Old 10-03-2016, 02:06 PM   #645
modernbeat
Vorshlag R&D
modernbeat's Avatar
Drives: A new one every month
Originally Posted by cf6mech View Post
Can i buy it though?.....how is the ground clearance with the brackets?...
Yes, I'm sure you can purchase it. I expect ground clearance to not be affected beyond the low point of the box sections under the floor.
I think the low point of your car isn't the headers, but the angle of the cats. I think with some rework they would be brought up to aid the ground clearance.
Jason McDaniel at Vorshlag Motorsports
modernbeat is offline
The Following User Says Thank You to modernbeat For This Useful Post:
cf6mech (10-03-2016)
Old 10-03-2016, 03:01 PM   #646
cf6mech
Drives: FRS Silver LS1 swapped.
Ok.....had to remove cats....had no choice.....thanks for the reply....end link lengths figured out yet.....are the brackets available now?....
cf6mech is offline
Old 10-03-2016, 03:26 PM   #647
cf6mech
Modernbeat you have a PM
cf6mech is offline
Old 10-03-2016, 08:05 PM   #648
wooly35
Drives: 2014 Scion FR-S LS3
some assembly required. lol
2014 scion FR-LS3 lol
wooly35 is offline
The Following 5 Users Say Thank You to wooly35 For This Useful Post:
C130NAV (10-05-2016), cf6mech (10-03-2016), civicdrivr (11-30-2016), gatorbushmen (10-03-2016), Zer0 (10-04-2016)
Old 10-04-2016, 04:20 PM   #649
Zer0
Drives: 2015 frs
some assembly required. lol[/QUOTE]
You lucky bastard. Mine should be in Wednesday or Thursday
Zer0 is offline
The Following User Says Thank You to Zer0 For This Useful Post:
cf6mech (10-04-2016)
Old 10-04-2016, 06:35 PM   #650
Zer0
Drives: 2015 frs
It arrived early.
Zer0 is offline
The Following 2 Users Say Thank You to Zer0 For This Useful Post:
Shark_Bait88 (10-04-2016), wooly35 (10-04-2016)
Old 10-04-2016, 06:49 PM   #651
Zer0
Drives: 2015 frs
Originally Posted by wooly35 View Post
Yes I did. It wasn't pretty, but I got them out. I'm relocating my battery today. I want to get the fuel pump upgraded as soon as possible. Do you know what fuel pump we need for this swap?
Not sure what pump people are using. I plan on running a surge tank with a internal pump in the tank to prevent fuel starvation. I'm also just going to a tiny battery upfront. Well the smallest battery that will fire the engine.
Sorry for the late reply I was in a nasty accident that totaled out my commuter car on the way to work. This is going to cause a delay to the project. Gotta buy another car.
Zer0 is offline
Calum (10-05-2016), wooly35 (10-04-2016)
Old 10-04-2016, 07:32 PM   #652
wooly35
Thats no good. Hope it doesn't delay the project to long.
wooly35 is offline
Old 10-04-2016, 08:10 PM   #653
cf6mech
Dont see ths need for a surge tank myself unless your thinking drift car or FI and race gas....the main problem is our tank design.....its a saddle with a weak syphoning system for the pax side.....Vorshlog never addressed this for me...after pulling out in traffic with less than a half a tank and taking a left hand turn in a hurry to avoid uncomming traffic my car basically stopped and it got hairy fast....once the fuel evened up it fired up and i floored it so I wouldnt get squashed......so what i ended up doing is wiring in a second pump for pax side of equal output.....forgot the LPH but its over kill..didnt want that near mishap to happen to me again......both pumps feed into a common T obtained through jegs along with the AN plumbing hard lines....The wiring for the pumps with relays supplied by dietchworks with direct voltage coming straight off my rear mounted battery.....works great....have had no issues.....but becauss of my dual fuel pumps the regulator in engine bay had to be turned way down to get to 60 psi , the nominal pressure for A LS1.....but also the 60psi doesnt budge no matter what the demand requires......this saddle tank dual pump set up has been used by others for years.....looked into the hydromat for awhile....but decide against it since this seems to be working fine......long term though since pumps are turning at full capacity they may have longevity issuss....eventual i need a cockpit fuel pressure gauge easily wired in via my regulatod.
cf6mech is offline
The Following User Says Thank You to cf6mech For This Useful Post:
Old 10-04-2016, 08:22 PM   #654
cf6mech
Bought two of these....http://www.deatschwerks.com/products...ion-kit-detail
cf6mech is offline
The Following 2 Users Say Thank You to cf6mech For This Useful Post:
wooly35 (10-04-2016), Zer0 (10-04-2016)
Old 10-05-2016, 01:01 PM   #655
Calum
That Guy
Drives: 2013 asphalt FRS MT
I hope you're alright, man. What kind of car did you lose?
Also, what does Vorshlag do to the transmission?
Calum is offline
Old 10-05-2016, 06:41 PM   #656
C130NAV
C130NAV's Avatar
Drives: Whiteout 6Sp FR-S
Thats weird I have driven mine hard for about 10k miles and never had a fuel starvation issue in a turn. I am however running a DW300. I don't have cats either. I have custom 180 headers that connect to a Fullblown custom made exhaust. I do have clearance problems with the exhaust in the back but I think when I get cutouts I will have the shop address this.
C130NAV is offline
Old 10-05-2016, 08:33 PM   #657
cf6mech
Wouldnf matter the pump size, once the gas flows to on side of the saddle ,not enough syphoning to run a V8, atleast in my case, its a ventury syphon btw, nothing is pumping nothing is syphoning eventually your bucket runs dry....Cough! Cough!......still might look into a Hydromat though for insurance.
cf6mech is offline
Old 10-05-2016, 08:41 PM   #658
cf6mech
Wish somebody would make this for our cars......would of saved me a lot of headaches and many days waking up with a sore back......we are not alone with this issue....http://www.bimmerworld.com/Intake-Fu...ation-Kit.html
cf6mech is offline
FS: KW V3 Coilovers w/ Vorshlag Front Camber Plates Steeze_Its Brakes, Suspension, Chassis 7 06-27-2014 10:32 PM
FS: Vorshlag Front Camber Plates h4nh Brakes, Suspension, Chassis 1 03-01-2014 11:49 PM
FS: KW V3 w/ Vorshlag camber plates & oem stock suspension (SF bay area) serial gixxer Brakes, Suspension, Chassis 18 05-20-2013 09:51 PM
WTB: Front Vorshlag Camber Plates YDNA Brakes, Suspension, Chassis 0 05-03-2013 06:31 PM
Maybe a repost, but have you seen the Vorshlag project car? Bart1 BRZ First-Gen (2012+) — General Topics 3 01-07-2013 02:19 PM
