posted by Andew727 View Post
i have a v1 kit with a 100mm pulley and a 90mm pulley
100mm pulley is the one that comes with the kit. This is 12999-AK005. The 90mm pulley is the optional pulley. This is 12999-AK003.
The belt that comes with the kit and is for the 100mm pulley is a 6PK2440. The HKS belt this size has been discontinued.
There is no HKS belt for the 90mm pulley. You would just have to measure what you need and buy the correct one.
Torry@HKSUSA is offline   Reply With Quote
Old 10-19-2016, 11:42 AM   #478
Koj
Koj's Avatar
Drives: Toyota GT86
ok Torry (the table)
Thanks
Koj
S/C HKSv2, HKS R Spec Manifold, Fujitsubo Authorize R Type S Catback, and more...
My Journal/Garage
Koj is offline   Reply With Quote
Old 10-20-2016, 05:45 PM   #479
Efferalgan
Drives: 2025 BRZ, ex-2012 GT86
Nice Another confirmation that the V2 units are not supposed to live long enough to require the belt replacement
Efferalgan is offline   Reply With Quote
Old 10-21-2016, 08:06 AM   #480
Torry@HKSUSA
Drives: HKS
The V2 kits came with a 100mm pulley, so not sure how you can draw that conclusion.
The V2 and V3 kits use the same supercharger and as I mentioned before, we have yet to have anyone with a problem with the supercharger itself.
Old 10-24-2016, 06:03 AM   #481
Efferalgan
http://www.ft86club.com/forums/showp...&postcount=279
Old 10-24-2016, 08:50 AM   #482
Torry@HKSUSA
Drives: HKS
Sorry, I had the V1 kits and V2 kits mixed up. You are correct.
V1 kits came with the 100mm pulley (5-bolt). Belt size is 6PK2440.
V2 kits came with a 90mm pulley (1-bolt). Belt size is 6PK2110.
V3 kits come with a 110mm pulley (5-bolt). Belt size is 6PK2160.
V3 Pulley Upgrade is to a 100mm pulley (5-bolt). Belt size is 6PK2135.
The Following 3 Users Say Thank You to Torry@HKSUSA For This Useful Post:
Efferalgan (10-25-2016), Koj (11-17-2016), Yobiwan (10-26-2016)
Old 10-24-2016, 08:52 AM   #483
Torry@HKSUSA
Drives: HKS
There is no belt for the 90mm pulley on the V1 kits. Those kits used a 100mm pulley.
The V2 90mm pulley uses a 6PK2110 belt.
The Following User Says Thank You to Torry@HKSUSA For This Useful Post:
Old 10-24-2016, 07:15 PM   #484
empower-auto
Kouki-Monster
empower-auto's Avatar
If someone has a V2 with the restrictor off and the powerband is too peaky.. what is the next step? Smaller pulley with restrictor? Some sort of V3 frankenstein combo?
Boost comes on very late and of course when you don't hit boost until more than halfway through the tachometer, that linear crawl to max boost at redline leaves a very narrow window of good power. My 86 is gutless below 5800 and it's not a tuning issue
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 10-24-2016, 08:07 PM   #485
wbradley
Sarcastic SOB
wbradley's Avatar
I have a Frankenstein V1 kit with 100 mm stock pulley, restrictor delete and a much bigger intercooler (maybe 1/3 bigger). Boost does build in a linear fashion all the way to fuel cutoff obviously. My tuner set cutoff at 7000 RPMs as I didn't want to do fuelling upgrades and thats where the stock injectors max out.
I think of my power band as being like an S2000 but with higher numbers 276 WHP@7000, 209 TQ. Not gutless at all, still have to wring it, just that you get more out of it.
Alternately, theres the positive displacement setups where torque comes in low but thats a recipe for wheel spin and lost traction and IMHO not consistent with the cars character.
I think power the delivery being proportionate to the revs works for this platform. More power is useless if you cant put it down.
Sure a smaller pulley will bring on the power lower down with quicker boost, but consider the other factors involved. Right now the clutch should be fine. With higher torque earlier the clutch will wear faster and with more power the axles can go. And I am not sure how to keep early torque down unless you want max width rear tires which hurts handling.
I wouldn't personally go much higher than 9-9.5 PSI regards to boost restriction. My setup now appears to peak at 9.5 once but on a cooler day it read peak 10.5 at cutoff.
I have a 90mm pulley and injectors but decided not to bother installing them.
wbradley is online now   Reply With Quote
Old 10-25-2016, 08:19 AM   #486
Torry@HKSUSA
Drives: HKS
There is a V2 > V3 Upgrade kit. This is part number 12002-KK002. This comes with all the parts needed to convert to the V3 (pulley, new charge pipe, etc.).
Then if you still want more power, you can do the pulley upgrade kit, so long as you have the fuel and tuning to back it up.
Old 11-01-2016, 01:48 PM   #487
86socal
86socal's Avatar
Drives: White frs
I have uel headers, 60mm overpipe and front pipe and 3in single exit exhaust. Would I be able use my setup with this kit and run the e85 flash tune?
86socal is offline   Reply With Quote
Old 11-02-2016, 11:40 AM   #488
empower-auto
Kouki-Monster
I have upgraded pump and injectors.
I am running the V2 with no restrictor and am peaking at 11psi
If I install the V3 upgrade kit what boost will I be running?
This is another one of the things they couldn't / wouldn't answer for me on the phone.
The only way I want to upgrade to the V3 kit is if I'm not downgrading in terms of power. I want to run the same or a small amount more boost but with a better boost curve.
Rich Anderson
EMPOWER AUTO
Old 11-02-2016, 03:16 PM   #489
wbradley
Sarcastic SOB
wbradley's Avatar
Just get a smaller pulley.
Old 11-03-2016, 09:29 AM   #490
makinen
makinen's Avatar
Drives: Toyota 86
Hi,
I've tested acceleration of 86 with v3 installed.
[ame="https://www.youtube.com/watch?v=WQM5vNKuRiw"]HKS Supercharger V3 0-200km/h Test - YouTube[/ame]
What's your thought?
V3 + 100mm pulley (boost peak recorded is ~14.5 psi.)
RON98
225/50R16 Kumho 4X-II
makinen is offline   Reply With Quote
The Following User Says Thank You to makinen For This Useful Post:
Andew727 (11-03-2016)
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
Five Axis Edition FR-S Owners Thread digital_assassin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 563 07-08-2015 09:22 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
Supra Owners Build Thread BoostJunkie Other Vehicles & General Automotive Discussions 164 03-12-2012 09:37 AM
