Old 09-18-2016, 10:53 PM   #1
Glok24
Drives: 2014 FR-s Whiteout
Factory Reset on Bespoke head unit?
Hello, I was wondering if anyone had figured out how to do a factory reset on the Bespoke head unit in the 2014 FR-S.. Im not sure if there is a way to do so, but I think that might solve a couple of problems I am having with the unit. I have not been able to find any info on this so far
Glok24 is offline   Reply With Quote
Old 09-21-2016, 12:41 PM   #2
misterfly
Drives: Toyota 86 2017
If you open the unit, you will problably find a battery , try to retire it and replace it after one minute, normally you can reset electronic by doing that, if the unit dont have battery, i dont know where you can make the reset.
misterfly is offline   Reply With Quote
Old 10-05-2016, 05:52 PM   #3
nextcar
Guilt free parts vulture!
Drives: 2024 GR86 Trueno Halo 6MT
Try the following (it will take the unit through the diagnostics and setup...)
1) Hold down the audio button
2) While holding down the audio button, turn the headlights on and off 3 times
3) Turn off the car then turn it back on
Hope this helps...
nextcar is offline   Reply With Quote
Old 10-09-2016, 08:02 PM   #4
Glok24
Hope this helps...
Thanks for the suggestion, but a couple days after i posted this, i found out about this diagnostic menu and stuff, but it didnt work. theres another menu that you can get into that says itll reset to factory default, but it didnt actually do anything. thank you though for the suggestion
bespoke, factory reset, head unit
Head Unit random reset/power cycle ? Breeeep BRZ First-Gen (2012+) — General Topics 6 06-03-2015 03:41 PM
FS: BeSpoke Head Unit nocurfew Audio/Visual, Electronics, Infotainment, NAV 6 09-11-2013 09:23 PM
Bluetooth causing head unit to reset? Eric1855 Electronics | Audio | NAV | Infotainment 4 01-15-2013 09:42 PM
[FS] BeSpoke Head Unit ProTekk Audio/Visual, Electronics, Infotainment, NAV 1 11-21-2012 01:07 AM
