Old 10-15-2016, 08:00 PM   #1
amartinez9881@gmail.com
amartinez9881@gmail.com's Avatar
Drives: Scion FRS
New Toyota 86 steering wheel
Hey guys,
I was curious is any one has the part number for the new 86 steering wheel with the audio controls in it, I really like it and I'm trying figure out if it will be compatible with the older models.
amartinez9881@gmail.com is offline   Reply With Quote
Old 10-15-2016, 08:48 PM   #2
djwishbone
Last Starfighter
Drives: 2016 FR-S Series 2.0
I would rock one of these too, I'm willing to bet with airbag you're probably looking at $2K
djwishbone is offline   Reply With Quote
Old 10-15-2016, 11:25 PM   #3
HachiRo
Drives: 2013 White-Out FRS
I initially was envious of the idea of the audio controls. Now I realize with how small the car is, I could just not be lazy and reach a bit to control the audio, lol. Simple steering wheel = more racecar feel LOL. Or, you know.
I live my life one quarter-pounder at a time.
HachiRo is offline   Reply With Quote
Old 10-16-2016, 01:28 AM   #4
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
More racecar feel? Have you seen a race car steering wheel?
nextcar is offline   Reply With Quote
Old 10-16-2016, 02:03 AM   #5
HachiRo
Okay, bad choice of words, but I appreciate the simplicity haha.
Old 10-16-2016, 02:49 AM   #6
johan
Drives: '14 981CS, '99 NB1
Originally Posted by amartinez9881@gmail.com View Post
Hey guys,
You'd need, at a minimum:
- Steering wheel
- Air bag
- The appropriate wheel controls setup (there are the two different sides, and obviously 86/BRZ Limited get different setups - you probably need the left side buttons and the right side blank since the right side is for the new screen on the BRZ Limited)
- Clock spring
- Wiring harness on the steering column
And then you'd have to wire into that wiring harness somehow... if it's even possible to get that harness in the first place. Oftentimes these things are all part of an expensive, large, one piece harness that is simply attached to the dash or even worse - the body harness itself.
So that is to say that it is likely possible, but quite difficult to do cleanly / correctly.
johan is offline   Reply With Quote
Old 10-17-2016, 12:46 AM   #7
Drives: Scion FRS
To lazy to reach my finger get tired.. Lol but it just easier wile driving not having to get over a bit to reach or having to fidget with my phoen to go to next track . I change tracks a lot!
Old 10-19-2016, 03:51 PM   #8
Julia@SimplicityInSound
Drives: 2013 Scion FRS
Another option is to make your own like I did using factory KIA controls and wiring, and a little bit of fabrication...
http://www.ft86club.com/forums/showt...t=39244&page=5
Last edited by Julia@SimplicityInSound; 12-20-2016 at 11:01 PM. Reason: Fixed broken image link
Julia@SimplicityInSound is offline   Reply With Quote
Old 10-19-2016, 04:04 PM   #9
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Since the Canadian market 2017 BRZ came with the prior American BRZ limited radio (with NAV) I wonder how hard it really would be to retrofit the steering wheel seeing as they're the same radio and both LHD..... hmmmmm
Old 10-19-2016, 04:26 PM   #10
Good call. May be as simple as ordering a 17 Canadian wiring harness.
Old 10-27-2016, 08:29 AM   #11
chaoscentral
Drives: 2013 Scion FR-S Series 10
- Steering wheel
- Air bag
- Clock spring
Actually I don't think that you would need a new clock spring. The one in the FRS/BRZ is sourced from the 2012+ Subaru Impreza, it is also identical to the 15 WRX. The plugs are there to pass the data through, just need to either rewire if the plug is different, or if the clock spring didn't change it would be plug and play on the wheel side, all that's left at that point is to wire from behind the steering column to the radio.
The 2014+ FRS headunits actually support SWC since it's a radio used in a bunch of Scion models, and same with the BRZ, that radio is used in the WRX and Forester.
Current Mods: Eibach Sportlines/ Borla UEL Header/ Invidia N1 Catback/ OFT Stage 2 UEL E85 Tune/ Enkei EDR9 18x7.5
chaoscentral is offline   Reply With Quote
Steering Wheel Aigbag w/ Toyota Emblem AG3NT_5CARFAC3 Interior Parts (Incl. Lighting) 6 12-28-2015 05:38 PM
toyota 86 gt used steering wheel red/black (sold) genesis86 Interior Parts (Incl. Lighting) 2 04-03-2015 01:52 PM
FS: Steering Wheel Toyota Emblem FRS_Jack Interior Parts (Incl. Lighting) 3 07-01-2014 03:29 AM
Steering wheel emblem subie or Toyota? Mrqb22 Cosmetic Modification (Interior/Exterior/Lighting) 11 09-27-2013 09:17 AM
Cover up Toyota sticker for steering wheel? liajet24 Cosmetic Modification (Interior/Exterior/Lighting) 4 09-17-2013 06:02 PM
