#15 | |
Drives: 2015 Scion FR-S
Voodoo now includes a spacer pack with their arms because they were finding manufacturer discrepancies between the left and right side, and multiple cars. If you don't need to use them, then don't. Chances are that you'll have to use them though. |
#16 |
Because compromise ®
Drives: Red Herring
What is being patented?
#17 |
#18 |
Making Oilfield Cash!
Drives: 2015 BRZ Limited
I ordered these last week and will be installing them with KW V3 coilovers soon. So to do a "street" alignment of -2 degrees or less I'll need adjustable toe arms as well?
#19 |
Simply lowwering the rear 1.5-2'' should cause the rear suspension to camber out to -2.
I was able to get my rear alignment correct, lowered, at -2 camber with the stock camber rods. |
| The Following User Says Thank You to mike the snake For This Useful Post: | OilFieldTrash (12-13-2014) |
#20 |
Drives: FAT H8R Hot Lava FRS
Bump and Update, I have also had the Voodoo13 RLCA's for quite sometime almost 2 years now as well as the toe and trailing arms as well putting on mileage and track abuse on them and they have been great! These also have a more durable finish and superior hardware as well. I did have other LCA's on the car before and I definitely liked these the best compared to other ones before
#21 |
Drives: 2014 Monogram Scion FRS Whiteout
Kinda late to the post but has anyone faced any knocking sounds after installing the LCA and toearms. I habe BC racing BR coilovers.
#22 | |
Drives: FR-S TRD RS1#1488
http://www.ft86club.com/forums/showp...5&postcount=11 |
#23 | |
I ended up putting the car back to stock and I sold these arms to my buddy and he installed them, and they knocked on his car too. My educated guess is that it's the spherical rod end resisting spinning, binding slightly, then letting itself rotate and cause a dull clunk. The only time these things stopped making noise on my car is when I daily drove the car. This was mainly a weekend/good weather car, so daily driving was rare, but when I did the noise got quieter and then eventually stopped. I parked the car for a week then drove it again and the popping some came back. |
#24 |
Drives: '13 FRS - STX
I had knock too, it was my sway bar end links, ended up grinding them down a bit too insert shims in like the op did on the first page, but they were quiet without shims after grinding them for a bit of clearance. Totally counterintuitive but that's the way it goes sometimes, lowering plus an LCA seems to make the oe links not happy.
I was going crazy thinking it was the damper and my custom spring setup, thinking maybe it was the lca (Racer-X), but yeah, swaybars man. Quick check is to take out one endlink and go for a drive, if the clunk disappears you found your problem. |
#25 | |
| The Following User Says Thank You to Travisty75 For This Useful Post: | strat61caster (10-23-2016) |
| DME Lower Control Arms and DME Toe Arms - Review | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 23 | 02-24-2015 11:53 AM |
| CrossoverAuto.com - FRS/BRZ/86 Voodoo13 Rear Lower Control Arms | Crossover Auto | Brakes, Suspension, Chassis | 7 | 05-18-2014 07:02 PM |
| SPL Arms - Brand New! - Rear Lower Control Arm + Rear Toe Arm w/ Eccentric Lockout | quiet-k | Brakes, Suspension, Chassis | 8 | 03-22-2014 10:17 PM |
| ISC Rear Lower Control Arms | FT-86 SpeedFactory | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 09-26-2013 09:47 AM |
