#1709 |
Drives: FRS hot lava
Wasn't going to pay the extra for the kit for a tune I was just going to throw away anyway plus I already have a licence wasn't going to pay twice. Anyway I got it sorted out. I threw my bigger injectors in and it fired right up. Figure the scaling is closer. Now it's getting loaded up on a trailer and towed to get a proper tune.
#1710 | |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
My DGM BRZ vid: https://www.youtube.com/watch?v=0OL9OhxexAA
My car journal thread: http://www.ft86club.com/forums/showthread.php?t=43402 |
#1711 | |
Drives: 2015 Raven FRS
#1712 |
Drives: FRS, Supra, Colorado D, GLC63
#1713 |
Boost Creep
Drives: 2016 HyperBlue BRZ
It's 2.5 bar, the scaling is entirely different, and the base map from Edelbrock doesn't cost anything.
SBD400X Turbocharged 2016 Series.HyperBlue BRZ
#1714 | |
The tune is FREE to anyone who owns an Edelbrock kit. Kit 1556 includes an EcuTek cable and license; kit 15560 does not include an Ecutek cable and license. The tune is available to everyone with a kit; all you have to do is provide Edelbrock with your dongle ID. Email them now, and you'll have a tune for stock injectors probably by Noon tomorrow. |
| The Following 3 Users Say Thank You to CSG Mike For This Useful Post: |
#1715 | |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
So are you saying that I could, for shits & grins, even though I am running another tune (from Moto-East), email calibration@edelbrock.com with my dongle ID and get an Edelbrock OTS tune free, flash my car with that for let's say, comparison sake and then it flash back if I wanted without any issues (licensing or otherwise)?
#1716 | |
TALLY FT86
Drives: 2014 FR-S Monogram -- SBD Turbo --
| The Following User Says Thank You to Cockatoo For This Useful Post: | shiumai (10-17-2016) |
#1717 | |
Drives: UK GT86
.: Stealth 86 :.
| The Following User Says Thank You to Kodename47 For This Useful Post: | BirdTRD (10-17-2016) |
#1718 | |
Simply Forgotus
| The Following User Says Thank You to BirdTRD For This Useful Post: | CSG Mike (10-17-2016) |
#1719 | |
| The Following User Says Thank You to CSG Mike For This Useful Post: | BirdTRD (10-18-2016) |
#1720 |
Drives: 2013 Black BRZ Limited
Alright - I finally had some time to work on the BRZ tonight. I ended up ordering a smoke machine for $80 shipped off of eBay.
![]() Link to ebay item It runs off a 12v battery and compressed air. There's a regulator on the side which drops it down to 2 psi. There's a nichrome wire wrapped in a wick which is then soaked in mineral oil. 30 seconds after hooking everything up you've got a nice steady stream of smoke. ![]() I removed the TMAP sensor, stuck the smoke hose in, blocked off the intake pipe with some duct tape, and immediately looked towards the bypass valve to see if that was the issue. There was plenty of smoke, but nothing coming from the bypass valve. ![]() Smoke was pouring out of somewhere. I let the engine bay clear and then resmoked it. It was coming from one of the hoses attached to the EVAP solenoid. Specifically the hose that connects the EVAP solenoid to the throttle body. There are two hoses that connect to the solenoid, one of which, the Edelbrock instructions say to use an included hose clamp. The other is just press fit on. That hose came right off with a ginger tug. ![]() Didn't need to remove the AC compressor or anything else. Used a long pair of forceps to pull the hose off and then attached a hose clamp. ![]() Resmoked it and nothing leaked from the EVAP solenoid this time. The entire engine bay was pretty clear except for a little bit leaking out of the intake. Manifold gaskets and the other hoses seemed tight. I know others have raised the issue of clamping the EVAP hoses for all forced induction installs (given the number of threads explicitly calling it out) however, I don't understand why Edelbrock wouldn't just include another clamp and write it into the instructions? I'm hoping this solves my issue. Will monitor fuel consumption and take some MAP logs the next time I get to drive... |
| The Following 7 Users Say Thank You to taiguy For This Useful Post: | BigFatFlip (10-23-2016), BirdTRD (10-18-2016), CSG Mike (10-18-2016), djdnz (10-18-2016), gramicci101 (10-18-2016), paiceyfan (10-18-2016), strat61caster (10-18-2016) |
#1721 |
TEQSPORT Brand Manager
Drives: '24 GR86 + '16 FR-S
Anyone tracking this kit (road course) using a 3 inch pulley + E85 on a stock motor?
| The Following User Says Thank You to ATL BRZ For This Useful Post: | jmimac351 (11-04-2016) |
#1722 |
![]() Threw a P0507 code again today. ![]() Anyone have thoughts on where else to look? Loose hoses, or places that air could be getting in? The behavior is noticeable when coming up to a stop. Clutch in, foot on the brake, the RPMs will dip down to 1000 and then climb back up to 2000 where it spins for a few seconds before settling back down to 1000. Once it settles, it stays there without wavering. The entire time, my right foot is on the brake, so no effect from the accelerator. This is getting tiresome. |
| Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
| Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
| Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
| Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) — General Topics | 0 | 05-24-2012 10:09 PM |
