View Poll Results: Do the MY17 twins chirp?
My fuel pump is chirping 10 52.63%
My fuel pump is not chiping 9 47.37%
Voters: 19. You may not vote on this poll
Old 10-07-2016, 05:20 PM   #1
Impureclient
Drives: 2015 FR-S
MY17 fuel pump chirping
I know this is more of an Issues/Warranty/Recalls/TSB thread kind of question but I would imagine most new 17' owners aren't frequenting that subforum much...yet.
So is this not an issue at all for you new owners or is it still there?
Old 10-07-2016, 09:48 PM   #2
rkaywhodat
Drives: 2017 Toyota 86 Halo
Not yet..hopefully never using Ultramar 91 No ethanol and Shell only thus far.
Sent from my D5803 using Tapatalk
rkaywhodat is offline   Reply With Quote
Old 10-07-2016, 10:03 PM   #3
The changes to the 17 fuel pump go way beyond the pump itself. With the completely different cam stroke and pump they have probably killed the crickets. This is not good news for the pre 17s though since a simple pump swap will not work and probably can't even be done anyway since the cam is changed. Odds are they will do nothing to correct the pre 17s at this point.
Cole (10-07-2016), humfrz (10-07-2016)
Old 10-08-2016, 01:41 AM   #4
WWFT86
Drives: 2017 BRZ Limited
Don't believe I heard it yet on my MY17 BRZ. I've been running Shell 91 exclusively.
WWFT86 is offline   Reply With Quote
Old 10-08-2016, 02:28 AM   #5
JD001
JD001's Avatar
Drives: Subaru BRZ
For those who are not driving MY17 cars are excluded from voting therefore can't see which way you guys are swinging...
Old 10-08-2016, 04:05 AM   #6
PetrolioBenzina
PetrolioBenzina's Avatar
Drives: 17 86
No chirp here, and I would not care at all if it did.
PetrolioBenzina is offline   Reply With Quote
Old 10-08-2016, 05:01 AM   #7
JD001
JD001's Avatar
Drives: Subaru BRZ
Out in MY14 yesterday, outside temp 13/14c and the crickets were silent.. perhaps in hibernation.
Old 10-08-2016, 05:32 AM   #8
PetrolioBenzina
Drives: 17 86
I never understood why this was such a big deal.
The Following 3 Users Say Thank You to PetrolioBenzina For This Useful Post:
Hoahao (10-08-2016), pushrod (10-10-2016), Ultramaroon (10-10-2016)
Old 10-08-2016, 09:56 PM   #9
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
As the person who (I believe) first posted the cam shaft differences as a possible reason why the new fuel pump may not work on our older cars, I feel obligated to add the following:
The part numbering of the new pump indicates that it should be interchangeable. That said, even though the new pump should work on our older cars it may be that it still chirps due to the larger cam lobe on our camshafts.
Frankly I am not bothered by the crickets, I've kind of grown used to them so I would not bother trying the new pump unless my current pump fails. I am very interested though in whether it gets rid of the crickets from a curiosity standpoint!
nextcar is offline   Reply With Quote
Old 10-08-2016, 10:26 PM   #10
extrashaky
Drives: 2014 BRZ Limited
Yes you can. Click "View Poll Results" in the lower right hand corner of the poll. Or you can just click here:
View Poll Results
The Following User Says Thank You to extrashaky For This Useful Post:
JD001 (10-09-2016)
Old 10-08-2016, 11:12 PM   #11
I am not convinced it would work or at least not properly. Both the cam and the pump were changed to work together. If the new pump is used with the old cam there could be too much lift since the old ones (according to the info) had a longer stroke. Of course the reduced cam lift could make up for that but things are deviating from the design specs in at least two areas so I would not try it. Sure sombody will at some point though and then we will know for sure.
Old 10-09-2016, 07:36 AM   #12
PetrolioBenzina
Drives: 17 86
I really want someone to try this, in a watch the possible train-wreck sort of way.
The Following User Says Thank You to PetrolioBenzina For This Useful Post:
Tjs Blunts and Coffee (10-09-2016)
Old 10-09-2016, 09:21 AM   #13
Somerandom18
Drives: 2017 manual BRZ
Just hit 1k miles and no crickets so far.
Sent from my SM-N930V using Tapatalk
Somerandom18 is offline   Reply With Quote
Old 10-09-2016, 12:09 PM   #14
nextcar
#totaled
More parts for me!
The Following User Says Thank You to nextcar For This Useful Post:
Tcoat (10-09-2016)
Fuel Pump "Chirping" relaxjim Hawaii 27 04-19-2016 11:51 PM
Fuel system questions. Boost-A-pump/stock fuel lines for engine swap Toxicmilk45 Engine, Exhaust, Transmission 4 12-14-2015 03:52 PM
Important Chirping Pump Update... 5AD86D Issues | Warranty | Recalls / TSB 92 02-07-2015 02:52 PM
cricket chirping after replaced fuel pump withbrz Issues | Warranty | Recalls / TSB 3 02-18-2014 08:18 AM
Dynosty FR-S/BRZ Fuel System Upgrades! Deatschwerks DW65C Fuel Pump Dustin@Dynosty Engine, Exhaust, Bolt-Ons 3 08-21-2012 04:53 PM
