#1611 |
Drives: Subaru BRZ Limited M/T
Need to buy the new one first. Still waiting on an availability date for the EL JDL.
I may look at the Nameless header? Or a clone there of. Sent from my iPhone using Tapatalk |
#1612 |
Drives: Honda Accord Euro
What is the current status on Catted EL header? What revision is the newest and is there a dyno for that?
Also, have anybody tried Catted EL with ultra-quiet midpipe; or even with JDL Catback? Thanks |
#1613 |
Drives: 2013 Scion Frs 6mt
that would be interesting to hear... jdl uel catless, berk op, berk hfc fp, perrin 2.5 res here... do catted headers make a difference in sound quality? lol
#1614 |
JDL Equal Length header is here. If I can ever catch the Fedex truck.
#1615 |
Drives: 2017 Audi S3
I ordered a catted UEL this spring and have to say that I have been disappointed with the fitment. When it was first installed, the bottom of the header was rubbing on the skid plate, which was very noticeable at idle and taking off from a start. Climbed back under the car, removed the skid plate, tried and mostly failed to dent the area of the skid plate that was making contact and ultimately decided to install a spacer for some more clearance. That helped the problem slightly, but now I have an obnoxious rub/rattle noise, specifically around 2500 RPM.
Back under the car I went to assess, and here is what I found: ![]() ![]() ![]() As you can see, the rubbing has taken out approximately a quarter inch off of the skid plate and completely wore off a section of the ceramic coating: ![]() As you can tell by the first picture, I also have an exhaust leak at the overpipe connection, which wasn't a huge surprise given how difficult those bolts were to tighten due to the position of the cat. The two bolts for the header-overpipe connection, which were supplied with the header, were also too long. Not having a way to cut the bolts in my toolbox, or access to another car during install, I just tried to make the best of it. The end of one bolt starts to dig into the cat as you tighten: ![]() The other bolt is bending the base of the O2 sensor: ![]() I love the sound of the header and the improvement in eliminating the torque dip, but I was not expecting so many issues from a top of the line header. Please help @JDLAutoDesign . |
#1616 |
Ohne Titel
Drives: 2017 BRZ PP ISM
Subscribed.
#1617 | |
Drives: 13 FRS
These headers are built in a fixture and we have a height checker to test for skid pan clearance. I don't know if the fabricator just didn't check it or what. I apologize for the issues, you should not be having any so we'll get it taken care of ASAP for you. If anyone has any issues please do not hesitate to Call or email direct with any questions! Jesse |
| The Following User Says Thank You to JDLAutoDesign For This Useful Post: | immaculate (10-03-2016) |
#1618 | |
Drives: 2013 GBS BRZ Limited
![]() EDIT: Just saw their post above
APEXi / JDL / Perrin / Grimmspeed / Tein / Hotchkis / TRD / RAYS / Michelin / Raceseng / JPM Coachworks / SWEIDIT / Carsmo / TOM's / OFT / OEM Audio
#1619 |
What type of HFC JDL uses in header and ultra-quiet midpipe?
I have to say JDL's support is not good. No response to mail, PM, or here. |
#1620 |
Senior Misanthrope
#1621 | |
Drives: 13 FRS
We use Magnaflow 200 cell cats typically but have used Eastern Cats for a few customers that wanted a higher (400) Cell cat for emissions purposes. If there's anything I can do to make up for it please let me know! Jesse |
#1622 |
Drives: frs
I have found JDL customer service to be excellent. Helped me solve a problem with speed and grace. Great company from my experience!
#1623 | |
- Have you ever tried Catted EL with ultra-quiet midpipe and with JDL Catback? Basically your full exhaust combo. - Do you have any current version catted EL dyno available - Are these spun cats you are using reliable? Don't they cone? Or possibly do magnaflow or other twisted cores? But maybe it is fine. I think two quality 200 cels will be fine! |
#1624 | |
Drives: 13 FRS
| JDL Auto Design | ft_sjo | User/Vendor/Sponsor Reviews, Feedback, Comments | 58 | 04-28-2017 10:13 AM |
| JDL Auto Design | alexand3r | User/Vendor/Sponsor Reviews, Feedback, Comments | 4 | 12-11-2013 12:05 PM |
| New Scion FR-S products by Coverking are now at TAP Auto parts | TAP Auto Parts | Interior Parts (Incl. Lighting) | 9 | 06-06-2013 07:43 AM |
| Check out some of the new products from Auto Finesse | DetailersDomain | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 2 | 05-08-2013 08:42 AM |
| JDL Auto Design...What We Do | JDLAutoDesign | Announcements, Contests, Giveaways | 21 | 10-30-2012 09:05 PM |
