Old 10-06-2016, 08:34 PM   #1
CTB727
Drives: 2013 Subaru BRZ
Code P000B
So my CEL has been coming on and off over the past few weeks with a code P000B - cam position sensor slow response, bank 1 position B. Can someone tell me where exactly this is located?
I have searched everywhere and can't seem to pinpoint exactly where this is.
I bought a sensor from the dealer and hopefully this solves the issue. I'd imagine with the CEL being intermittent that it's a sensor issue, and not something mechanical.
CTB727 is offline   Reply With Quote
Old 10-06-2016, 09:57 PM   #2
steve99
Drives: FT86
have a look at the tsb here related to rough idle cam position and cam sensor shimming.
http://www.ft86club.com/forums/showthread.php?t=21868
Unfortunatly it might not be as easy as the sensor
it could be the cam sprocket/actuator or the cam oil control valve that causing the slow response to ecu commands. ie the sensor is ok
or a problem with the ecu itself
Old 10-06-2016, 10:26 PM   #3
Oh, my ..... @CTB727 since you don't know where it is ...... and from what steve99 says, I would recommend you take your car into a dealer ....
Old 10-06-2016, 10:52 PM   #4
CTB727
There are multiple cam sensors, in case you didn't know. I'm just trying to get to the correct one so I don't end up replacing a perfectly good sensor.
Also I read the about the cam sprocket TSB. My car exhibits NONE of the other symptoms or codes. So I will go with the sensor first.
Thanks for that very insightful and informative response though.
Old 10-07-2016, 12:12 AM   #5
steve99
Drives: FT86
yes that the reason I referred you to the TSB section
see here while this tsb is for cam position censor cam shimming it does show you can sensor location, and if you note it does not mention P000B
http://www.ft86club.com/forums/attac...6&d=1375302652
however I would suggest you read the TSB below as well it does mention P000B , it looks like you have not seen this one . note it does suggest multiple causes for the problem and requires extensive diagnostics and replacement of expensive components such as oil control valves, camsproket/actuator and ECU , but none of them being the cam sensor itself.
02-132-12 : DTCs Relating to the AVCS (Active Valve Control System)
Old 10-07-2016, 12:25 AM   #6
I'm sorry if I insulted you.......
I didn't mean to challenge your ability to diagnose and fix your car's problem.
I was just trying to be helpful, by suggesting you take it to a professional, experienced in these matters .....
guybo (10-10-2016), Ultramaroon (10-11-2016)
Old 10-07-2016, 12:55 AM   #7
steve99
Drives: FT86
quite a logical suggestion, given the amount of diagnostics and expensive parts that can contribute to this issue, even the dealers have trouble with this problem.
humfrz (10-07-2016)
Old 10-10-2016, 08:15 PM   #8
CTB727
Thanks. Just an update, bringing the car in to the dealer tomorrow. Found that position B is out of reach. Also not trying to take everything apart on my daily driver when I have a 60 mile daily commute.
Will let you all know what the issue is.
Old 10-11-2016, 03:28 PM   #9
TatharPallan
Drives: 2015 Subaru Blue Series - Pearl
GL dude.. dealer has had my car in several times for this same issue replacing Oil control valve(OCV ) several times, cam sprocket, and ECU. They have had my car for 3+ weeks now with no idea on how to fix. I recently filed a Motor Vehicle Defect Notification with Subaru.
2015 BRZ Series.Blue CWP (K1X) - JDL UEL Header, 3" JDL Res FP, 3" JDL OP, 3" Perrin Res Cat back, 3" Perrin BigMAF Intake/Inlet tube, Perrin Light Weight Pulleys (AC, Water Pump, Crank) - Moto-East FFK - E85 Tuned by HRI - ECUTEK - Eibach Pro-Kit Lowering Springs
TatharPallan is offline   Reply With Quote
Old 10-11-2016, 11:48 PM   #10
CTB727
Well, $395 later. Apparently the powertrain warranty doesn't cover sensors? They replaced part number 10921AA230, valve assembly - oil control. Also says "replace bank one camshaft sensor to correct", even though a part number isn't listed or priced.
The Following User Says Thank You to CTB727 For This Useful Post:
shiumai (10-12-2016)
Old 10-13-2016, 09:44 PM   #11
BRZnut
Drives: BRZ DGM Limited
Did that fix the issue?
Old 10-14-2016, 04:42 PM   #12
TatharPallan
I doubt it as i've had both replaced in my car.
Old 10-23-2016, 05:31 PM   #13
CTB727
It's been nearly 1000 miles, and so far yes.
I'm speculating here but I honestly wouldn't be surprised if running 0W-20 in Florida for so long has caused some of my issues. I also had oil seepage that was repaired (under warranty) back in June.
Old 09-03-2018, 02:18 AM   #14
eric555
Drives: gt86 aero kit
Hey found any solution ?
eric555 is offline   Reply With Quote
Another CEL code whitefrs Forced Induction 20 11-27-2019 12:27 PM
p000b Djratrap Issues | Warranty | Recalls / TSB 8 08-29-2016 03:33 PM
Lean Code and 02 Code diagnostics. Kiske Engine, Exhaust, Transmission 12 04-28-2016 11:19 PM
CEL code ChandlerSwyng Issues | Warranty | Recalls / TSB 2 04-08-2014 02:27 AM
u0115 code? ThisGuy919 Issues | Warranty | Recalls / TSB 1 11-11-2013 01:09 PM
