Old 10-19-2016, 03:49 PM   #1
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
2017 Toyota 86 Build - FT-86 SpeedFactory
86 Overview Video
[ame="https://www.youtube.com/watch?v=NxsPPIhDzyg"]FT86SpeedFactory - Toyota 86 Overview - YouTube[/ame]
We got one of the first Toyota 86's in the US about a month ago, and knowing us it won't stay stock for long. We've only put 50 miles on the odometer so far, but these are the changes we've noticed from the old FRS/BRZ.
Exterior
The new 86 is still the lightweight, fun to drive, balanced sport coupe we all remember but with a more modern and refined appearance. The changes go much further than the very debated front bumper styling, and to be honest it’s not bad once you see it in person. The new front end increases downforce from the larger chin spoiler and side canards. So even if you’re not pleased with the new look, you at least know it’s more functional.
Along with the new front bumper are full LED headlights with integrated DRL and turn signals which really cleans up the front end of the car. Around back are a pair of completely redesigned LED tail lights that have taken some styling cues from popular aftermarket lights.
And if you stare at the back of the car long enough, you’ll notice a very small difference in the rear bumper diffuser and redesigned tail pipes. There are also a new set of ten spoke wheels that use the same color combination as before but with a less cluttered design.
Powertrain
We didn’t get the turbocharged engine we all were hoping for, but we did at least of a bump in power. A very small bump however. The new red aluminum intake manifold and revised airbox together, produce a whopping five horsepower gain. While it isn’t much, the new red intake manifold does make you feel better about opening up the hood and showing off the engine bay.
The more noticeable performance increase will be from the new final drive gear. They’ve switched from a 4.10 gear ratio to a shorter 4.30 which multiples torque output, something these engines really needed, and it helps get into the powerband quicker. This should make 0-60 times faster, but we’ll report back on that after we’ve finished our full review.
Interior
Toyota has ramped up the material quality on just about every interior piece you come in contact with. We finally get the leather accent interior panels that were previously only available in Japan as well as new silver stitching found on nearly every interior panel.
However the biggest interior changes are the suede like material Toyota calls “Gran-lux” dash trim and smaller diameter leather wrapped steering wheel with stereo controls. Connected those new steering wheel controls is a touchscreen head unit that also displays the new standard backup camera.
Conclusion
All these changes come at a cost of only $155 over last year’s FR-S, which is an astonishing deal for all improvements offered. But for us gearheads all these improvements are still not enough. We want more power, more grip, and a more aggressive look. So over the next few months we’ll be taking matters into our own hands and modifying our new 86 with all the goodies the aftermarket has to offer. And you can follow our build progress right here.
FT-86 SpeedFactory is offline
The Following 7 Users Say Thank You to FT-86 SpeedFactory For This Useful Post:
Chaetagnath (01-06-2017), DAEMANO (10-19-2016), ichitaka05 (12-13-2016), irxproductions (05-31-2017), MJones_RB (04-24-2017), Rampage (10-19-2016), weederr33 (10-19-2016)
Old 10-19-2016, 03:53 PM   #2
FT-86 SpeedFactory
With only 15 miles on the odo, it was time to start getting this thing broken in. After messing with these cars for 4 years now, it was a pleasure to see and feel the changes Toyota has made to the car. A good amount of gripes have been answered!
Of course, not everything has been addressed, so it is far from perfect. The improvements are a great sign for the platform and we hope the enthusiasts take note. Sales numbers will dictate the future of this car and we know we aren't the only ones hopeful for a true second generation!
2017 Toyota 86 Drive Review
[ame="https://www.youtube.com/watch?v=Xqw_LjXPZ_o"]FT86SpeedFactory - Toyota 86 Overview - YouTube[/ame]
Old 10-19-2016, 03:54 PM   #3
FT-86 SpeedFactory
2017 Toyota 86 Sidemarker Install
[ame="https://www.youtube.com/watch?v=s7jDdcTC_U0"]FT86SpeedFactory - Toyota 86 Overview - YouTube[/ame]
The first modification on this build was a quick and easy side marker. We don't like the orange factory side marker that come on cars imported to the US and Canada, so it was the first thing to go.
However we had a new options to replace it with. Overseas in Japan they have a clear version but we wanted to do something a bit different.
GCS makes a unique LED marker that come in both clear and smoked styles. And have two side facing amber LEDs as well as a forward facing white LED light bar.
But we ended up with a simple and clean smoked side marker from Helix. It complaints the Steel Silver paint of our 86 perfecting. While we were in there, we also upgraded the light bulb to white OLM LEDs for much brighter illumination.
The Following User Says Thank You to FT-86 SpeedFactory For This Useful Post:
Old 10-19-2016, 03:55 PM   #4
FT-86 SpeedFactory
86 Suspension and Wheels
[ame="https://www.youtube.com/watch?v=bIVobRPdXpU"]FT86SpeedFactory - 2017 Toyota 86 Build Beginnings - YouTube[/ame]
Something had to be done about the large fender gap these cars have in stock form. We needed to drop the ride height at least a couple inches, not only to make it look better, but to also lower the center of gravity to perform better around the twisties.
Normally if we wanted to drop the ride height quickly and easily we would just throw on some lowering springs because they’re a great bang for buck option. But for this build, we wanted the adjustability of coilovers so we can fine tune the suspension to our liking.
