Old 10-05-2016, 10:54 PM   #15
Lantana frs
Drives: 13 frs red
Originally Posted by renfield90 View Post
I found the problem.
OEM batteries are notoriously poor quality. I got 2.5 years out of mine which was pretty good considering my climate.
Recommend you get the next battery from your local parts store, and hook it up overnight to an external charger 2x per year. I have made a cheapo parts store battery last 6+ years that way.
I didn't drive my car for over a year but had it hooked up to a battery tender. I swear by those things. Oem battery still going strong.
Lantana frs is offline   Reply With Quote
The Following User Says Thank You to Lantana frs For This Useful Post:
why? (10-08-2016)
Old 10-05-2016, 11:32 PM   #16
I blame this on manufacturers cheaping out on key components. I got sick of replacing the alternator on my Eclipse every time I left the headlights on. On my third one, I replaced the puny little internal regulator with a beefy F-150 external one. Never learned to shut off my lights but that alternator kept right on charging.
Well, now, THAT brought on a chuckle .....
Ultramaroon (10-05-2016)
Old 10-05-2016, 11:54 PM   #17
s2kbobby
s2kbobby's Avatar
Drives: 2013 BRZ WRBlue
Do you have any non standard accessories, ie media system, dash cams , alarms etc.
devices plugged into obd port ?
None of the above. The car is stock.
I charged the battery overnight before taking it in to test the charging system.
s2kbobby is offline   Reply With Quote
The Following User Says Thank You to s2kbobby For This Useful Post:
steve99 (10-05-2016)
Old 10-05-2016, 11:58 PM   #18
s2kbobby
s2kbobby's Avatar
Amen! The battery I bought from Subaru a year ago had a 2" plastic spacer at the bottom to keep it the same height as the original. I would have liked to see that 2" occupied by plates and electrolyte.
Old 10-06-2016, 12:06 AM   #19
s2kbobby
s2kbobby's Avatar
As mentioned before, have you cleaned the battery posts/cable connectors..??
They may "look" clean, but still have a layer of varnish that could prevent a good contact.
Yup! The posts and connectors are nice and clean.
Years ago, battery posts would obviously corrode with grey gunk. Not so much now and a poor connection is much less obvious.
Even my 14 year old Honda has clean terminals. I am not sure what changed. Perhaps the composition of the posts or connectors has been changed to reduce the dielectric effect.
humfrz (10-06-2016)
Old 10-06-2016, 12:13 AM   #20
Captain Obvious here ...... you have checked the electrolyte level ......
Old 10-08-2016, 04:03 PM   #21
s2kbobby
s2kbobby's Avatar
Indeed! I didn't. The battery is less than a year old and I have to remove the strap to access the one large cap that covers the inspection holes. That's my next job. . . .
BTW it has had no issues since I gave the battery a full charge.
There has to be a significant parasitic current draw somewhere that could discharge the battery overnight. Intermittent at that.
Old 10-08-2016, 05:04 PM   #22
churchx
churchx's Avatar
Drives: 2014 GT86
Most common parasitic current draw type big enough to drain batteries overnight are forgotten left on lights
Old 10-08-2016, 07:58 PM   #23
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
If you got the battery tested, you don't have to check the electrolytes, that problem would be apprarent with the test (it'd cause a failed batt test)
Are you sure the battery is getting drained? When it won't start, will it turn over slowly but won't start or will it click once or many clicks? Will it do nothing? What's the voltage when it won't start? I'm beginning to think that this is a starter issue
guybo is offline   Reply With Quote
The Following User Says Thank You to guybo For This Useful Post:
why? (10-08-2016)
Old 10-08-2016, 08:19 PM   #24
Old 10-09-2016, 12:49 PM   #25
s2kbobby
s2kbobby's Avatar
I agree for most other cars. The BRZ has an "Auto" feature that turns on lights at dusk and turns them off when it is light. It also leaves the lights on for 30 seconds after the car is stopped.
From the manual:
"The light switch is in AUTO, the headlights and tail lights turn off 30 seconds
after a door is opened and closed if the push-button ignition switch is turned
off." -- The push button ignition switch refers to the keyless entry models.
Additionally from the manual:
"Battery-saving function-
In the following conditions, the headlights and the other remaining lights will
go off automatically after 20 minutes in order to prevent the vehicle battery
from being discharged."
There are a few situations that will cancel this battery-saving function however none of them apply to my parking situation.
So you see, the drain on the battery is not likely to be head light related unless there is something wrong with the in-car computer.
Old 10-09-2016, 12:53 PM   #26
s2kbobby
s2kbobby's Avatar
When it won't start it will turn over slowly and immediately stop. Subsequent attempts to start result in an even shorter turn over or simply dimmed lights as the starter engages.
No I haven't checked the battery voltage.
Old 10-09-2016, 12:59 PM   #27
s2kbobby
s2kbobby's Avatar
I appreciate all of the feedback however I believe I will have to simply live with this until I can come up with a common set of circumstances that appear to contribute to the dead battery problem.
Taking it to the dealer will simply cost $100 for nothing, unless I can replicate the issue.
Old 10-09-2016, 01:32 PM   #28
It is odd that an easy 8 out of 10 battery issues reported on this forum are with BRZs. I have watched this topic closely and found that reported issues with the FRS are rare. I believe they have the same stock battery so there must be something about the BRZ features that are causing the issue. Something seems be causing a parasitic draw but I have no clue what it could be.
humfrz (10-09-2016), Ultramaroon (10-09-2016)
USB port charging issue unsurety Issues | Warranty | Recalls / TSB 2 05-17-2014 02:49 PM
question ......about turbo charging frs 2JZ-GTE CANADA 14 02-11-2014 12:56 PM
Iphone 5 Charging idea DIY AG3NT_5CARFAC3 DIY (Do-It-Yourself) Guides 8 11-21-2013 04:48 PM
Twin charging EmeraldMalta Forced Induction 23 06-12-2013 10:09 AM
****ADvice REquired: Built/vs/Stock*** killerkid08 Forced Induction 54 06-09-2013 04:57 PM
