go_a_way1
Old 10-17-2016, 09:49 PM   #3711
ShawnP19
ShawnP19's Avatar
Drives: 2016 Series.HyperBlue BRZ
@hamlet I'll be interest
Sent from my SM-G900V using Tapatalk
ShawnP19 is offline   Reply With Quote
Old 10-19-2016, 01:44 PM   #3712
zypher
Drives: WR Blue BRZ
When tracking our cars with the supercharger, what fuel do you use?
The manual recommends half a tank of race gas, but the track I go to does not have pumps yet so I run 93.
Is it worth putting in octane booster for track days?
zypher is offline   Reply With Quote
Old 10-19-2016, 02:40 PM   #3713
CounterSpace Garage
CounterSpace Garage's Avatar
Drives: Subaru BRZ / Toyota 86 Experts
93 Octane is far better than 91 ACN fuel we have in the west coast. We have consistently seen more power gain from the east coast brethren than the west coast simply because of the fuel quality.
CounterSpace Garage is offline   Reply With Quote
The Following User Says Thank You to CounterSpace Garage For This Useful Post:
funwheeldrive (10-20-2016)
Old 10-19-2016, 09:31 PM   #3714
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
I used 109/93
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
Old 10-20-2016, 07:44 AM   #3715
RevoG
RevoG's Avatar
Drives: Hot Lava 86 MT
Make sure your belt is properly aligned; a mis-aligned belt can put abnormal stress on the pulleys.
Mike, how do I go about changing the alignment if it is out?
JR Supercharger, JR RS Pulley, JR Oil cooler, JDL UEL header, Dual resonated 3" JDL Overpipe Front pipe, Perrin 3" resonated cat back exhaust, Upgraded Koyorad radiator, ECUTek tune, Enkei RS05RR 18x9.5, Bridgestone RE003 265/35/18, KW V3 Coilovers, Valenti sequential taillights, Kartboy short shifter kit
RevoG is offline   Reply With Quote
Old 10-20-2016, 04:51 PM   #3716
CSG Mike
CSG Mike's Avatar
Make sure the 6 ribs on the belt are sitting in the 6 grooves on the grooved pulleys. The car can run with 5, or even just 4 in the grooves, but you want to always have it perfectly aligned with 6.
if it is off, release your belt tensioner, and adjust by hand (make sure the engine is cool so you don't burn yourself).
Old 10-24-2016, 07:58 AM   #3717
RevoG
RevoG's Avatar
all 6 ribs are sitting fine but it looks like the belt is being pushed in. Like the SC needs to be spaced out
Will try to get a pic and post it
Old 10-24-2016, 12:27 PM   #3718
JDMChris
Drives: 2016
Send a message via AIM to JDMChris
You have any aftermarket pulleys?
JDMChris is offline   Reply With Quote
Old 10-26-2016, 03:53 AM   #3719
RevoG
RevoG's Avatar
No, just the JR High boost pulley.
But it seems I have found the problem. The bracket holding the SC is bent. I have no idea how that is even possible. I am in the process of having one machined from SS to replace the bent aluminium one. Once i have the old part back from the shop I will send it to JR and ask them about it.
I cant wait for a replacement as this is my DD and I need my car.
Pic for attention....
Old 10-26-2016, 02:26 PM   #3720
Jackson Racing
Jackson Racing's Avatar
Drives: JR FR-S,
Please contact us at tech@jacksonracing.com and we can work with you on what's going on here. Billet aluminum doesn't just... Bend.
Jackson Racing is offline   Reply With Quote
Old 10-27-2016, 01:58 AM   #3721
Bramick
Bramick's Avatar
Looking for suggestions for a squeaky pulley or belt. I just swapped the c30 for a 38. While I had room I clean out a lot of dirt and junk from the engine using paper towels with degreaser applied to them. I also removed the pulley above the tension pulley and cleaned it with degreaser. It was pretty caked.
My belt is a little over a year on on approx 14k miles. Since priming the SC I have heard the noise. The noise can be heard on starts and peaks between 2000 - 4000 rpm. While driving if you quickly let off the gas it gets a lot quieter. If you hold the RPMs steady the noise remains.
Tonight I removed the tension pulley and a lot of dirt fell out of it. I was surprised how much. And I also removed the pulley below the alternator. I cleaned both with shop towels and nothing else. I also flipped the belt to the other side.
Started the car and it squeaked so I gave up for the night.
The idler pulley does bounce but I thought that was normal.
Any suggestions on what to try next?
Old 10-27-2016, 06:05 AM   #3722
RevoG
RevoG's Avatar
I will definitely contact you guys directly. I will be picking up the car tonight from the workshop and will then be able to send you pics of the part.
I agree that the plate should not just bend so there must be something else going on. Thing is I have had the SC installed for 2 years now and absolutely no problems.
Old 10-27-2016, 12:41 PM   #3723
JDMChris
Drives: 2016
Degreaser is most likely causing the noise.
The Following User Says Thank You to JDMChris For This Useful Post:
Bramick (10-27-2016)
Old 10-27-2016, 01:56 PM   #3724
Bramick
Bramick's Avatar
So did I kill that pulley bearing or can that be corrected?
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 05:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 10:04 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 04:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 05:14 PM