That’s why we went with the Fortune Auto Prime Coilover system, which will let us individually adjust the ride height, dampening, and front camber. Since they come with 6k (336 lbs/in) spring rates front and rear, we won’t have any issues with body roll under hard cornering.
With the Prime coilovers installed we went ahead and maxed out the camber plates in the front. But to get matching negative camber in the rear, we installed RSR adjustable lower control arms. The only problem with lowering and adding negative camber in these cars is the rear toe goes way out of alignment. So we fixed it with our Velox/FT86SpeedFactory toe arms, that let us correct the toe out in the rear.
To finish off the look we installed a limited edition 17x9.5 +40 Volk TE37V-SL in double pressed black with 255/40/17 Bridgestone RE71, as well as a carbon fiber SARD LSR wing.
The Following 5 Users Say Thank You to FT-86 SpeedFactory For This Useful Post:
eblamble3 (12-14-2016), mmmcambelsoup (12-15-2016), R2RO (10-23-2016), rcm47 (03-17-2017), SkAsphalt (10-24-2016)
Old 10-19-2016, 03:56 PM   #5
FT-86 SpeedFactory
86 Fog Light Install
[ame="https://www.youtube.com/watch?v=xLSZA2VN1VY&feature=gp-n-y&google_comment_id=z12oivkgxteue30q104ciljjeujcun o4myc0k"]FT86SpeedFactory - 2017 Toyota 86 Fog Light install - YouTube[/ame]
At the time of this post, it will be very rare, if not impossible to find an 86 with fog lights in the US. Ours may very well be the first 2017 86 in the US with OEM fog lights.
It’s nearly impossible to find them on cars today, because the US market doesn’t get a fog light option. That’s why we put together our own kit using Toyota’s fog light bezels from Japan.
We’re not quite sure why the US missed out on this option, but it wasn’t very difficult to install, since every 86 already comes with the necessary harness to plug into. The most difficult part of the process was splicing in two wires for the ON/OFF switch and drilling a 20mm hole to mount the switch next to the trunk release button. Which was a very simple task and is something you could easily accomplish during your lunch break.
The fog light bezels retain the same aggressive canard design as before, and the lights are LED just like the headlights, so the color temperatures matches perfectly. However if you want to create a distinctive look, you could add Lamin-X covers to tint it Amber, Yellow, Blue, Green, Smoke, and even Pink.
Adding OEM fog lights to an 86 couldn’t be easier and the entire process shouldn’t take more than a couple hours. When it’s all said and done, no one will ever know your car didn’t come like this from the factory. Unless of course they read this post.
Old 10-19-2016, 04:18 PM   #6
weederr33
Airborne at your service
weederr33's Avatar
Drives: '17 BRZ Series.Yellow
So when are you throwing that turbo kit of yours on this car?
MS, CSCS, TSAC-F, CPT
weederr33 is online now
Old 10-19-2016, 05:00 PM   #7
Zaku
-Proud of Brzerhood-
Zaku's Avatar
Drives: '17 BRZ CWP LMT.
I totally looking forward to this Yo and Jeremy! Subbed !!!!
Zaku is offline
The Following User Says Thank You to Zaku For This Useful Post:
raven1231 (10-19-2016)
Old 10-19-2016, 06:12 PM   #8
beat1
beat1's Avatar
Drives: 2022 BRZ
While in Canada they are 2k more from 2016 sub'd!
beat1 is offline
Old 10-19-2016, 06:30 PM   #9
raven1231
Same!
raven1231 is offline
Old 10-19-2016, 06:32 PM   #10
Mr. Kurtz
Mr. Kurtz's Avatar
Drives: None
Excellent, I'll be watching this with interest. I picked up my 86 back in mid September, and I've been carefully considering upgrades. Not coming from an FRS, I can't speak to the changes from a function standpoint, but I'm a big fan of the aesthetic changes.
Mr. Kurtz is offline
The Following User Says Thank You to Mr. Kurtz For This Useful Post:
Old 10-19-2016, 07:15 PM   #11
FT-86 SpeedFactory
Second post updated with drive review
Old 10-20-2016, 06:14 PM   #12
CMEJATT
CMEJATT's Avatar
Drives: 2017 6M/T Limited CWP BRZ
in for more post
CMEJATT is offline
Old 10-21-2016, 07:19 PM   #13
FT-86 SpeedFactory
Third post updated with new suspension and wheels.
Old 10-21-2016, 07:52 PM   #14
Resolute
in the recliner of rage
Drives: Asphalt FR-S
This. Is that project dead? It looked promising.
Resolute is offline
The Following User Says Thank You to Resolute For This Useful Post:
Trust86 (03-28-2017)
CSG Mike's personal 2017 BRZ build and thoughts. CSG Mike Member's Car Journals 235 09-10-2019 12:03 AM
2017 Toyota 86 Driftz Southwest 3 06-04-2016 03:52 PM
FT-86 SpeedFactory - Firestorm Red - Build Thread FT-86 SpeedFactory Member's Car Journals 38 02-26-2015 03:42 PM
FT-86 SpeedFactory Vortech Supercharger Build FT-86 SpeedFactory Forced Induction 91 09-26-2013 09:02 AM
>>FT-86 SpeedFactory One Lap of America Build<< FT-86 SpeedFactory FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 84 05-23-2013 05:22 PM
