Old 10-19-2016, 01:03 PM   #1
take the cannoli
Barefoot skidding
Drives: 2013 FR-S Whiteout 6MT
Clutch whine during cold start
Hi all. First of all, sorry if this is a repost but I did do a fairly extensive search into the issue but never really found anything conclusive.
Lately during cold starts my car has been making a noticeable whining noise, particularly when I press the clutch pedal. It does get higher in pitch as the revs increase but I never have a problem with engagement or shifting. The whining noise goes away after about 15 minutes when the car is warmed up. The clutch travel also feels completely normal except for a small clutch fork squeak. I am quite worried that this is an early sign of a bad throwout bearing or something like that. My car is a 2013 model with about 47k miles.
I have tracked the car in the past, but I was never did any hard launches or clutch kicks. Nowadays, I drive the car pretty gently and rarely rev the engine above 4000 rpm. I have a habit of short shifting and I don't ride the clutch.
Can anybody tell me what's going on here? Any help would be appreciated.
take the cannoli is offline   Reply With Quote
Old 10-19-2016, 01:19 PM   #2
Throwout bearing. You didn't break it. They just suck. Get it replaced before it kills the rest of your clutch.
Old 10-19-2016, 01:45 PM   #3
I concur^^^^^^^
Old 10-19-2016, 04:13 PM   #4
microbionic
microbionic's Avatar
Drives: 2013 Subaru BRZ
I concur^^^^^^^
Guess what happened to me today!!!!!!
... it was making a slight sound for about a month ... super quiet though.. only could hear it in the garage.... today it seized.
getting it towed to a shop friday.
microbionic is offline   Reply With Quote
Old 10-19-2016, 04:19 PM   #5
And that is the way of the TOB.
Old 10-19-2016, 04:44 PM   #6
wparsons
wparsons's Avatar
If it's making noise with the clutch not depressed, it shouldn't be the throw out bearing. Typical TOB symptoms are no noise clutch out, noise as soon as you start pushing the clutch.
flickr
Old 10-19-2016, 07:17 PM   #7
DJCarbine
Thupercharged
DJCarbine's Avatar
I've had cars where the TOB is in constant contact with the pressure plate fingers by design, and had the throwout bearing go bad... would make noise without touching the clutch pedal
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
Old 10-19-2016, 07:47 PM   #8
This is one of them.
Old 01-16-2022, 04:05 PM   #9
iag48st
Drives: 10Series 0945
Old thread I know …
Is it possible that Cold starts during the cold winter months cause the TOB to make the whirring sound when pressing clutch? It goes away after car is warmed up. Clutch feels fine, no issues shifting.
iag48st is offline   Reply With Quote
Old 01-17-2022, 04:52 PM   #10
Originally Posted by iag48st View Post
Old thread I know …
It is never acceptable for a bearing to make any noise. It is failing now and won't improve on its own.
Old 01-20-2022, 12:21 AM   #11
demasrv
demasrv's Avatar
Drives: 2013 Rally Blue BRZ
Yeah likely the TOB. I'm mid rebuild and mine had been making a noise. It was very "crunchy" spinning it once I had it out.
demasrv is offline   Reply With Quote
Old 09-28-2023, 01:32 AM   #12
Thanasis
Thanasis's Avatar
I have same car and observation. Did you ever figure it out?
Thanasis is offline   Reply With Quote
Old 09-28-2023, 08:21 PM   #13
soundman98
ProCrastinationConsultant
soundman98's Avatar
did you read the thread?
Old 09-29-2023, 01:04 AM   #14
OMG that's too hard!
clutch whine
Clutch Engage Whine? PDM 2 Issues | Warranty | Recalls / TSB 12 10-25-2016 03:11 AM
The dreaded clutch whine RichardsFRS Issues | Warranty | Recalls / TSB 10 06-08-2016 06:44 AM
Clutch Rattle at cold start shellslinger Issues | Warranty | Recalls / TSB 16 10-11-2015 01:45 PM
RPM varies, cold start, clutch in and out 00NissanNinja Issues | Warranty | Recalls / TSB 8 03-04-2014 11:40 PM
White Smoke cold start up in Cold Weather (turbo cars) whitefrs Forced Induction 17 09-25-2013 05:05 PM
