#43 |
Drives: Satin White BRZ Limited
It handles very well. The balance is neutral with a little bit of understeer, if I go into a corner too hot. I have 0 toe all around, so wear is even on the tires. I drive spiritually on a daily basis and I do not get any camber wear on the tires. I would recommend my alignment for the street.
| The Following User Says Thank You to shattered_memory For This Useful Post: | zc06_kisstherain (10-07-2016) |
#44 |
Drives: SWP BRZ
do i need to wait few days to settle spring then get alignment?
my endlink came so gonna install tomorrow then get alignment on same day if possible. |
#45 |
Drives: scion fr-s
im thinking about purchasing these very soon... is it worth it? and will i need to upgrade my lca and stuff? or can i just run it stock with just the coils.. thanks in advance
#46 | |
Friendly Person
Drives: CWP Aozora
If anyone can confirm this, that would be appreciated. |
#47 | |
Drives: '13 10 Series FRS #1203
If you do a 1-1.5" drop you should be able to get away with stock and a little camber. I would however plan to get LCA's and Toe arms for the rear at somepoint. |
#48 |
Drives: 2013 FR-S Argento
Sure you can run just the coils with no camber adjustment. The lower you make your car, the more camber you'll have in the rear. Fronts suspension is not multilink so camber stays roughly the same, so you'll eventually have much more rear camber than front, which will make your car understeer too much. At the very least get some SPC camber bolts for the front and max them out, they're cheap. If you go really low then you'll probably want adjustable rear LCA's as well - ideally you want adjustability on front and rear as whomever aligns your car can set it up right.
| The Following User Says Thank You to bfrank1972 For This Useful Post: | Valfred (10-07-2016) |
#49 |
Anything under 2 should be good without hindering drive ability, once you start going over that more so in the front the car will start to grip imperfections in the road more from my experience, which can suck on long road trips.
| The Following User Says Thank You to Shady195 For This Useful Post: | Valfred (10-07-2016) |
#50 |
Hmm, I don't have this issue, thought I would, but I'm at -2.7 in the front, 0 toe, and it tracks fine down the road. I think there are other factors (i.e. tire compound/tread/sidewall stiffness, tire pressure, etc) that can help or hurt this. Making sure you have a good even alignment helps too. YMMV.
#51 | ||
Drives: SWP BRZ
#52 | |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
http://www.nydailynews.com/news/nati...icle-1.2708311
My DGM BRZ vid: https://www.youtube.com/watch?v=0OL9OhxexAA
My car journal thread: http://www.ft86club.com/forums/showthread.php?t=43402 |
#54 |
Drives: 2013 White-Out FRS
Sorry for my noob question, but if base drop is 1.2 inches and I only want my car lowered that much, I wouldn't need to make any adjustments right? Would I have to in the rear still as the rear is usually higher than the front? Or am I mistaken.
I live my life one quarter-pounder at a time.
#55 |
Drives: scion fr-s
#56 | |
| The Following User Says Thank You to shattered_memory For This Useful Post: | shiumai (10-07-2016) |
| Tein Flex A and Z!!! | breadcrumbz | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 25 | 05-24-2016 03:44 PM |
| Tein Street Flex Review! | Mikepage | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 52 | 04-20-2016 06:56 PM |
| Tein Street Flex Review and Short Video! | RallySport Direct | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 66 | 04-13-2016 02:17 PM |
| FS: (SOLD) Tein SRC / Tein Flex / Cusco F&R Sway / Cusco F&R Strut | kvnchu | Brakes, Suspension, Chassis | 26 | 12-09-2013 01:10 PM |
| New Tein Street Flex Coilovers - Review and Initial Impressions | RallySport Direct | Announcements, Contests, Giveaways | 6 | 02-18-2013 12:06 PM |
