Old 10-14-2016, 04:01 PM   #407
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Originally Posted by continuecrushing View Post
Looks like sports car is a pretty loose term...
Seriously, it's amazing that anything over 2,500 lbs gets called a sports car. Such a shame how we've lost what makes a sports car a sports car.
ineedyourdiddly
The Following 4 Users Say Thank You to strat61caster For This Useful Post:
krayzie (10-14-2016), new2subaru (10-14-2016), Tcoat (10-14-2016), why? (10-14-2016)
Old 10-14-2016, 04:03 PM   #408
steve99
Drives: FT86
I doubt it would affect fuel consumption. Quite a few guys are running 5w30 or heavier in their track cars. To my knowledge, all new cars use 0w20. Perhaps it saves wear when people drive them cold? Unless you have a good reason to switch(like the oil can't handle track heat) other than saving 5$ every oil change... I'd stick with OEM recommendation. I'm sure they decided on that viscosity for a reason. Maybe manufacturing tolerances have gotten tighter and needs the super watery synthetic oil to get into the gaps that conventional oils from the 90s can't
OEM recommendation is
"An oil of higher viscosity is recommended if vehicle is used as high speeds and loads" or similar wording in Australian vehicle manual.
see here different wording in vehicle manuals different countries
http://www.ft86club.com/forums/showp...5&postcount=40
notout86 (10-14-2016)
Old 10-14-2016, 04:05 PM   #409
yelsew
Little Member
yelsew's Avatar
Drives: Bloo - The 13' BRZ
Originally Posted by spralwers View Post
If anyone has any explanations, I would like to hear
If i hearken back to my powertrain systems class, think about the power output of those engines and less about the displacement. power out has to be more or less scaled by power in. the differences between engines that have better or worse ratios of this has to do with the vehicle's overall efficiency (engine losses, drivetrain losses, aerodynamics) a 90's camry v6 for example: just over 180 at the crank if i remember right. the japanese automakers were pretty good at making efficient engines so this is a decent enough comparison. the amount of power in (amount of fuel in) is indicative of the power out. so similar or better numbers than a car outputting 200 hp isnt too surprising. (setting aside weight, Cd, drivetrain configuration, engine tuning goals)
Edit: i read that post back after posting...im not sure if i make much sense, or if im just rambling again
<--- My Journal
People just need some #drivermod in their life.
yelsew is offline   Reply With Quote
The Following User Says Thank You to yelsew For This Useful Post:
spralwers (10-18-2016)
Old 10-14-2016, 04:11 PM   #410
...Granted, I think mostly its the drivers lol.
It's really more a combination of driver and road's driven. If you give any vehicle to the same group of drivers you will have an almost exact equal distribution of fuel mileage we see here. That's because real world is just that, real world, and that is different for everyone.
For example, nearly every car I have had as a DD I get at or above the "combined" EPA rating. That's because my commute almost mirrors the standard used for the combined. It is pretty constant for me, and would be regardless of what I drive.
Others that drive in the city, or stop and go, are going to get lower, no matter what they drive.
On the FR-S, I get above the highway rating on average which is an anomaly I admit. I remain amazed at the MPG I get because I do NOTHING to earn it other than not drive in stop and go. I really expected to be around 28 (the combined) at best.
As far as the "its a sports car, why do you care?". Well, after having driven well over a million documented miles in my life, I have found that regardless of what you drive paying attention to the fuel mileage tells you how the car is performing.
If I was driving a Lambo or a Ferrari I would still "care", I just have realistic expectations of what I'm caring about. For example, a Aventador is rated at 11/18. I would want to get in the middle but would only be concerned if it dropped below 11, assuming my current driving habits.
Heck, I even do that with my lawn mower. I know I can cut my grass twice on a single tank of fuel. If suddenly I had to refuel after once, I'd be looking for a leak.
strat61caster (10-14-2016)
Old 10-14-2016, 04:25 PM   #411
strat61caster
When my FR-S mpg drops below 11 I know I'm doing something right with my life.
ineedyourdiddly
Old 10-14-2016, 08:14 PM   #412
notout86
Drives: GTS 86 auto
Thanks for spotting that statement steve99. I missed it. It does somewhat contradict where they state "However it (5W-30) should be replaced with 0W-20 at the next oil change." .... the underline of "should" is mine.
Bottom line is 5W-30 is OK , so I will switch to Castrol Edge 5W-30 SN synthetic, especially as it never gets very cold where I live and it was on special at half the price of Toyota's and Subaru 0W-20. (Actually I have been Honda's 0W-20 synth SN GF5 at $55 for 5L.) Pity I did an oil change only 2 days ago.
BTW , this time I used a Ryco Z79AST which uses a synthetic medium claimed to filter 99.8% of particles >25microns and suitable for extended changes to 15000km and has teflon on the seal. It only costs a few dollars more so I will change it every second change at around 9000km. Another thing I noted with this Ryco was a plating on the metal part with the thread. I always run my finger around the thread to remove machining-metal shards which I always found ... but not this time!!
GTS86 Auto (Australia)
Old 10-15-2016, 05:18 PM   #413
steve99
Drives: FT86
The other statement in Aussie manual is
" 0W20 is filled into your Subaru vehicle at manufacturing and the best choice for good fuel economy and starting is cold weather" so you can deduct from the two statements that if you want best economy and easy starting in cold (their likely taking sub zero temps) weather go 0w20. If you drive hard/track in hot climate then 5W30 is likely the better choice if you don't run oil cooler as you going to see oil temps in 120C plus region
Old 10-15-2016, 09:17 PM   #414
Sapphireho
Famous Potatoes
Sapphireho's Avatar
Drives: '15 ultramarine
I am getting about 15 mpg with e85, but boy is it a fun 15 miles.
Old 10-15-2016, 09:37 PM   #415
notout86
Drives: GTS 86 auto
It has just occurred to me that running thicker oil will cause the engine to heat up faster, thus reducing fuel consumption during the warmup period. These cars warm up more slowly than my previous under the same conditions and the thin oil may be a reason. The previous car used 10W-40. For people who do a higher proportion of short trips from cold, e.g. < 7Km back and forth to work 5 days a week, 5W-30 might actually reduce their consumption a bit.
Over time these considerations add up.
Old 10-15-2016, 09:51 PM   #416
Yep. Over 10 years or so the difference would probably be a whopping $10 or so.
Andrew025 (10-16-2016)
Old 10-15-2016, 11:41 PM   #417
Old 10-16-2016, 02:59 AM   #418
Well, now, notout86, that just makes no sense to me.
It would seem to me to be just the opposite.
Then you site an apple / orange thing ....... YIKES!
I know that water swirls in a different direction going down the sink down there, but give me a break .......
Old 10-16-2016, 04:03 PM   #419
mrg666
pessimistic skeptic
mrg666's Avatar
This thread started as nonsense and getting worse everyday. Lock or delete it please.
Old 10-16-2016, 04:10 PM   #420
Ashikabi
Ashikabi's Avatar
The small amount of research I did states that thinner oil is used to increase fuel economy. Going to a thicker oil would do just the opposite
Canadian fuel economy different rating Oilers99 Scion FR-S / Toyota 86 GT86 General Forum 14 10-04-2012 08:16 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
Optimistic fuel economy? nubbster927 BRZ First-Gen (2012+) — General Topics 15 07-05-2012 08:50 PM
Subaru shows courage to cut horsepower for fuel economy [es vi: eks] Engine, Exhaust, Transmission 11 05-01-2011 02:02 PM
Fuel Economy Lexicon101 Engine, Exhaust, Transmission 38 02-22-2010 03:50 PM
