Old 10-12-2016, 11:13 PM   #533
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Gramlights57FXX, I believe.
Swing and a miss.
It looks like a rays center cap. It's not G25.... dang, back to Google.
Old 10-12-2016, 11:44 PM   #534
Tien0227
Tien0227's Avatar
Drives: FRS 10 Series MT
Swing and a miss.
It was a nice try. I was convinced at first
Tien0227 is offline   Reply With Quote
Old 10-16-2016, 08:11 PM   #535
Veloist
Veloist's Avatar
Drives: ‘93 MR2, ‘22 GR86, ‘23 GR Corolla
I researched a bit and found these wheels which seem to be exclusive to Australia. Company name is Roh Wheels and the wheel name is Korsa.
Veloist is offline   Reply With Quote
Old 10-17-2016, 08:15 PM   #536
Chris17BRZ
Drives: 2017 BRZ WR BLUE
Question 18x9+33
Hello, Not sure exaxtly how this works. Never used a forum before. I own a 2017 BRZ. Stock height and looking to remain that way. I'm interested in purchasing some Cosmis xt-206r in 18" wheel size and looks like the smallest width is 9 + 33. I looked for quite a while and couldn't found anyone with these same exact wheel specs. Just wondering if they will fit with no rubbing issues. Thank you in advance
Chris17BRZ is offline   Reply With Quote
Old 10-26-2016, 11:28 AM   #537
Leonardo
Country Boy 4 Life
Leonardo's Avatar
Congratulations on the 17. Welcome to the forum.
+33 9" wide wheels will poke. +35 8" wide is generally considered flush.
These wheels are 17x9 +30. Or only 3mm different.
http://www.ft86club.com/forums/showthread.php?t=7533
You can see, narrow tires and camber is needed to make them fit.
Also, read page one of the Meaty tire thread. Lots of good info for wide wheels and low offsets.
Good luck!
Old 10-30-2016, 03:45 PM   #538
Chris17BRZ
Good luck!
Thank you. I ended up going with the Cosmis R1 18x8.5 +35. Will need to take some pics and post them soon.
Old 10-31-2016, 06:50 PM   #539
Morchkin
Morchkin's Avatar
Drives: 2013 Scion FR-S Firestorm
Hello everyone - I'm new here, in fact this is my first post. I chose here since wheels were my first upgrade. I just purchased my FR-S at the end of this past August. I went a bit aggressive on the offset, still, had I done more extensive research I'm not sure I'd make a different decision. Wheel turn response slowed a little; however, the wide stance feels more planted to the ground. The pros outweigh the cons IMO. Anyone have a similar experience? Let me know what you think! BTW I stinkin' love this car.
They are Drifz Spec-R 308MB 17x8 +20 offset:
Morchkin is offline   Reply With Quote
Old 11-21-2016, 03:18 PM   #540
JoeShaft
JoeShaft's Avatar
Hey guys. Got my winter/cold weather setup on. Picked up some Avid1 AV-52 wheels in 18 inch with Continental DWS-06 tires to run for the cold months. I'll keep my stock Five Axis 19's with summer tires for the warm months. Same staggered setup as my 19's, but slightly more aggressive offset. The car is lowered on Tein gold springs, which I believe were part of the Five Axis package that came on the car. They lower it around 1 inch or so. No Rubbing issues so far. Fronts are pretty flush, rears poke a bit. I love the look. May have to get another set for summer tires.
Wheel specs are:
Front 18x8.5 + 35, 225/40R18 tires
Rear 18x9.5 +30, 255/35R18 tires
2013 Scion FR-S M/T, Five Axis Edition, Whiteout
JoeShaft is offline   Reply With Quote
Old 11-23-2016, 07:41 AM   #541
Alpha_noob
Alpha_noob's Avatar
Drives: Toyota Gt86
Wheel specs are:
That looks sick af!
Sent from my SM-N920C using Tapatalk
There's no point in owning an 86 when you like to sell your cars at low mileage
Alpha_noob is offline   Reply With Quote
Old 12-09-2016, 04:01 AM   #542
Chris17BRZ
18x8.5 +35
Here is the results of added the cosmis r1 wheels. 18x8x5 +35 all around. Loving the wheels. I'd like to get rid of some on the tire gap. Looking for a flush fitment. Some help needed on recommendations on springs/coilovers. Also need to know how much to drop it. I don't know much about this subject. Trying to stay away from camber or rolling my fenders. Not trying to go too low, just get rid of some/all of the gap. Any help would be greatly appreciated. Thank you in advance.
Old 12-09-2016, 06:52 AM   #543
swarb
Measuring tape is your friend.
Anything more than 1.5 inch drop, coilovers are needed. I don't think there are any springs that go lower than 1.5inches from stock.
Suspension cambers towards more negative as you lower it.
Camber is not adjustable in the rear without lower control arms. You don't really need it if you are only lowering an inch or so.
Front you need camber plates or camber bolts.
Eibach springs are pretty popular and so are RCE yellows. Search threads for pics/reviews of those.
Old 01-03-2017, 01:10 PM   #544
Chris_98
Drives: Scion FRS 2013
Wheel fit ment
YOO Someone help a 86 bro 😢.
I'm about to buy forme 9 wheels and I am currently running stock suspension just for now , I need to know if 18x8.5 with 30 offset will fit with no issue
Chris_98 is offline   Reply With Quote
Old 02-01-2017, 02:21 PM   #545
FT_86_SM_GP
FT_86_SM_GP's Avatar
Drives: Lawn moweR
OZ Racing Chronos 16inch 8J
OZ Racing Chrono's (Originally on Toyota Celica GT4 rally car)
16inch
8J
FT_86_SM_GP is offline   Reply With Quote
Old 02-08-2017, 05:45 AM   #546
Alpha_noob
Alpha_noob's Avatar
Drives: Toyota Gt86
XXR 527 18" Concave
Hey Guys. I'm new to this forum. I think this will be my first post.
Anywho, I've pulled the trigger on a set of XXR 527's Deep Concave
They're 18 inch. Here's the spec:
Front: 8.75J ET30 Tyres: R18/35/215
Rear: 9.75J ET20 Tyres: R18/40/225
I've had no Rubbing issues and they fit perfectly fine with the correct spigots.
brz aftermarket wheels, brz wheels, fr-s aftermarket wheels, frs aftermarket wheels, scion fr-s wheels, scion frs wheels, subaru brz wheels
BRZ/FR-S Wheel Fitment Photo Topic DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 07-12-2012 04:16 AM
BRZ/FR-S/86 Wheel Fitment Simulators JDMSushi Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 0 07-05-2012 10:49 PM
Stock Suspension and Wheel Fitment bneale Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 11 06-29-2012 07:42 PM
Wheel size and fitment bsclywilly Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 48 03-27-2012 12:34 PM
Wheel fitment sfwg BRZ First-Gen (2012+) — General Topics 6 10-28-2011 06:33 PM
